Hoover F7205900 SteamVac V2 Wet/Dry Vacuum Logo
dannie grigg Posted on Oct 28, 2012
How do you take the valve off from the tank on a steam vac2?
Polti steam cleaner water empty light staying on
If the water empty light is staying on when the water tank is full in your Polti Pro95 steam cleaner, it could be due to a malfunctioning float valve or a faulty water level sensor.
Here are some steps you can take to troubleshoot the issue:
  1. Check the float valve: The float valve is responsible for regulating the water level in the steam cleaner. If it is stuck or malfunctioning, it could be causing the water empty light to stay on. To check the float valve, remove the water tank from the steam cleaner and inspect the valve for any signs of damage or blockages. If the valve is damaged or blocked, replace it.
  2. Check the water level sensor: The water level sensor is located inside the steam cleaner and is responsible for detecting the water level in the tank. If it is malfunctioning or faulty, it could be causing the water empty light to stay on. To check the water level sensor, you will need to disassemble the steam cleaner and inspect the sensor for any signs of damage or wear. If the sensor is damaged or worn out, replace it.
  3. Check the wiring: If the float valve and water level sensor are functioning properly, the issue may be with the wiring. Check the wiring between the sensor, float valve, and control board for any signs of damage or wear. If you notice any issues, repair or replace the wiring as needed.
If you are not comfortable performing these troubleshooting steps, it is recommended to take your Polti Pro95 steam cleaner to a certified repair technician for further diagnosis and repair.
Hoover agility steam vac F6210 solution tank repair
Hello! The valve assembly is not replaceable on the F6210. We recommend replacing the solution tank part number 90001091, can be purchased online or through a local service center. Hope this was helpful!
1helpful
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
How to disassemble the hoover steam vac2. the hole that the brushes snap into does not rotate so the brushes are not rotating
The hole the brush shaft goes into is the turbine that turns it. If it will not turn it is seized and should be replaced.
1helpful
My hoover steam vac is losing all the cleaner and water out of tank the trigger isn't stuck
You will need a resevoir. This is the valve that the solution tank sits on when put on the machine. If your exact part number is not available ask to look at another model series, you may get a different colo but you will have a working steam cleaner.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
My Hoover 97441-980 Dual Steam Vac won't hold detergent. The valve is bad. How can I get the old valve out so that I can replace it?
Just grab the valve stem with a pair of needle nose pliers and pull it out, then you can gently work out the outer valve with the pliers, and then remove the gasket. The older tanks tend to crack around the valve which may be the whole problem, but the good news is that the new replacement valves and tanks are much better.
2helpful
2answers
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
2helpful
Hoover steam vac
in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
Hoover Steam Vac V2, Model #F7430-900
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 • Vacuums
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
