Question about Ac Delco Vehicle Parts & Accessories
I changed the plugs etc in my 1994 gmc c1500 4.3 now it wont start
Sounds like u have ignition or fuel problems, could be module in distribator or rotor button, fuel pump, cloged fuel filter or it is possible the wires got crossed, could be coil but it's rare because they didnt give much trouble but its possible.
Posted on Oct 28, 2012
1994 gmc safari, wont start. seems to be trying to. changed fuel pump and filter, didnt help. now what
The same thing happened to me in 2008. I had to put in a new starter also. It's been fine ever since
Apr 07, 2013 | 1994 GMC Safari
1994 GMC 5.7 Engine Missing/Surging/Sputtering, I started my truck this morning no problems then after idle for 10 minutes it just shut off and I can't get it started now?
will it turn over ? newer gmc's have an idiot safty thing... it wont turn over if the fuel pump cant put out enough presure, good chance its that especially if you use regular... try to find someone with a computer to see what codes pop up on it.
Feb 10, 2013 | GMC Cars & Trucks
Need to know the signs of the engine coil going out in 1994 GMC Sierra 1500 350V8
Hard starting or won't start, no power, stalling, mis-fire...etc.
How old are the plugs and wires? Plugs wear out, and with wires, its the age not the miles.
Please use AC/Delco wires, from a dealership. Yes they cost more, but you will thank me.
Has your fuel filter been changed recently?
Engines must have Air, Fuel and Ignition. Checking these systems will most likely find your problem.
Aug 15, 2011 | GMC Sierra 1500 Cars & Trucks
1994 GMC Seirra wont start tried changing the battery and still wont start,when we changed the battery the dash lights and the headlights worked but as soon as we turned the key all lights went out and the...
did you see what volts the battery is? and what volts it goes to while trying to start it? should have over 12, and then over 10 while trying to start. Sounds like a battery, or... a poor connection.
Jul 09, 2010 | 1994 GMC Sierra
Trouble shoot 1994 GMC will not start
The only two things that can cause an engine not to run is fuel and/or fire. Check the plugs. Pull a wire and ground it to see if it is getting fire. If it is getting fire then its a fuel problem. Anything from a fuel pump, to an ignition fuse. Coils, sensors etc. Fuel or fire.
Apr 06, 2010 | 1994 GMC Suburban
I have a 1994 GMC 3500 diesel that i had running perfect yesturday and now it wont start. i put a new gas peddle init and still nothing
HI" is your glow plug light coming on for a moment and going off ,,cause you may have a problem glow plugs or relay ,have you scan computer for codes
Sep 23, 2009 | 1994 GMC Sierra
1994 GMC Jimmy hard to start and runs rough when first started
i think if you checked the sparking plugs and map sensors then check your distributer its maybe not delivering the current nedded to perform the spark to some of the cylinders
May 30, 2009 | 1994 GMC Jimmy
1994 GMC Sierra wont start when at operating temp.starts fine cold!
its your fuel pressure regulator!!!!!!!
change that!!!!!!
Apr 13, 2009 | 1994 GMC Sierra
did you do a fuel pressure test? if you havent do it its cheep an at least you can elimanate that. if thats not an issue, then there is only two other things crank sensor, and if there is one cam sensor.
Feb 02, 2009 | 1994 GMC Jimmy
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Ac Delco Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Andrew Gaitan
Level 1 Expert
Terry Hair
Are you an Ac Delco Vehicle Part and Accessory Expert? Answer questions, earn points and help others
