Question about Mitsubishi WS-55513 55" Rear Projection HDTV
TV wont come on.
I saw a solution to a problem I am having with my TV coming on. It says to replace the 4 caps in the standup shielded model. Where are the 4 caps in the standup shielded module located on the Mitsubishi WS-55513 Models.
  • 81 Answers
If your timer light wont stop blinking? on the vary left of the chassis. is the stand up module or as it is called the digtil module. there are 4 1000 uf caps at 35 volts the top of the caps will be swoling
Posted on May 28, 2007
Tv wont power up after replacing 6 caps 4 bad 2 looked good but were in series so replaced with larger voltage. mitsubishi wd 62725
That model will usually have 8 caps that require replacement on the Power board and also 4 capacitors on the DM board which will usually cause the Non stop blinking light symptom.
Sep 23, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Blinking Light Problem on Ws-55513
If bad capacitors are the problem then replacing them will involve soldering.
If the problem is something else less visible then fault finding will be difficult without the proper service manual.
http://www.completeservicemanuals.com/mitsubishi/crt-projection-television/ws-55513-service-manual/prod_37.html
This will show the correct disassembly and test procedures.
Good luck.
Oct 20, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Zenith L20V34S Completely DEAD Zenith LCD flat screen 20in Model: L20V34S Manufactered: Oct 2005 Listed HealthCare Facility TV Hello all, TV wont turn on (no red light either)after turning it...
The tv now is completely dead,no LED power light indication at all?Yes,than the tv power supply board 90-95% it is alway the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 01, 2011 | Zenith L13V36 LCD TV
Someone gave me a dell w3000 tv and i hooked up the speakers and cable line and plugged in. the tv button turns on and green light comes on but no picture or sound
I have this tv, and have had the EXACT problem. my solution was simple. just need patience if you take the back cover off of the monitor, there are 2 boards on the outside edges of the left and right of the monitor. these boards are covered by metal shields. remove the 3 screws on each board shield and slide them off.(careful this can be tricky) on the boards are 2 capacitors that need to be replaced. 4 total, 2 on each board. the capacitors are 150uf at 35 Volts. go to your local electronics repair shop to get the parts and tools needed to do this repair.
make sure to get the polarity of these caps right. stripe side on cap goes to the minus.
Aug 04, 2010 | Dell W3000 30 in. HD-Ready LCD Television
Hi there, i have a Dell tv model W3000 lately the tv does not turn on at all,i know power is there but the tv does not comes on. sometimes it comes on but it does not last....if i turn the tv off it does...
This is the way all of these fail. Don't buy Dell TV's.
Try this internet posted solution.
Turn on TV with remote control, if the TV does not light-up, find the Main Power Switch. Turn the switch off, then turn it on, the TV lights-up. Probably caused by poor contacts due to age and low quality parts.
Apr 27, 2010 | Dell W3000 30 in. HD-Ready LCD Television
I get a green power button, no picture. I have to turn the Dell TV on 6-10 times beofre picture comes up. What is wrong with it?
I have this tv, and have had the EXACT problem. my solution was simple. if you take the back cover off of the monitor, there are 2 boards on the outside edges of the left and right of the monitor. these boards are covered by metal shields. remove the 3 screws on each board shield and slide them off.(careful this can be tricky) on the boards are 2 capacitors that need to be replaced. 4 total, 2 on each board. the capacitors are 150uf at 35 Volts. go to your local electronics repair shop to get the parts and tools needed to do this repair.
make sure to get the polarity of these caps right. stripe side on cap goes to the minus. 1
Mar 28, 2010 | Dell W3000 30 in. HD-Ready LCD Television
Phillips 19" flat screen
OK, I had the same problem and I fix it 100%.
The power board is ok, the lamps are ok, don't waste time there.
Just open the TV, remove the shield of the mainboard, and in the side where are the wires from the power board, there are many capacitors, check them, in my case 4 were "fat", exploded.
I had to change 9 to make shure, and that's all !!!
Saludos de Mexico!!!
Feb 21, 2010 | Philips 19PFL5422D Television
Bad Caps
Steps to fix your TV: http://www.chrisandnat.com/temp/BlinkingTV.pdf
Oct 10, 2006 | Mitsubishi WS-55513 55" Rear Projection...
Will not reset
4 caps in the standup shielded module get bulges on top--obvious failure. Replace them. Seen it many times
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
