Question about Sub-Zero Refrigerators
Fan on model 550 will not work when pressing switch
My Suzuki GS 550 Horn don't work.
CHECK FOR POWER AT HORN IF YOU HAVE POWER THE SWITCH IS THE GROUND.OR IF YOU GET POWER WHEN YOU PRESS THE SWITCH. IF YOU HAVE BOTH POWER AND GROUND WITH THE SWITCH PRESSED REPLACE HORN
Feb 22, 2013 | Suzuki Motorcycles
ON MY SUBZERO 550 MODEL, THE SECOND SWITCH ABOVE THE FRIDGE DOOR DOESN'T ACTIVATE THE FAN THAT IS CONNECTED TO IT. IS THIS THE FAN THAT BLOWS COLD AIR INTO THE FRIDGE OR IS IT A FAN FOR ANOTHER...
Hi again,
That fan is supposed to blow the air into the refrig. since ya bypassed the switch and the fan does not run i believe the fan is bad and it would need to be replaced .
The part number for that fan is 4200160
Now the bad news i have looked up on several online parts sites and they say the part is no longer available. While i usually recommend that you try to fix it yourself what you can do is call alocal service company and they could get a universal fan motor and match it to the exact application of your refrig.when trying to make a universal fan motor fit to a certain model its best that someone who is very familiar with it.
GENE
Sep 24, 2011 | Sub-Zero 650 / O Bottom Freezer...
What does the second switch about the door in the refrig control. we know one is for the light what is the other? we have a 550 sub zero
Typically the second switch is for the ice dispenser and fan,when the door is open the fan and the ice dispenser power is cut off via that second switch
GENE
I have a Sub-Zero Model 550 whose freezer does not get very cold even though the set to 10
set freezer for 0 deg and clean the coils on top . and make sure the fan up top is working . very important .. mm 550 are r12 and may be low or refergent . this is somthing you may need a service tec to ck but do the cleaning first and see how it works. mm
Sep 03, 2010 | Sub-Zero Bottom Freezer Refrigerator
I replaced the light switch on the subzero 550 and now the frig isn't staying cold. When door is open and I press the switch light goes off so light switch is working.
On sub Zero's this has been a common problem. Pressing with your finger to test isn't good enough. You have to test the switch function, by slowly closing the door to see if the DOOR turns off the lights.
There are so many lights in the food compartment producing so much heat that if the lights are on with the door closed, it will not cool.
When I run into this problem, which is common, I take a thin plastic shim
and tape it on the part of the door that hits the switch. 2" x 3" shim will
work well. If that solves the problem, I put a few drops of crazy glue on the shim and remove the tape a day later.
If the switch has 4 wires to it, the second 2 wires run the fan in the fresh food compartment. You can test that by pressing the switch and listening to see if you can hear the fan in the fresh food compartment start up.
Oct 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Engine size if 2.0L, 6 Cyl, 1997 model. It is overheating at low speed and at being idle. One guy had said that radiator fan is not getting power so something is wrong with the electric circuit. But this...
1. you're paying for their experience and knowledge.
2. you can fix it yourself if you research electrical circuits go buy a muti meter and spend some time.
if the fan has power to it when the engine is at operating temp. the fan is dead. if it doesn't have power check the fuse or relay that sends power to it. it that's ok check the thermostate switch that tell the fan to operate (jump the switch the fan should come on.
now whose going to pay me? lol :)
Jun 23, 2009 | 1997 Volkswagen Jetta
Panafax uf-550 message reads: file register full wait till file ready
Turn the machine off
Open the document feeder
Hold down the pointy switch by the small glass while turning the machine on until it beeps
Close the feeder
Scroll down to SHIPMENT SET
press set
press 2
set
Wait until the machine reinitializes.
Jan 29, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Refrigerators Logo
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
