That 52 inch rca hdtv problem
What is the fly back that you speak of? where to i buy another fuse for this tv set? I have the same problem right now and im going to try to fix it by my self. Can you give me some pointers and a walk-through maybe.? You can even email me at artic429@hotmail.com.
  • artic429 Jan 03, 2009
    Ok i have found the three fuses that you are talking about and i have noticed that the caps pull off of the fuses to expose the actual fuse itself. Does that part actually pull out too or is that soldered in place?
    I have found the 3 fuses and the one in the middle... the cap reads T400mA with a 396 on it. It also has FL231 stamped into the board next to its slot. The cap comes off of the fuse, does the fuse itself also pull out of its slot or is it soldered into place? And where can i buy one of these fuses?
3 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: 52 inch rca hdtv projection
Yes, I sure Can how much money can you send am Broke? First board on bottom left is Deflection board / Board next to it on right side is SSB board has turners on it. OK go to menu then setup look for convergence if its not there/ then you have open Fuse FL231 ON right side of FBT flyback transfomer there is 3 in a roll small square brown looking caps but they are fuses. Will be right in front of you.on board. FBT is gray/black has 2 wires coming out from it. red'/bl
Posted on Jan 08, 2009
SOURCE: my 52 inch rca hdtv comes on but it looks like the
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
Posted on Jul 01, 2010
I can't find auto converge choice in menu of rca 52" rear projection tv.model # R 52 WH 74.
You have 3 pico fuses by your fly-back transformer. One of them blew that controls your convergence circuit. Your TV now thinks that it is a Basic CRT set with 1 tube. Find the bad fuse and replace with a 1/2 amp pico fuse, and re-solder all the pins of your fly-back transformer. Your menu should have the convergence option again.
Apr 27, 2011 | RCA HD52W59 HDTV Projection Television
Convergance is off
I have an RCA 52” HDTV Model R52WM24 the other day it developed a convergence problem (The picture took on a 3D effect and it the screen had an hour glass type of shape)
This appears to be a common problem or a pattern failure.
I wanted to confirm that I did find the fuse p/n FL231 to be blown.
I think it said the RCA part # is 259213 and it is a 400 ma, 125V fuse, Looks like a square capacitor by the fly back xfmr.
I bought a generic part from Digi Key and it seems to be the identical replacement part to the fuse that was in the circuit.
The Digi-Key part is part # WK4440BK-ND (99 CENTS EACH).
THIS IS A 125V, 400 MA ( 0.4 A FUSE). Digi Key PHONE # IS 1-800-344-4539
I am watching the TV right now for last 3 hours and it seems to be a good fix.
The fly back transformer solder connections looked good but it is recommended to re solder these part ( so I did).
Good luck
Dec 27, 2009 | RCA R52WM24 52" HDTV Projection Television
Double vision on the 52 inch tv in red and the top sags down a couple of inches like a smiley face smile
Resolder the connections on the high voltage transformer. There are 3 fuses mounted to the right of this transformer. They look like 3 brown boxes. Replace the center one if its open. ABOUT 1/2 AMP pc mount fuse pico fuse will do. Common failur eon this tv.
Nov 01, 2009 | RCA D52W23 52" HDTV CRT TV
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Jan 03, 2009 | RCA R52WH73 Projection Television
I have a 52 inch RCA Screen TV, there was a thunder storm and it
Check your AC fuse first it will be on board that has your cord pluged into it, if its ok ck odd looking fuses next to your tuner if it is opened set will not come on.
Dec 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the fly back fuses 3 of them
fuse in flyback. prehaps you mean the special fuses that are located next to flyback. the fuses are three brown rectangular brown or tan looking to the right of flyback. the one in the middle is f231 the one to look at if you have convergence problem.
Nov 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV all blured and screen concaved on all sides
Look,followsteps and you wil repair this set. Disconnect main board ( fly back), take care about connectors. Under fly back you will see loose connections, resolder and that's it Am sure this is your solutions.You need do this soon, because fuse will be blown if keep blink picture, Thank you
Aug 08, 2008 | RCA P52926 52" Rear Projection Television
RCA HDTV Fuse location
There are 3 small rectangles that are on the right side of the flyback, they are micro fuses FL231 is the center one. I am not sure if radio shack has them, may have to order from RCA
Jun 30, 2008 | RCA R52WM24 52" HDTV Projection Television
Televison & Video Logo
280 people viewed this question
Top Televison & Video Experts
