Have aricho aficio mp 3010 am getting a service code sc546 any ideas as to what this is? have tried to turn of for 30 mins and on again thanks a lot.
5 Suggested Answers
SOURCE: aficio 1018d
sc 302
Posted on Jul 05, 2008
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
M2Tech1
  • 313 Answers
SOURCE: I can't get my RICOH Aficio MP 3010 to scan to a
first have you installed the scan driver? if so hopw are you connected to teh computer if it is by usb this is not going to work as the scan function needs an ip address to go through so you will have to connect via a network cable and then get the ip address of the machine from teh printer config page in user tools
Posted on Aug 27, 2009
goodgold
  • 389 Answers
SOURCE: I have a Ricoh Aficio 150 PCL and I have an error
SC546Fusing ready temperature malfunction
Look sanity of the block of the fastening, fuser
Check join , замерьте resistance termo lamp, termistor and termo fuse.
Posted on Sep 28, 2009
SOURCE: Ricoh Aficio MP 2000Le Machine error code SC 546 appears.
"Unstable Fusing Temperature" Chang Fusing Thermistor.
Posted on Jan 07, 2013
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Error code sc546
sc546 is a fuser ready temp problem.
it requires a reset procedure: enter SP mode.touch Copy SP..touch SP DIRECT then press 7807# on the keypad then execute...turn power off and then back on
Jan 29, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh aficio mp3010 ,i will change n?ew toner then againe coming add toner mesege,why
Have you replaced the developer yet???? It could also be the unit that the toner bottle goes into. There is a paddle wheel inside of it that move the toner and it may have broken up... Good Luck
Jan 15, 2013 | Ricoh AFICIO MP 3010 COPIER. REFURBISHED....
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
How do I clear error SC546 on a Ricoh Aficio 2045
SC546 A Fusing ready temperature unstable The fusing temperature is fluctuating. Thermistor connection loose Fusing unit connector loose you have to go into service mode and reset it
Apr 27, 2010 | Ricoh Aficio 450 Copier
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
RICOH 2045E COPIER WHAT DOES ERROR CODE SD546 MEAN?
Hello!
Follow the next steps carefully and the error code SC546 will disappear.
Press the following keys by this order:
1. press the (yellow key) [Clear]
2. press then the numbers on the numbers key by order (1)-(0)-(7)
3. press the red key (cancel) [C] and hold it pressed for about 5 seconds.
4. on the screen will appear another menu different from the one
you are
familiarized it will write up in the left corner [service menu],
(if the service menu do not appear repeat the procedure again).
After this menu will appear turn off the machine from the red switch which is located somewhere in the middle of the machine and just by the left corner (the turn off switch-plug) wait for 10 seconds and turn back on the machine by the same switch-plug.
After this the error code SC546 should be disappear.
Please Answer does this was helpful for i to know does the problem has disappear or i should post some other information.
Regards
Jan 12, 2010 | Ricoh Aficio 450 Copier
Service code sc546 what do we need to do to fix this problem?
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
k24674
