Question about Toshiba Satellite L505DS5983 Notebook
Toshiba satellite l505d-s5983 fan not running continuously
  • Toshiba Master
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Oct 29, 2012
big_al_1982
  • 95 Answers
SOURCE: toshiba satellite L505D GS6000 mouse freezing
reinstall the driver for the mouse touchpad
Posted on Feb 23, 2010
paul7of9
  • 1189 Answers
SOURCE: touchpad not working toshiba l505d-s5983
“Hi let’s see if we can fix this problem”
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
III. You may need to “Update Drivers” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Drivers”, click (OK), this will ensure that the application take effect.
Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
"Don't forget to rate the help," thanks
Posted on Jun 07, 2010
rh10
  • 122 Answers
SOURCE: I have a Toshiba Satellite L505D-S5983
Try a different mouse, that would prove where the problem lies. Looks to me like the mouse is failing.
Posted on Jul 16, 2010
Testimonial: "Thanks! Yes, I've noticed that the mouse is getting weird, in that sometimes it works and sometimes it doesn't. Also, are there viruses you can get that can mess up your mouse, or your ability to use it?"
  • 452 Answers
SOURCE: how to replace lcd screen for toshiba satellite
This guid will give you an idea on how to replace the LCD screen on your laptop.
http://bootmylaptop.com/how-to-replace-lcd-panel/
Posted on Dec 18, 2010
  • 1583 Answers
SOURCE: Toshiba satellite l505d-s5007 Toshiba satellite
I don't think that's available on laptops; I've never seen it on Toshiba models. There is usually a small battery to save BIOS info and keep the clock going when the main battery is out. It's either under the keyboard or near the memory or wireless card compartment. Remove the main battery and leave the adapter unplugged. Open the compartments and look for a a connector with just a red and black wire connected to it - if you see it going to a coin cell, that's the one you want. Unplug it and wait ten seconds. Plug it in and put everything back together. If you got the right connector, your computer will probably go straight to BIOS and ask you to set the time and date.
Posted on May 02, 2011
Speakers keep going on n off
Try the latest audio driver...then do an audio diagnostic by going to run then type dxdiag. Hope this helps
Mar 10, 2015 | Toshiba Satellite L505D-S5983,...
Toshiba Satellite L505D-S5983 Sorry if this is choppy but I kept getting use only legal characters and I can't seem to figure out what it is referring to I looked into the reflow process but when I...
The GPU in every laptop is soldered in place, if you have a lot of experience with reflowing then you can try to pull the GPU and replace it but a lot of the time it's actually more cost effective to get a replacement MB and sell the one that's having issues. Because the GPU may not be the only part that has gone out or it maybe another part that has gone out and is keeping the GPU from powering or outputting signals
Oct 29, 2013 | Toshiba Satellite L505D-S5983,...
Black screen even on ext monitor
External monitor confirmation means that you're not getting anything out. If there truly are not words coming up, telling you what's up, then you're probably looking at a bad logic board. It could be bad video, but if nothing, not even a fan, is spinning up, then you're not getting power across the system. Check all your power connections and inputs, but I'm leaning towards a bad system board.
Nov 17, 2012 | Toshiba Satellite L505D-S5983,...
How can I adjust the microphone?
The microphone can be manipulated with the sound software. Right mouse click on the loudspeaker symbol and select recording devices.
Oct 31, 2012 | Toshiba Satellite L505D-S5983,...
How do you remove keys from a laptop?
you need to use something to pry them up, do so slowly and easily.
Oct 09, 2012 | Toshiba Satellite L505D-S5983,...
Toshiba satellite l505D-s5983 Keeps freezing and going unresponsive
This sounds like ram memory issue, remove one stick of ram and power up, no change, remove second piece and replace the first, if this works the memory stick in your hand is defective.
Jun 16, 2012 | Toshiba Satellite L505DS5983 Notebook
My battery won't charge
There's not much that can be done except return the adapter for replacement. But first, are you sure your car's cigarette lighter works ?
Mar 28, 2011 | Toshiba Satellite L505D-S5983,...
Jul 16, 2010 | Toshiba Computers & Internet
Toshiba Satellite L505DS5983 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
