Question about Pioneer GM-X862 Car Audio Amplifier
Wiring a pioneer gm-h100 amp - Pioneer GM-X862 Car Audio Amplifier
happy_colors
SOURCE: Pioneer GM-232 Amp
amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgthese are from the actual owners manuel-i used to have this amp also. hope these help
Posted on Dec 29, 2008
  • 150 Answers
SOURCE: NO REMOTE TERMINAL ON PIONEER GM1200 AMP
does it function properly with just the power and the ground?If so try using a ordinary fuse breaker(switchable on/off) and mount it in the cabin of the vehicle where you have easy access to it and can shut it off and turn it on when you need to- Its not necessary to have the remote lead connected to it if it functions well without it.
Posted on May 30, 2009
  • 4 Answers
SOURCE: Red light showing up on amp ( pioneer 800 watt GM 7200 amp )
it could be the amp it could be the way you've installed and if you have a sub in an enclosure the wires could be touching the postive and negetive speaker wires what ever the problem is the amp is in protection mode i hope this helps hope its not the amp i hope its just the wiring
Posted on Jun 05, 2009
  • 8 Answers
SOURCE: Pioneer GM-7200M 800 Watts Mono Amplifier
you Amp is overloading and going into protection mode. if it cuts out with the wire u were using first then their would be no need to upgrade the size of ur wire cause that would only be, doubling or trippling the power u are getting threw those wire now. bottom line the 2 subs u are using are obviously to much for the amp. try dropping the OHM's by connection the subs together and runnig just a single positive and negative to the amp! or just get a better amp
Posted on Jun 10, 2009
SOURCE: i have a gm-h100 pioneer amp.remote switch will
FIRMWARE DVD PIONEER 1.51 DVRKD08A ERREUR INTERNE DE CIBLE
Posted on Nov 23, 2009
I need wiring for pioneer gm 3000 amp?
Here is the pinout. You need to solder your own connections.
Oct 15, 2014 | Pioneer Gm-3000t Car Amplifier
I have a pioneer gm-354 amp and the power indicater light on the front has changed from solid to flashing and no sound from the amp to the subwoofer it used to power any idea's
If it is flashing it went into the protect mode.Check that a speaker wire hasn,t come off, Or that the ground cable conection is good end all other hook up wires to it.
Oct 27, 2012 | Pioneer GM-X354 Car Audio Amplifier
Show me a picture how to hook up this pioneer gm-h100 amplifier
What do the red and black wire go to coming out of the harness?
Jan 04, 2012 | Ford F-150 Cars & Trucks
Can not find where to hook the rem wire on my pioneer gm-h100
This remote wire requires a switched 12 volt .This can be connected at fuse panel and or to radios remote out or power antenna wire.
Sep 22, 2011 | Car Audio & Video
W__How do i wire two pioneer GM-D9500F amps i only have two rca outputs on head unit one sub output that is being used with a D class mono amp for sub the other rca to one pioneer GM-D9500F amp but i have...
Hi, you can split the preamp RCAs with Ys available everywhere. The amp input impedance shouldn't cause much load on the head unit. Let us know if you have more questions, and thanks for using FixYa.
Jan 18, 2011 | Car Audio & Video
Pioneer GM-232 Amp
Dec 29, 2008 | Pioneer GM-232 Car Audio Amplifier
My pioneer gm-h100 amp does not have a remote wire hook up on the amp
there should be a wire harness that clips into the side of the amp if you dont have the clip u can just use some end conecters and hook it up to the two pins that are on the side and hook that to the remote wire.
Aug 11, 2008 | Car Audio & Video
I have a Pioneer GM-H100 amp and I can not figure out the whole 3 prong thing is there a special wiring for it i have seen mixed comments of this same problem on different website can you please help me...
I have a gm-h100 amp. The three prong plug is for a remote turn on. Mine has two wires one of which goes to the radio where it gets a power on sigonal (12 volts when the radio is on). the other wire goes to the an accesory fuse where it gets 12 volts when the key is turned on. the amp needs both of these before it will run
Jul 23, 2008 | Car Audio & Video
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-X862 Car Audio Amplifier Logo
95 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
