Question about Systemax Arrival (036063) PC Desktop
Syx-d865glc front header - Systemax Arrival (036063) PC Desktop
Hi i have a Systemax Tiger (SYXS-DC-1000) PC Desktop can you tell me what memory type it takes thanks
Install and run this http://www.piriform.com/speccy it will tell you the entire hardware configuration.
Aug 25, 2011 | Systemax Tiger (SYXS-DC-1000) PC Desktop
Mother board power switch
I don't know what you are asking for exactly, so I'll through out possibilities.
A) The Power On switch located inside the plastic Power On button assembly is a Momentary Contact Switch.
It is an ATX power on switch.
This is a generic example of a Power On switch that fits Many models,
http://www.amazon.com/Power-Motherboard-Cable-Switch-Button/dp/B00345WH4A/ref=pd_cp_e_2
B) The plastic front of the computer is a Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel go to, is the Front Panel header.
Intel Support > Intel D865GLC motherboard > Product Guide,
To find out if the problem is the Power On switch, or the Power Supply, perform the simple test using a jumper wire.
If you do not know how to perform this test, and wish to, post in a Comment.
Regards,
joecoolvette
Jul 09, 2011 | Intel D865GLCLK Motherboard
Need ethernet controller driver - d865GLC motherboard - MPC345
You can download the LAN driver for the motherboard D865GLC from the website given below:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=950&DwnldID=8659&lang=eng
Regards
May 24, 2010 | Intel D865GLC Motherboard
Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Apr 01, 2009 | Dell Dimension 4600 PC Desktop
Intel d865 glc mother board sound card is not woking
you first verify that front audio pin jumper place in motherboard
if you are not using front panel audio so insert jumper in front side audio attachment see manual for more detail
Feb 02, 2009 | Intel D865GLC Motherboard
Front panel connection to board
all these should be marked on the board and on the connectors, you may need a magnifyer, if not marked, try and get a diagram from the company that made the board.(should be in owners manual)
Jan 03, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
I bought a mother board from a swap meet but it didnt come with the wiring up diagram and im lost as to how to wire it up only for the power reset etc.. not sure which way they plug into i think i have...
Hi kjstenny, not sure where you saw the board E210882. This is not a valid Intel model number. The Intel D865GLC is a valid model number & you can download the manual for this at the link below:
http://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
Main Intel link for D865GLC:
http://support.intel.com/support/motherboards/desktop/D865GLC/LC_manual.htm
MB layout page 14 & 15. Than see page 13 block D, J9J1 Front panel pins. Page 43 for jumper connections.
Intel D865PCD (Matched). Front panel, page 34 & 35. Download manual at this link:
http://download.intel.com/support/motherboards/desktop/d865pcd/sb/cdenglish.pdf
Main link: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1671&lang=eng
Intel D865PCK - (No Match). (Or no longer listed).
D865PE50 - (No Match). (Or no longer listed).
The most common wire color for each 2-pin connector will be negative, including the color black.
Good luck kjstenny!
Still need help, just post your question.
Mike
Dec 03, 2008 | ASUS A7S333 Motherboard
Systemax Arrival (036063) PC Desktop Logo
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
