Question about Refrigerators
Beko Fridge TLS480
Thanks for your comment but how do I get the housing off the fridge wall.There doesnt appear to be any screws or whatever and I dont like trying to lever it off if there is some technique
2 Suggested Answers
  • 4793 Answers
SOURCE: we have a beko frost free tall fridge now
is the fan running okay if so could be drain vent blocked also if used for lots of ice making condensate has noplace go
Posted on Feb 09, 2010
My Beko AB910S/1 is freezing the food on the bottom two shelves of the fridge. My wife commented it was making more noise than usual the day before this started to occur. ANy common faults?
The coldest part of your fridge is at the bottom. The bottom shelf will freeze before the top. Check the temperature with a thermometer - its should be about 6 degrees. Trying turning the fridge down a little. If this doesn't put things right chances are the thermostat has stuck and needs to be replaced.
Oct 22, 2013 | Beko Refrigerators
BEKO CG964 fridge/freezer - base of fridge flooding with water underneath salad drawers
I had the EXACT same problem. I've just used a wire coat hanger and pushed it through the hole that the plunger couldn't impact and all the water drained out perfectly! Problem solved!
Jul 02, 2012 | Refrigerators
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Were is the serial number on my fridge freezer
If it is a BEKO, then on the left wall of the fridge unit (Inside) a third of the way down (A silver sticker).
If this question relates to the recent safety recall issues in the media, please read on.
I'm pasting this response on all queries regarding the recently announced issue with BEKO fridge freezers and the risk of fire from their defrost mechanisms, but I have placed it here in hints and tips too, in the hope it will be of use to any concerned BEKO Fridge owners:
According toseveral sources I have checked, including the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what Ican ascertain, the fridges affected were manufactured between January 2000 andOctober 2006 (So, after shipping and sitting around in shops, you can probablyextend that margin to machines SOLD between 2000 and 2008)
If you go tothe BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
I have tosay. Regardless of dates and matching serialnumbers, if I had an affected model,I would be checking with BEKO anyway!
Jul 05, 2011 | Refrigerators
We have a beko frost free tall fridge now
Feb 08, 2010 | Refrigerators
Hi, I have a Beko fridge freezer. It was delivered flat and when plugged in 24 hours later the freezer seems ok but, the fridge is not cooling the light is on. It's a second hand fridge. Thanks
hi. thanks for the question . Check , the freezer fan motor, to see if its ok. check the coils at the back, and fan at the back . if all ok. check behind the freezer wall to see if all coils are frosting up .If all te coils are not frozen you have a faulty compressor .thanks the appliance doc
Oct 01, 2008 | Refrigerators
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Beko fridge freezer humming
- Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object.
Jan 12, 2008 | Haier (492420265334) Refrigerator With Ice...
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
