Question about Gateway NV59C26u PC Notebook
Wierd issue with AC adapter and battery.
My laptop runs on just AC power, and just on battery power, but I cant use the adapter and battery at the same time, the power button, battery and charge indicator lights blink steady with the ac adapter and battery installed. The power light blinks blue, the battery light blinks orange the the ac input indicator blinks blue, and they are all in sync. I seen that Gateway had a bios update for a battery issue but i managed to boot into windows with the battery on, and as soon as I plug in the AC adapter the lights start blinking and it doesnt recognise that its plugged in which fails my efforts for the bios update. I did a teardown to check the motherboard and all connections seem fine. I have tried different AC adapters and different batteries as well. Doesnt work in Macbuntu either....I'm stumped, please help.
  • 13 Answers
SOURCE: Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Posted on Jul 01, 2008
tat4u
  • 520 Answers
SOURCE: Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Posted on Feb 05, 2009
  • 3940 Answers
SOURCE: Brand new battery & ac adapter not working on MX3702
If you've replaced both the battery and the ac adapter then the fault lies in the charging circuit of the motherboard and generally that is either a motherboard replacement or having the power connection on the motherboard by a service center, either way usually about $100
Posted on Dec 12, 2009
Geekman
  • 32281 Answers
SOURCE: No power. All power cords checked and tight. With
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Jan 06, 2010
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Posted on Jan 09, 2010
My cumpter t400 battery not detected what can be the cause
Lenovo Thinkpad T400 battery
its fully charged but computer cant find it .?
worth a try
Unplug AC adapter and Shutdown the system. Remove battery, Connect AC Adapter and Start windows.
look around device manager under the battery tab.
Shutdown, Remove AC Adapter, Install battery,
Reattach AC Adapter. Now, Power up and check.
check in settings and battery power etc
at worst
could turn out to be a mother board issue
Jun 14, 2016 | Computers & Internet
It wont turn on all it said is loding os image
An AC power adapter and a battery work together to serve as the power supply of a notebook computer. Whenever you connect a power adapter into a laptop's power port, it supplies enough power to the battery for you to boot the operating system, run programs and perform computing tasks.
1. Turn on the laptop. If it does not power on, the battery may need to be charged. Connect the two ends of the AC adapter into the notebook's power port and a power outlet. Ensure that the power outlet into which the AC adapter is connected is active. Try plugging the power adapter into another wall outlet if the first outlet you try is not generating power.
2. See if the LED power light goes up. If it does but the laptop still does not power on, reseat the battery. Open the battery compartment at the back of the laptop and remove the battery. Wipe the gold contacts of the battery as well as the battery contacts of your laptop. Place the battery back into the slot and ensure that it is properly seated.
3. Remove all unnecessary peripherals if the laptop still does not power on; these may include external hard drives, flash drives and card readers. Turn on the laptop once again and see if it powers on successfully.
4. Use another battery or another AC adapter. If using another battery or another AC power adapter solves the problem, then the issue is with the battery or the AC adapter that you were using. Replace whichever item is malfunctioning. If this still does not remedy the issue, then the issue may be with the laptop's power port or the laptop may be malfunctioning. Seek help with a professional if this is the case.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Sylvania G-Netbook
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
My Dell 5160 laptop slows down with the AC adapter plugged in.
try running ur laptop using the adaptor without the battery in it's place and run it with just the battery...note the difference....it may be a power surge/short issue....some times the battery is supplying power along with the adaptor to the notebook and the power circuit in there is not able to take dual power....check your power options setting in Control Panel...
also do this
clean ur system use Tuneup Utility get it from my website Dowload page
www.sureshayyar.110mb.com
use all the tools and option in that tool...the best is 1n Click Maint in there .....it fixes all ur issues...
Dec 29, 2009 | Dell Inspiron 5160 Notebook
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Nov 11, 2009 | Dell Inspiron 1521 Laptop
Toshiba satellite m35
Are you sure that you fixed the power issue it sounds like there is still a bad connection in the power socket if you want info on this problem go to this site http://www.ask.com/bar?q=laptop+repair&page=1&qsrc=0&ab=1&u=http%3A%2F%2Fwww.laptoprepair101.com%2Flaptop%2F2006%2F01%2F04%2Ftoshiba-laptop-overheating%2F
Mar 29, 2009 | Toshiba Satellite M35-S456 Notebook
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
Jun 21, 2008 | Dell Inspiron E1505 Notebook
Gateway NV59C26u PC Notebook Logo
75 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
