Question about Hampton Bay Ceiling Fan Wall Control 9050H
I just purchased a hampton bay remote control kit model 191-691. I have installed the wiring from the house power to the receiver and from the receiver to the fan and light. I set the dip switches in the remote and receiver, but the fan or light works. I hardwired the fan to house power and the fan will function. Any suggestions?
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
SOURCE: UC7078T Remote
try opening remote control
vary (4) "dip" switch(s) positions
when I opened mine-all four were up
I moved the 2nd switch down and it worked!
Posted on Oct 26, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
  • 87 Answers
SOURCE: my hampton bay remote control fan doesn't work for
Your recever in the fan is bad if this is a new unit take it back to the store and they will give you a replacement, I have seen this problem on this model before.
Posted on Oct 03, 2009
SOURCE: cannot set remote code for fan/light(dip switch)
BUILT IN RECEIVER IS NOT WORKING WITH REMOTE. THE DIP SWITCHES ARE MATCHING. iS THERE A REMOTE TO BUY OR A FIX FOR THIS
Posted on May 21, 2011
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
Hampton bay fan model 761 567 running faster on
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The receiver is located in the upper portion of the housing for the fan motor. Look for a semi-circular black control box (usually manufactured by Rhine)
Jun 05, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Fan doesn't work after nearby lightning strike
Your issue is most likely a faulty speed control, which presumably was destroyed by a power surge. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The fan unit itself is manufactured by AirCool 800-896-4908
Unfortunately the Brookdale fans with a Rhine 7058 series controller have a separate circuit wire for each speed. Rewiring this to use a conventional fan receiver that uses a single wire to control each speed is not easily achieved. Your best bet is to order a new remote receiver of the proper type.
Jun 04, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I HAVE A HAMPTON BAY MODEL AC-418 CEILING FAN. IT
May 10, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
My ceiling fan does not work.It is a Hampton Bay. There is power.
Hampton Bay receivers are notorious for taking a dump, replace the remote. If you're just adding the remote... There will be 6 wires on the remote, a set of two (white and black) a set of three (white black red or blue) and a single small wire by itself. The single wire by itself is the Antenna wire, do not wire it to anything, or it will fry the board in the receiver.
Mar 31, 2010 | Hampton Bay 52 In.Carriage House II in...
Cant find reciever on my hampton bay fan
Hello, there are many Hampton Bay fans sold where the box states REMOTE READY but you have to purchase the remote and the receiver. Check to see if your fan is remote ready or did it actually come with a remote and a receiver. Normally the receiver will be in the fan housing.
Sep 03, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton bay ceiling fan (7030T) remote does not work.
This symptom is usually caused by either a bad receiver or bad transmitter. Install a new remote system (receiver & transmitter).
Apr 20, 2009 | Hampton Bay 52 In. White Redington...
Hampton bay fan with remot problem
You can try the universal receiver. The white, black, and green wires are the house wires. The receiver must match to these on one side. The wires on the other side go to the fan/lights. It is possible that one of these has come loose. If you try the universal, make sure the dip switches are in the same positions on both.
Or,
Take the fan down, and remove the receiver completely, from house wires and fan. (Make sure the breaker is off first!) Then wire the fan directly to the house wires. The blue wire on the fan is for lights. Wire it with the black wire in the same wire nut.
I'm assuming you have a wall switch that powers the wires coming from the ceiling.
By the way, I have never seen anyone control two fans with lights with one receiver. Usually each fan has its on.
Feb 09, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Can a remote control be installed on the Huntington III?
Yes you can operate them with two styles of remotes: either the remote wall switch, or a hand held remote. Both require the receiver to be mounted above the top of the fan in the base it is wired to. The receiver has wires on both sides; the one side wires directly to the house wires, and the other goes to the fan and light. They are both sold at Home Depot and Lowes. The ones at Home Depot also include the set made by the fan manufacturer.
Feb 01, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Ceiling Fan Wall Control 9050H Logo
32 people viewed this question
Top Hampton Bay Televison & Video Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Are you a Hampton Bay Televison and Video Expert? Answer questions, earn points and help others
