Question about Sony 32IN TV Stand Designed for Model KV-32FS120
Sony tv die we niet kunnen opstarten springt aan en terug uit wel
Sony kv-28fq86B 10 JAAR OUD ONGEVEER TRINITRON EERSTE 10 SEC WEL GELUID DAN NIETS 220-240V ROOD LICHTJE RECHTS ONDERAAN PINKT SERIE 4004920
SOURCE: Sony FD Trinitron WEGA KV 32FS120
My Sony KV-32FS120 won't power up, LED blinks four times, replaced the Vertical Deflection Booster (IC561), still dead.
Posted on Mar 26, 2008
SOURCE: sony trinitron KV-30HS420 HDMI
Yes. As long as your PC has an HDMI port as well (or at least a DVI port and a DVI-to-HMDI converter dongle).
Posted on Sep 07, 2008
  • 586 Answers
SOURCE: Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Posted on Nov 19, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
SOURCE: I want to adjust my LG remote control to my Sony tv
I found the DVD LG DVS-8575N manual in spanish on http://safemanuals.com/user-guide-instructions-owner-manual/LG/DVS-8575N-_S
To set a Sony TV just press at the same time POWER TV and number 8 or 9
Scherm start op daarna valt het beeld weg.Als de aan en uit knop ingedrukt hou komt het beeld weer even terug en verdwijnt dan weer
Kijk of het scherm wel op de goede input staat.
Probeer anders een ander scherm om te kijken of het niet aan de PC ligt.
Anders misschien in het menu van het scherm kijken.
Sucses!
Jun 03, 2011 | Acer AL2017 20" LCD Monitor
Tijdens rijden ging A.B.S.knipperen , motor uit gezet , daana wilde hij niet meer starten geen stroom aan duwen starten hij ,en terug gereden ,accu door gemeten was maar net 9v nieuwe accu gekocht hier...
Hi, S_schweig mooie novelle de volgende is een uitgebreide laadsysteem test die is gegarandeerd de vondst probleem met uw systeem.
1. Accu Test: De batterij moet in een volledig opgeladen en de belasting getest om de juiste lezingen te verzekeren, moeten aansluitingen schoon en strak te zijn. Als u niet werkt met een volledig opgeladen en functionele batterij, zullen alle andere spanningstesten onjuist zijn. Staande batterij De spanning moet 12,5-13,2 DCV zijn.
2. Charging System Voltage Test: Start motorfiets, het meten van DC volt over de accupolen u een lezing van ongeveer 13,2-15 DC Volt zou moeten hebben.
3. Aansluitingen / Draad: Controleer de regelaar / stator plug, en de batterij voor aansluiting / corrosie. Als alles lijkt in orde zijn, ga dan naar nummer 4 hieronder om te bepalen of er een defect onderdeel.
4. Stator Checks / Rotor Check: elk van de volgende tests isoleert de stator en rotor. Als AC Output test mislukt en Resistance controleren, en de stator IB Test Pass dan Rotor in gebreke is gebleven (Trek Primary covers en controleer rotor op beschadigingen).
5. AC Output Check:
Trek de regelaar stekker uit de stator
Start motor en verander voltmeter AC volt.
Probe beide stator draden met uw meter lood.
De motor moet worden blussen van ongeveer 18-20 ACV per 1.000 rpm. Reading zal vari?ren afhankelijk van het systeem, controleer service manual specificatie
Generic Specs:
22 amp produceert ongeveer 19-26 VAC per 1000 rpm
32 amp produceert ongeveer 16-20 VAC per 1000 rpm
45 amp produceert ongeveer 19-26 VAC per 1000 rpm
Statorweerstand Check:
Schakel uw multimeter Ohm x 1 schaal.
Probe elke stator draden met meter leidingen en controleer weerstand op de meter.
Weerstand moet in het bereik van 0,1-0,5 Ohm. Reading zal vari?ren afhankelijk van het systeem, controleer service handleiding voor de specificatie
Generic Specs:
22 amp produceert ongeveer 0,2 tot 0,4 ohm
32 amp produceert ongeveer 0,1 tot 0,2 ohm
45 amp produceert ongeveer 0,1 tot 0,2 ohm
Stator IB-test of Ground Check:
Probe elke stator kabel met de positieve draad op de multimeter en negatieve aarde.
Er mag geen continu?teit aan de grond aan beide draad.
Als er continu?teit is uw stator grond is kortgesloten naar aarde.
5. Regulator Test: elk van de volgende tests isoleert de toezichthouder alleen, dus als een van deze tests mislukt, de regelaar een fout heeft begaan.
Het identificeren van draden:
Batterij opladen Lead Wire gaande van regulator om de batterij positief.
AC-uitgang leads- draden uit de stator aan de toezichthouder.
Grond- Wire van Regulator naar aarde of regulator kan worden geaard via de fysieke bouten chassis.
Regulator grondtestartikelen: Controleer de regulatorlichaam geaard of aardingskabel stevig bevestigd aan een goede grond (moet dit controleren door het controleren van de continu?teit van regelaarlichaam tot chassisaarde).
Fwd / Reverse Bias Test / Diode Test: Deze controle is het testen van de Diode functie om ervoor te zorgen zij regels stelt voor de AC-stroom voor de stator in DC Current.
Schakel multimeter naar Diode Scale.
Plaats uw multimeter positieve draad op elke AC-uitgang draad.
Plaats uw multimeter negatief lood over de batterijlading draad.
De meter moet spanning meestal gelezen rond 0,5 volt.
Vervolgens schakelt u de multimeter leads zetten de negatieve draad aan de uitgang draden AC en de positieve draad over de batterijlading Wire.
De meting moet oneindig zijn.
Met de meter op dezelfde instelling, plaats je multimeter positieve draad rond de regulator aarddraad of de regelaar rechtstreeks en plaats de meter negatieve draad op de AC uitgangsleidingen.
Vervolgens schakelt u de multimeter leads zetten de negatieve draad op de regelaar grond en de positieve draad aan de uitgang draden AC.
Let op: Hieronder staat een tabel met de metingen te laten zien:
Positieve Lead Negatieve Lead Reading
AC uitgang 1 batterijlading voorsprong Voltage
AC uitgang 2 batterijlading Lead Voltage
Acculading lead AC uitgang 1 ?
Acculading lead AC uitgang 2 ?
Ground AC uitgang 1 Voltage
Ground AC uitgang 2 Voltage
AC uitgang 1 Ground ?
AC uitgang 2 Ground ?
Voor meer informatie over uw probleem en waardevolle "FREE" downloads die je nodig hebt, klik dan op de blauwe links hieronder. Veel succes en hebben een prachtige dag.
http://www.st-owners.com/forums/showthread.php?111722-ST1100-Charging-problems
1991 Honda ST1100 charging system problems 28a alt
Honda ST1100 Pan European Service and Repair Manual av Matthew Coombs Bok
http://www.partsfish.com/page/oem-parts-for-honda
Honda Pan European ST1100 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 29, 2017 | Honda ST 1100 Pan European (cbs-abs met...
Ik heb een samsung gt b3210 ik krijg mijn gsm niet open het valt telkens uit als ik het aanzet vraagt soms pin code achteraf valt het terug uit wat kan het probleem zijn met laden heb ik geen problemen...
Dat had ik ook maar anders.. weet niet of het helpt maar zit er een geheugen kaart in .. bij mij zat er wel eens in,, die was blijkbaar stuk , en me mobiel begon te koken en laade niet meer, ik heb geheugen kaart er uit gehaalt en nou doet ie het weer:D maar ik denk niet dat het helpt
Mar 07, 2011 | Samsung Cell Phones
Een dikke zwarte streep op de achterkant van het papier, bij eerste afdruk na opstarten van printer
Mijn 4 jaar oude Canon MP500 begon ook een brede zwarte streep te trekken aan de onderkant van het papier. Dat gebeurde na iedere reiniging van de koppen, de eerste paar velletjes kregen een zwarte streep en daarna was het meestal goed totdat de printer zijn koppen weer reinigde.
Bij het reinigen van de koppen wordt met een soort pompje wat inkt door de kop gezogen. Deze inkt wordt via een slangetje afgevoerd naar de ruimte tussen de bovenste plaat en de bodemplaat van de printer. Een groot deel van de bodem van de printer is gevuld met een soort vilt dat de inkt kan opnemen. Zolang het vilt inkt opneemt is er niets aan de hand, maar bij mij was het vilt rondom de uitstroomopening van het slangetje helemaal verzadigd met ingedroogde inkt. Daardoor kon nieuw aangevoerde inkt alleen maar omhoog tot aan een aandrukrol voor het papier. Dit aandrukrolletje bracht de inkt keurig over op de onderkant van het papier.
De oplossing is de printer uitelkaar halen en de overtollige inkt in het binnenste verwijderen. Dat is een vies werkje waar je echt even voor moet gaan zitten, en als je niet handig bent kun je er beter niet aan beginnen.
Trek alle kabels (vooral de 230V) uit de printer en zet hem op een goed toegankelijke plek waar je een dikke laag kranten op hebt uitgespreid. Eerst verwijder je de zijkanten door 2x2 schroeven los te draaien. Het lipje aan de voorkant moet je vervolgens (een beetje) naar voren trekken zodat het los komt. Aan de achterkant is een schroevendraaier in de naad handig, de zijkant komt dan los en kan naar beneden toe worden verwijderd.
De veer van de scanunit krijg je los door aan de voorkant twee lipjes opzij te buigen. De scanunit is nu vrij, maar is nog verbonden met de printer met 3 massadraden, een connector met 4 draden en twee flatcables. Die moet je met moed en beleid loshalen, en noteer even wat waar zit. De draden loshalen is geen probleem, met de flatcables moet je heel voorzichtig zijn, zo dicht mogelijk bij het connectortje vastpakken (daar is de flatcable iets dikker) en voorzichtig er uit trekken.
Nu kun je de kap loshalen (4 schroeven).
Dan kan het printermechaniek worden verwijderd van de bodemplaat door 4 schroefjes te verwijderen. Om bij de vierde te komen moet je de voeding loshalen: een connectortje bovenop losmaken en aan de onderkant twee lipjes opzij buigen. De voeding komt dan naar onderen uit de printer.
Maak alles enigszins schoon, verwijder in ieder geval alle dikke lagen inkt. Dan weer alles in elkaar zetten. Als je geen magnetische schroevendraaier hebt, kun je ook tijdelijk een dun draadje om de schroefjes wikkelen om ze op de goede plek te krijgen. Denk er aan om de schroefjes die in kunststof worden gedraaid, eerst even de verkeerde kant op te draaien. Je voelt dan een klein klikje waardoor je er zeker van bent dat de schroef precies in de oude draad komt. Doe je dat niet, dan heb je een grote kans dat je het schroefje dol draait. De flatcables hebben maar aan een zijde contactjes, dus steek ze juist om in het connectortje.
Als alles weer in elkaar zit doe je een schietgebedje , sluit de printer aan en testen maar...
Feb 07, 2011 | Canon Pixma MP500 All-In-One InkJet...
Waste ink near full
I'm having the same problem. Lots of solution for resetting the printer, but none of them helping me to lead me to the absorber itself inside the printer. It seems to be a lot of work and disassembling half of the printer! Looking on internet I haven't found any answer yet.
As I am living in The Nehterlands I'm looking for solutions in Dutch. One solutions discribes disassembling another Canon printer. This could possibly help. I'll paste the text below. It's dutch, so you'll have to translate it.
Wishing you succes with this matter!
Dutch text:
Wat te doen bij de melding 'Afvalinkt bijna vol'?
Onderstaand verhaal geldt voor de Canon SmartBase MPC200; voor andere Canon
printers geldt ongeveer hetzelfde, met uitzondering van de reset-procedure (zie
hieronder).
Oorzaak
Onderin de printer bevindt zich een langwerpig, dik vloeiblad (een soort spons van
vilt). De overtollige inkt, bijv. de inkt die gebruikt wordt bij het reinigen van de
koppen, wordt afgevoerd naar deze spons. Als deze spons bijna verzadigd is,
verschijnt bovenstaande melding. Dat is ook nodig, want als je gewoon door zou
kunnen gaan, zou de spons geen inkt meer opnemen, en op een bepaald moment zou
je merken, dat de printer zou gaan 'lekken'. Geloof me, dat wil je niet meemaken.
Printerinkt is gemeen spul!
Canon
Het lastige is alleen, dat Canon nogal moeilijk doet over deze melding. Zij hebben
maar één oplossing: opsturen en het probleem door hen laten verhelpen. Kosten: ruim
€ 100,-!!! Toen ik dat van de telefonische helpdesk hoorde, reageerde ik met: "Dan
kan ik beter een nieuwe printer kopen!" De telefoniste was dat eigenlijk wel met mee
eens.
Zoeken
Vervolgens ben ik gaan zoeken op het internet. Wat je daar niet kunt vinden, bestaat
niet, tenslotte... Toen merkte ik al snel dat ik niet de enige was met dit probleem.
Iedere eigenaar van een Canon-printer krijgt er na verloop van tijd mee te maken.
Helaas was er geen kant-en-klare oplossing voor mijn printer, maar door de
beschrijving bij andere printers kreeg ik wel een idee over de oorzaak van het
probleem en wat ik eraan zou kunnen doen.
Oplossing
Over de oorzaak heb ik al geschreven. Over de oplossing gaat het nu. Die gaat in twee
stappen:
1. De vilten spons schoonmaken.
2. De printer resetten.
Dit is een vies werkje. Doe een schort om en gebruik huishoudhandschoenen! Inkt in
je kleren gaat er niet meer uit en op je handen duurt het een hele tijd!
De spons ligt helemaal op de bodemplaat onderin de printer. Je moet dus een beetje
handigheid hebben en niet bang zijn om een schroevendraaier te gebruiken.
Schroef eerst de beide zijkanten van de printer los. Die zitten elk met twee schroeven
vast (één aan de voorkant en één aan de achterkant).
Verwijder dan het toppaneel (met de scanplaat). Die zit vast met twee schroeven aan
de achterkant en drie aan de voorkant (deze drie zitten aan de onderkant van het
bedieningspaneel). Let op: zodra je het toppaneel verwijdert, merk je dat die op drie
plekken vastzit. Op één plek met een schroef (gewoon losdraaien) en op twee plekken
aan de elektronica. Trek die twee punten voorzichtig los. Je kunt het toppaneel nu
opzij leggen.
Dan moet je de printplaat verwijderen. Maak eerst alle 'draden' voorzichtig los. Kijk
goed hoe het vast zat, om het later weer te kunnen bevestigen. Maak dan de printplaat
los (4 schroeven). Verwijder daarna ook de metalen plaat, waarop de printplaat vast
zat.
Je bent er nu bijna. Het bovenste deel van de kast (voor zover die er nu nog staat) is
op de vier hoeken met schroeven bevestigd op het onderste deel van de kast. Je moet
misschien wel even zoeken, want ze zitten diep weggezakt. Schroef ze los.
De bovenkant en de onderkant zijn nu los van elkaar, maar nog wel met draden en
elektronica aan elkaar verbonden. Maak die verbinding niet los, dat is niet nodig.
Doe nu het schort om en de handschoenen aan!!
Je kunt nu bij de bodem van de kast komen. Daar zie je de spons, die zwart is van de
afvalinkt. Kijk eerst hoe de spons erin zit, voordat je die eruit haalt.
Maak de spons voorzichtig schoon. Niet wringen en zo, alleen uitspoelen en eventueel
induwen om de inkt en het water eruit te halen. Ga een flinke poos door, totdat er
alleen nog schoon water uit de spons komt.
Hang de spons een paar uur te drogen in de zon. Gebruik daarna een föhn om ook het
laatste beetje vocht eruit te halen, zodat de spons weer kurkdroog op zijn plek gelegd
kan worden.
Zet de zaak nu weer in elkaar. (Als je het net zo doet als ik, houd je twee schroefjes
over, maar mijn printer doet het nog steeds prima. )
1a. Niet schoonmaken maar bestellen...
Sinds kort weet ik dat je de spons ook kunt bestellen. Dat scheelt een boel pruts- en
schoonmaakwerk.
Je kunt de vilten spons, die uit 2 onderdelen bestaat, bestellen bij ETB (Electronic
Trading Benelux).
Bel naar 0165-850500 en bestel de volgende artikelen:
HC1-0795-000
QA4-0213-000
Toen ik ze bestelde (in maart 2006) waren de kosten voor deze 2 onderdelen samen
maar E 1,04!!
Deze prijs was wel exclusief btw en verzendkosten. Maar omdat ik het samen met
andere producten bestelde, had ik daar geen last van.
Als je nu de printer weer aanzet, kun je merken hoe dom het apparaat is. Hij heeft niet
in de gaten dat de spons weer schoon en leeg is. Dat moet hem nog verteld worden.
Op het internet kon ik daar geen geschikte procedure voor vinden, dus ben ik maar zo
brutaal geweest om Canon op te bellen. Eerst deden ze afwerend (ik moest de printer
opsturen), maar toen ik vertelde, dat ik het grootste deel van het werk zelf al gedaan
had, kreeg ik een technicus aan de lijn, die me stapsgewijs uitlegde wat ik moest doen.
De stappen laat ik hieronder volgen:
1. Zet de printer aan
2. Druk op de (langwerpige) menuknop
3. Druk op de meest linkse ronde knop (Copy)
4. Druk op de ronde knop rechts daarvan (Scan)
5. Druk twee keer op de meest linkse ronde knop (Copy)
6. Druk op het min-symbool (links van OK); het scherm zegt nu: 'Test mode'
7. Druk op OK
8. Blader met het plus-symbool (rechts van OK) tot het scherm zegt: '#8 Printer
Test'.
9. Druk op OK
10. In het scherm staat nu: '8: Printer Test' en daaronder: '- 8 - 2 +'
11. Druk 1x op het plus-symbool; in het scherm staat dan: '- 8 - 3 +'
12. Druk op OK
13. In het scherm staat nu: '[0]: Ink Count'
14. Druk op OK
15. Druk op de knipperende oranje knop om die uit te laten gaan.
16. Mogelijk werkt dat niet. Trek dan de stekker uit het stopcontact.
17. Wacht even. Doe de printer weer aan.
18. Als het goed is, ben je nu bevrijd van de irritante melding over afvalinkt.
Succes!!
Nov 04, 2010 | Canon PIXMA MP750 All-In-One InkJet...
Ik heb een acer 7520 aspire bij het opstarten gaat hij maar door met op starten als ik op escape druk komen de woorden TPM werkt niet meer.
U hebt waarschijnlijk te updaten BIOS (Basic Input / Output System) met de nieuwste firmware beschikbaar op de website van de fabrikant. Ook in staat stellen TPM (Trusted Platform Module) in het BIOS handmatig.
LET OP: Het wijzigen van BIOS / Complementary Metal Oxide Semiconductor (CMOS)-instellingen verkeerd kan ernstige problemen veroorzaken die uw computer kunnen voorkomen kunnen opstarten. Microsoft kan niet garanderen dat problemen die voortkomen uit het configureren van het BIOS / CMOS-instellingen kunnen worden opgelost. Wijzigingen van de instellingen zijn op eigen risico.
Oct 04, 2010 | Acer Aspire 7520-5185 Laptop
Lens van mijn Ricoh Caplio R 6 gaat niet meer in of uit
Hoi Van de caplio R6 zijn geen onderdelen leverbaar, de camer moet worden aangeboden aan Ricoh Nederland ze zullen je een website aangeven waar je de gegevens kunt opzetten en daarna pas de camera kan opsturen aan hun servicecenter
Groet,
Rob Rotronica
Apr 15, 2009 | Ricoh Caplio R6 Digital Camera
Machine wil niet starten
I understand your problem but need the make and Model # to help you with the programming problem
Apr 07, 2008 | Washing Machines
Televison & Video Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
