Question about HP Hewlett Packard LaserJet 3000dn Printer
Have a hp8400 where is the on off switch can you help
  • 43 Answers
Should be on the right hand side of the front bezel middleways up, right above the USB ports.
Posted on Jan 03, 2009
Help - 1 Way 2 gang switch - ie: two sets of lights in same room, 1 light switch with two switches on it, each switching on 1 set of lights. I have 2 brown wires, 3 blue wires, and a short length of free...
I can probably help.
BUT, what voltage are you working with. It sounds like 230V european wire colors?
Now also. Do you have two separate light switches in same box (which is called 2-gang)? Or do you have a double switch, which is two switches on one device?
Add a comment, and include as much detail as possible about the switch, voltage, and number and color of screws on each switch.
Here is a start-point using 120Volt and US wire colors:
http://waterheatertimer.org/How-to-wire-switches.html#double
The difference between US and European, is that European has two hot wires, while US has hot and neutral wires. Otherwise both systems require two wires to complete circuit.
Sep 26, 2012 | Gb Electrical GSW-117 Toggle Switch
My motorized seat (passenger) doesn't go fully forward, it does go fully back. It seems to stick, and makes clicking noises. It sounds like something is stuck and preventing the forward motion. ...
The most common cause of the problem you are having is with the switch itself.
The switch needs to be removed and cleaned.This helps in some cases, but if its not helping, then switch has to be replaced.The cost of switch is approx $25.You will have to get it from dealer or from local auto part stores. But first try cleaning the switch.Most probably that will help.In cleaning switch.You will have to remove the switch out, disconnect its wires, then clean both wires and switch contacts with cleaner and then reconnect. -------- For instructions and diagrams to disassemble and remove switch on your Lincoln continental , please click the link below:--- http://technoanswers.blogspot.com/2011/06/passenger-motorized-seat-switch.html ------------- This should help.Thanks.Helpmech.
Jun 10, 2011 | 2002 Lincoln Continental
Where does the inbalence switch go
Sorry to read about your problem, I hope this helps you out.
the best way to find it. is to look for the door lock switch.
the door lock switch goes to a large connector on one end, and the other side of the switch goes to a line connector 3 wires in and 2 out. follow the 2 wires you will find 3 switches to this line, the last switch or the first switch on the return..like a little loop. is the unbalance switch the other 2 are displacement switches.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Washing Machines
The button on the jacuzzi 536 RH will not start the motor when pushed. The motor is tested to work however.
The unit uses a air switch, you should see a plastic tube going from the switch to the power switch.
remove the tube at the power switch end, and then push the switch, you should feel air, come out.
If you feel air, then you must have a defective power switch.
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Jacuzzi R100-959 Cetra 536 RH R100...
Hampton Bay Antigua Fan comes with 2 pull chain switch. Fan switch is working. The light does not turn on when we pull its chain switch. Is that because of switch? and where to buy new one? KTE switch is...
Home Depot has them. Hampton Bay is a Home Depot product, made by Home Depot
3 Thumbs - Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Hampton Bay Dryers
Im installing a two way switch and have one hot lead. going crazy please help
If I understand you correctly, your hot lead should attach to 1 switch and a common wire goes from that switch to the other switch. Here's a link to a good explanation of 2 way switch wiring. Essentially you run power to one switch, and that same switch sends power via 1 of 2 other wires to the second switch. The light (or other device) is then connected to the second switch. Hopefully the diagrams in the following link will help you. In any case you need 3 wires at each switch. Good luck!
http://2wayswitch.com/2-way-switch-wiring-diagram/
Mar 10, 2010 | Leviton R03-5634-A Two Single-pole...
Can not get to fan switch help please.
is it the rad fan switch or the heater fan switch ?
Aug 06, 2008 | 2000 Ford Focus
A nokia N90s series.
My phone switches itself off when in pouch, even though the key lock is on.
Also the phone seems very slow to access menus????
Help
Oct 18, 2007 | Cell Phones
Hotpoint EW81 Dual Oven Cooker
Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
New switch is a Diamond H - 48ER101C1P.
Numbers on switch are S1,P2,2,P1,4,S2
At the moment I have no cooker - help.
Sep 08, 2007 | Ovens
HP Hewlett Packard LaserJet 3000dn Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
