Question about General Water Pump Pulley, cog belt, small C-AEA477
How to change water pump belt if boken on 2002 cadillac
Water pump belt broke and car temp went up above normal temp
There should be a diagram under the hood that shows u how to route the belt.
Posted on Oct 28, 2012
Long 3/8 rachet to tentioner and follow belt diagram but first make sure water pump turns freely
How to replacewater pump housing on 2002 cadillac devile dhs
If the housing is leaking, you can replace the gasket but you need to remove upper filler panel, air cleaner assembly, secondary air injection control valve, oil level indicator tube nut, water pump belt shield, the belt, the radiator hose at housing and then the cover.
If you need to replace the water pump, not easy as you need a special tool to remove and insert the pump.
May 20, 2015 | 2002 Cadillac Deville
Because if you put the thermostat at 300m water does not circulate when the thermostat is new
So you changed the thermostat?
Water will not circulate while engine is cold. As it reaches normal temp it should open and circulate. If it is overheating when warmed up, and still not circulating, then either the thrmostat is bad or wrong type, or it was installed wrong and somthing is blocking it.
One other thing possible is the water pump is broken, but usually when pump is broke, it leaks, from the back of the pump.
You could check the belt is correctly driving the water pump.
Apr 10, 2011 | 1999 Chrysler 300M
I have a 2002 cadillac deville.it recently ran hot because the water pump tensioner broke.I replaced the radiator,tensioner and pulley and the belt.but if I let it sit there and idle the temp guage goes no...
It sounds like you have an air pocket in the cooling system. I would try parking the car on a hill with the front of the car facing up. When it has fully cooled off, recheck the coolant level and ad more coolant if needed. Sometimes you can slowly top up the system through the bleed hole as well, do this when cold on level ground.
Jan 23, 2011 | 2002 Cadillac Deville
How do i change the water pump belt on my 96 32v v8 cadillac
Hello there:
Remove the water pump belt shield
Loosen the water pump belt adjuster and . remove the belt from around the water pump
Sep 29, 2010 | 1996 Cadillac DeVille
Engine temp goes up to 230 degrees
It's actually normal for engine temps to go up to 220 deg. F or 230 deg. F in the summer time, even in normal engines that run at 196 deg. F typically.
This happened to me with no malfunctions on my 1997 Cadillac Deville, yesterday.
Actually, engines run more efficiently at higher temperatures like this.
Just make sure your coolant is topped off and that it fluctuates between lower temperatures and this high reading.
This is a normal temperature in my experience for GM vehicles.
Aug 11, 2010 | 2002 GMC Envoy
What coolant temp should i have, while driving temp gets to 222 f. is this normal?
222 is quite normal for the Northstar engine.
The cooling fans don't come on until around 225 degrees unless of course you have the air con on.
Oct 03, 2009 | 1998 Cadillac DeVille
01 civic timeing belt went, are the valves ok?
It is an interference engine and I always change the water pump when I replace timing belts because it's cheap insurance and you don't want to go there again if it goes out in a couple of months after you replace the timing belt.
Feb 03, 2009 | 1996 Ford Taurus
Where is the water pump located on the 2002 Cadillac Deville?
Water pump is located on rear of the engine. faceing the car it is between the radiator and the head. It is driven by a small belt. It is removed by removing a cover plate that has the radiator host and by pass hose connected to it. it takes a special tool to remove and install this item. it is available at most auto stores. approx. 2 hour job and somewhat a hard job . see the haynes manual for this car very detailed on how to change the waterpump. jim
Dec 02, 2008 | 2002 Cadillac Deville
General Water Pump Pulley, cog belt, small C-AEA477 Logo
182 people viewed this question
Top General Plumbing Experts
ka4iup
ka4iup
Gil Shultz
Richard Warren
Richard Warren
Are you a General Plumbing Expert? Answer questions, earn points and help others
