Question about 4Seasons 35786 Relay - Engine Cooling Fan
Hvac fan won't work
    New Friend:
Have you gotten this fixed?
Posted on Dec 18, 2012
Fan on heater don't work on 2005 Buick Lacrose
Then you either have a blown blower motor relay or the blower motor itself is toast.
Dec 07, 2017 | Buick Cars & Trucks
My GMC Envoy keeps blowing the 10 amp fuse for the heaters.I unplugged the front blower fan but it still does it. Is the other fan in the consul?
The fuse isn't for blower motor. I saw a fuse 39 and fuse 36 both 10 amp, both for hvac. I don't know which one is blowing? One fuse is for actuator doors under the dash, the other is battery voltage to hvac control module. One is hot all the time, the other goes hot with key on.
What is model year? Does it blow as soon as you turn on the key? Any applicable hvac trouble codes? About all I can do is track wiring circuits.
Nov 08, 2017 | GMC Cars & Trucks
Where is the fuse for the heater located in a 2008 gmc sierra
Do you have The Automatic or Manual HVAC system ? Doesn't matter fuse's are the same ! Out in the under hood fuse / relay box are two fuse's for heater HVAC BATT fuse #39 10 amp an # 70 40 amp . HVAC BLWR . HVAC = heater ventilation an air conditioning ! So Tom what problem are you having ? Heater fan not working ? There is also a blower motor control module involved !
Feb 09, 2015 | 2008 GMC Sierra 2500HD
Heater ac fan won't blow 05 silverado. Started truck on cold day fan was blowing and turned it off waiting for truck to warm up and heater would not come back on. Checked all the fuses, all were good. Fan...
Test the electrical circuits ! Manual HVAC or automatic HVAC ?
Do you know the difference ? Heater / A/C blower motor electrical control diffrent . Manual has resistors an a relay for different speeds , automatic has a blower motor control module .Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info year , make , model and engine size . Under system click on HVAC ,then under subsystem HVAC controls will pop up . Click the search button , then the blue links . First off you need to know what system yours has , manual or automatic.
GMC Yukon HVAC Blower Motor Won Turn On
Blower Motor Problems Auto Repair Help
Feb 27, 2018 | 2004 Chevrolet Aveo
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
Have two Broan exhaust fans that I want to wire to a programable hvac themostat.I'm told that I need a relay and not sure how they are wired. The fans draw 1.23 amps each and looks like they have
are you sure that your not looking at motor capacitor attached to each motor??? To use programable stat you would have to find line voltage stat with rating to handle fan amp . other option is to use low voltage stat and transformer and fan switching relay with fan motor wired through n/o contacts and relay 24v coil energized by low voltage stat.
Nov 25, 2012 | Heating & Cooling
Fan on my hvac split system won't stop running
Hello, sounds like the contactor coil is stuck which keeps sending power to the motor. Change out the contactor.
May 06, 2012 | Heating & Cooling
1996 buick riviera heater blower won't run. I jumped the motor and it runs. Turn on the switch and it won't run
you have a piece of solder broken off the controller of your hvac unit, causing power not to get to the blower motor it self. take test light and see if you have power at the blower motor. check and see if you have continuty or brake between the power wire at the blower motor and at the hvac control unit. if wires are good then the problem will lie in the hvac control unit. check and see if the blower is working at all speeds, if it works on some speeds thens the blower motor resistor.
Sep 29, 2011 | 1996 Buick Riviera
I turned on the ac and the light does not work, the vents are not blowing and the car is running hot. I have a saturn SL 1996
First check the 15 amp HVAC fuse located in the main fuse block inside the car on the passenger side of the center console, under a cover. If the fuse is good, then the problem may either be the HVAC blower switch (which is the fan blower selector switch), the fan blower motor resistor, or the fan blower motor. An auto repair manual will explain and illustrate for you the steps on how to check each of these components.
Even after pushing the ac light switch on, the fan blower selector switch has to be turned on as well (working) because it provides an electrical path to the positive side of the battery to complete the circuit and turn the ac light on. What the ac light switch does is provide the electrical path for the ac compressor clutch to come on through the ac control relay which is controlled by the car's PCM(computer) when you want ac, but the ac light switch still needs to run through the fan blower selector switch to receive its power. You can turn on the fan without the ac light switch because it gets its ground path(negative) from the blower motor. So the blower motor has to work in order to provide a ground path for the fan blower selector switch to be functional. You could have a faulty blower motor which is why no air blows through the vents. The fan blower motor is located inside the car on the passenger side underneath the dash at the bottom end of the glove compartment box. You'll see it. It's right above where a person rests their feet on the floor. Therefore, if your 15 amp HVAC fuse is good, check to see if you have voltage at the blower motor connector. Unclip the connector and with the ignition on and the fan blower switch moved to any one of the first 3 selections, check for voltage using a multimeter. The voltage will vary because there is a blower motor resistor. Voltage should be higher on setting 3 than 1. If you do have voltage at the blower motor connector, check for a faulty blower motor. The auto repair manual will tell you how to do it using jumper wires.
It's normal that your car is running hot because the radiator fan works in conjunction with your ac compressor. If the ac is on, the radiator fan will be on and therefore the engine coolant temperature will stay in it's normal operating range. If the ac is off, the radiator fan will stay off as well and the engine coolant temperature gauge will begin to rise and show pretty hot (especially at idle). It will do this up until a certain degree then the radiator fan should turn on thermostatically and stabilize the temperature. It's scary and I know what your saying because it does that to my car if my ac isn't on. Don't worry it won't overheat.
May 29, 2011 | 1996 Saturn SL
4Seasons 35786 Relay - Engine Cooling Fan Logo
64 people viewed this question
Top 4Seasons Computers & Internet Experts
David Payne
David Payne
Are you a 4Seasons Computer and Internet Expert? Answer questions, earn points and help others
