Question about Arris Wbm760a Touchstone Docsis 3.0 Cable Modem
Where do i get a network security key for Arris wbm760
Im trying to connect my other pc to arris wbm760
oldnovii
  • 667 Answers
SOURCE: how is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Posted on Jul 22, 2008
djxtreme979
  • 151 Answers
SOURCE: Switched to cable(arris modem) can't set up network
cable dsl same thing. Did you switch providers and get new modem from them? If so. Just delete previous netowrk and install new one let pc discover new one. Also, with your router you got a disc. It should install correctly. Perhaps it is previous network that is hindering you.
Posted on Dec 30, 2008
  • 17 Answers
SOURCE: Arris cable modem
if the power light is flashing then the modem is on battery backup and internet is disabled. plug the power cord into the modem or find a working power outlet, you should be set after that.
Power light flashing=bad
Posted on Jul 04, 2009
SOURCE: i have a arris tm602 modem, HOW DO I CONFIGURE MY
Cable modems bond to what they are plugged into, so you have the modem plugged into a computer and it is working fine. Then you want to unplug the ethernet cable from the computer and plug it into another device such as a netgear router. Then you find no matter what you do it will not work.
Now normally to break this bond to the computer so that it will bond with the router you would simply unplug the electrical power from the cable modem, wait for it to sync back up with your ISP's CMTS, power up your router which you would have connected via the internet or wan port, and you would be up and running.
You may have even did this with your Arris TM602. Why isn't your router pulling an IP address? The reason is simple, pulling the power cord did not really remove power since the modem has battery back up.
In order to make it release its bond to your computer, so it can bond with the router you need to either push the reset button on the back of the modem while still powered up or remove its battery pack while unplugged from power.
So try again, this time push reset on the modem. This question was posted in January so I am sure buttercup is all fine by now but maybe this will help someone else.
Posted on Jul 16, 2010
How to configure it
Disconnect the coaxial cable from the Arris.
Turn the Arris off.
Connect an Ethernet cable from your computer to the Arris.
Turn the Arris on.
Turn on (or reboot) your computer.
Open a command-line prompt on your computer.
Enter 'IPCONFIG' to see the IP-address of the "default gateway".
Open your web-browser, and type that IP-address into your web-browser, to access the configuration-page of the Arris.
Configure the Arris.
Turn the Arris off.
Connect the coaxial cable.
Turn the Arris on.
Reboot your computer.
Done.
Jun 04, 2015 | Arris New Sbg6580 Surfboard Extreme 3.0...
Where do I fine SSID Name & Encryption Key
If you are trying to set up a router and need to establish the SSID name and WPA encryption key, you will need to sign into the router using the routers IP address. Input the userid and password, then go to the wireless network setup page. Here is where you enable wireless operation, establish the SSID, and generate the encryption key or passphrase.
If you are trying to connect to someone else's wireless network, you need to know their SSID so that when you do a search for available networks you can determine which is theirs. Once that is established, if they give you the encryption key or passphrase, you can attempt to connect to their network. With the encryption key or passphrase, you will not be able to connect.
Mar 15, 2015 | Motorola Computers & Internet
Windows Vista won't let me config Arris tg862g router options
hope this help you.
you need yo reset the router, there is a reset button on the wireless router that you need to click for 10 sec after that, connect everything to your PC and follow instructions on this link bellow.
https://bendbroadband.com/residential/support/detail.asp?kb=100196
May 06, 2017 | HP Computers & Internet
Youtube error message
Here are some troubleshooting ideas to try, posted by youtube support.
https://support.google.com/youtube/answer/3037019?hl=en
Jan 03, 2014 | Arris Wbm760 A Docsis 3.0 Cable Modem...
How do i set up a wireless network with an arris wbm760 modem? i have suddenlink
Your device is just a modem. You would need to purchase a wireless router to go along with that in order to set up a wireless network.
Aug 19, 2011 | Computers & Internet
Where do I find the WEPkey for Arris TM502G? The question is posted all over the internet, but no real answers.
The WEP key is a encryption key that is configured in the wireless settings of the wireless router. This setting is then applied to the wireless card in the computer so it can connect to the wireless router.
To secure your wireless network from unauthorized access, please click on this link and follow my instrucrions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 19, 2010 | Arris Touchstone 450a (CM450) Modem
Need solution to Networking 2 comps thru an Arris tm602g/ct via a linksys 8 port switch, the seems to be no Usb connection on the modem
You will need to purchase a router my friend. The arris does not have a DHCP server built in and cannot assign IP addresses to the work stations. The only way that could work is if you ISP provided you with a second IP address, which would also be extremely unsafe from a security standpoint. Any wireless router should do the trick.
Mar 18, 2009 | Arris Touchstone 450a (CM450) Modem
Connecting my arris modem to x-box live
I have an Arris cable modem and use Xbox live. They work very well together. Most ISP's will only allow one active device at a time. When you switch between you cable modem and your Xbox you need to use a pen and press the reset button on the arris every single time you switch.
Jun 22, 2008 | Arris Touchstone 450a (CM450) Modem
Arris Wbm760a Touchstone Docsis 3.0 Cable Modem Logo
95 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
