Question about Sanyo Televison & Video
My sanyo model #dp37649 turn on and off over ond over done replace main and power boards what do i need to do to fix it
Need help fix this problem please it power on or two second and off over and over
  • Sanyo Master
  • 933 Answers
Hey Chris, take off the back cover of the set and disconnect the key controller board. The key controller is the board that has your side buttons attached to it. If you replaced the main board and power supply with good parts, the only logical thing to try next is the key controller
Posted on Oct 29, 2012
Benimur
  • 6966 Answers
SOURCE: Sanyo 42
Hi again,
Sorry bout the Live Session.
May I suggest something?
Pls try another signal source other than the indoor antenna such as a DVD or even an old VCR.
It is possible that what you are experiencing is video muting due to dirty antenna signal. If even with a stable known to be good video source (DVD) the problem persist, then it is a matter of checking the voltages as indicated in your service manual.
Hope this be of some help/idea even if the chat did not work out. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 02, 2008
IrishDruid
  • 2712 Answers
SOURCE: No Picture
I would check the soldering first for any cracks, and any obvious faulty capacitors or components. It looks like the power board is going into a protective mode because of a short / failed component somewhere.
It would be virtually impossible to guess exactly where with a spot check..
Posted on Oct 29, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp 42' LC-62C42U main circuit board needs replacement
I would recommend Shopjimmy.com.
Parts are at reasonable prices. Compare with the prices at Partstore.com and you'll see what I mean.
Posted on Aug 07, 2009
  • 195 Answers
SOURCE: olevia 437-s11
Most likely the CCFL inverter has been the problem all along....
Posted on Oct 10, 2009
My sanyo tv model number dp32648 turns on but then the picture turns off still have sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 02, 2017 | Sanyo Televison & Video
What causes Sanyo tvs with model numbers starting with dp to white out the screen. I have 2 dp42647 and dp37649
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 27, 2016 | Sanyo Televison & Video
My 42inch Sanyo TV has sound but no picture how do it fix it
Apr 22, 2016 | Sanyo Televison & Video
When I turn the power on my Sanyo DP32648 the picture goes on for a few seconds then the screen turns black but there's still sound.What's wrong with it.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Apr 11, 2016 | Sanyo Televison & Video
How to fix Backlight on TV?
Mar 12, 2016 | Sanyo Televison & Video
I have sanyo model dp37649 the tv cut on and off.
Could be a heat issue again as the tuner board is overheating and being shut off by the power board. Depends what you see on the screen exactly, like snowy noise or a complete power down.
Oct 04, 2014 | Sanyo Televison & Video
Picture on a Sanyo dp42848
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ .
Sep 08, 2014 | Sanyo DP26648A DP32648 DP37649 DP42848...
My sanyo dp42840 flat screen turns off by itself after 5 minutes...what do I do?
The first thing I would check would be the electrolytic capacitors on the power supply board. If any of them are swollen or domed on top rather than flat, they will need to be replaced and that will fix your problem. I fix about 75% of them at the shop by replacing caps on power supply. A tech will probably charge around $100 if it is bad caps. It is a fairly easy job.
Jul 31, 2010 | Sanyo DP42848 LCD TV
Sanyo plasma 42 TV Turn off for no reason
Ok Fellas I found the Problem!
The Problem is the V4 Y-Main Board. This board is located on the left side of the case looking upright from the back. I spoke with may suppliers, and Sanyo all confirming this. Apparently it has been an issue for some time. Sanyo has replaced the V4 Y Main board with a W1 Y main board in newer models. The W1 Board is NOT compatible for us tho. Just to be sure... If your T.V is taken apart (like mine) Disconnect the peripheral cable from the V4 Y Main, and turn on the set. I bet it will power up with audio and channel function just NO picture. When you plug the board back in... POOF set shuts down. Replacement boards are VERY hard to come by. So Happy Hunting!
42' HD V4 Y-MAIN
PCB: LJ41-02760A LJ41-02761A LG92-01200A BN96-03352A
Oh yeah.. just FYI, Sanyo, Phillips, and Samsung all use the same parts. Hopefully that will help your searching.
Aug 26, 2007 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
113 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
