Question about Eureka 4718AVZ LightForce 300 Bagless Upright Vacuum
Eureka lightforce 300 poor suction, power paw doesn't spin and self cleaning duster doesn't clean its self when the button is depressed.
Purchased new a couple years back. Hasn't worked properly since we bought it and has been sitting idle. My hubby isn't one to follow through with things and I simply haven't had the time to take care of it since he lost the receipt, otherwise it would have been returned and exchanged. It has never had enough suction to make the power paw spin and the self cleaning duster's fibers only vaguely move on the top 1/10th when the button to clean is depressed. I have brought it over to my Mom's and hooked up the power paw to her 12 amp vac and it works like a charm, I also hooked up the hose of my Mom's 12 amp vac to my lightforce 300's self cleaning duster and depressed the button to see what it would do.... the entire duster spun in the cleaner and the fibers were cleaned like it was a whirlwind vortex inside there..... So.... Help me out here and let me know how I can fix this ******'s lack of sucking power..... Thanks so much ahead of time for any and all help!
When this happens to me I do two things. The first is to empty the cannister but when you do (with the vacuum unplugged) stick your hand up inside of where the cannister goes.Sometimes that is filled with debris. Pull as much as you can out. There is another part inside there that you can twist and pull out - this will help you pull out more of the trapped debris. Replace that part and the cannister - usually there's a blockage and just removing some of that debris will cause a bunch more to dump in to the cannister. You may have to repeat this process two or 3 times untill no more debris comes out when you turn the vacuum back on.
The second tip solution is to clean the filter which can be found on the front of the vacuum.There's a clear plastic cover, a black rectangular this that hold the filter sponge and inside of that, the filter sponge. I just rinse the little sponge inside and shake off the thing that holds the sponge (Sorry, don't know the technical terms). Put it back together and you should have suction - viola.
Hope this helps.
Posted on Dec 03, 2012
2 Suggested Answers
  • 833 Answers
SOURCE: Eureka Enviro Vac Model 4470 Not Sucking
First, check to see if there is suction without the hose on the base. If not, and there is no blockage, the problem is likely a damaged impeller, the small fan that makes the suction. That will have to be replaced.
Posted on Dec 31, 2008
Need brush bar and bearings
The brush roll you need has been discontinued. I have one in stock at this time. ($49.99) Please contact me if you want it.
May 12, 2014 | Eureka 8853AVZ Capture Plus Pet Lover...
Does not suction/pick up trash and debris.
we have an eureka 4495 model and it doesnt want to pick up the dirt off the floor but the hoses are clean and the hose it self has suction and the roller and belt are ok and turn
Feb 02, 2011 | Eureka True Clean Upright Vacuum (Yellow)...
I purchased a brand new Eureka Pet vacuum, sorry don't know exact name but it the one that has the self cleaning duster on it. Last night I used the vacuum on my carpet, it was working fine until I...
If the motor is running, there should be suction. Possible problems depend on whether it's a canister or upright and are:
A clog in the hose, UR or canister. Detach hose. Drop small coin in one end and lift hose causing it to roll out the other. If it does, no clog in hose. Drop same coin into hose opening on power head. If it rolls out, no clog in PN.
Broken fan blades, UR. Needs to be taken to shop for repair/replacement.
A reset button is for use if the motor isn't running, so won't have anything to do with the suction.
Dec 17, 2010 | Eureka Vacuums
The power paw on my vacuum machine is not working.Eureka ez kleen
The filter is not the reason it's not working. Take out screws and open Power Paw, remove fur from the roller brush on the right side, there is a small gap where fur winds around tightly, cut off with scissors or pull out with a small toothpick.
Oct 18, 2009 | Eureka Vacuums
Eureka 2971 vacuum
The duster on this unit is just that a duster the holder for it is to vacuum it off when your not using it it doesn't have anything to do with the vacuum cleaner really. As for the power pawl it is a air driven upholstery nozzle the suction air passes through a turbine which in turn spins the brush agitating whatever it is your cleaning ie. sofa,steps. Simply attach it to the end of the hose and your off just be sure to try and clean any hair or debris for the unit it will not work if the air flow is cut off. For any questions or parts for this unit or any other visit www.stevessewandvac.com
Jul 30, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka Altima Vacuum Cleaner w/Power Paw
The way I resolved the problem was to remove the cover at the end of the power paw. Then remove the so side black covers for the shaft. Remove any debris and hair and then put back together. This solved my problem.
Jan 06, 2008 | Eureka Vacuums
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka 4718AVZ LightForce 300 Bagless Upright Vacuum Logo
188 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
