I get a lot of lines going down my screen
Im pretty sure this is a problem with the logic board. i will get a bunch lines with darkish green colors going down my screen the light is almost out completely . i know it cant be the lamp i just got a new lamp installed to try to fix the problem . it was the same. but now to day it got worse. all the information i could find onmy tv was the serial number 31HW500629L, the model code HLN6117WX/XAA and the lamp code :BP96-00224E(p) please help.
  • Copper Mccambridge
    Copper Mccambridge Oct 28, 2012
    i didn t mean to put it under projection television inless a tv with a lamp inside is a projection tv. im no good with tv
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Its a dlp rear projection which uses the lamp---possible problem with optical light engine or digital board--set more prone to light engine problems--it displays the picture onto the mirror and processes all picture info in and out of the engine.
Posted on Oct 30, 2012
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
welcomejee
  • 10594 Answers
SOURCE: Color Wheel installation
You can purchase color wheel of Samsung HLT5075SX from Part Store and I would recommend to have qualified TV tech for installation. it is not advised to novice to get involve in such kind of repair that can damage TV.
Still you want to repair it by yourself then download service manual copy of same TV from HERE for small fee that has proper info.
Posted on Aug 05, 2009
  • 146 Answers
SOURCE: Mitsubishi WD 62327
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
My best gess is the Ballast.
Posted on Nov 15, 2008
  • 37 Answers
SOURCE: We have a Samsung DLP model HLP5067 WX/XAA. It
NEEDS A COLOR WHEEL ABOUT 150.00 DOLLARS
Posted on Feb 09, 2010
  • 8457 Answers
SOURCE: Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Posted on Aug 02, 2010
My other computer, G4 Macbook Pro, has a screen issue. When it is turned on and in process of coming up, the screen shows large sections of odd colors such as light pink or light green or light blue. Then...
Connect an external display to the computer. If the lines and distortion shows up on the external display its the video card, which is attached to the logic board. So, the whole logic board will need to be replaced.
If the lines and distortion don't show up on the external display the issue is the LCD module, which will need to be replaced.
Jan 30, 2011 | Apple PowerBook G4 Mac Notebook
Color isssues with my television
The problem you having is Called Convergence,Contact me while im online And ill tell you about it ttech
Jul 22, 2007 | Toshiba 57H81 57" Rear Projection...
Monitor flickers, similar to a fluorescent light bulb that is going out. Also, there is one line on the left side of the screen, going up and down, that changes color, but it comes and goes. I thought...
The problem is in the monitor screen, there is a large circuit board connected behind the main display screen. The video signal is feed to the main board and generates the proper color balance, the second problem is the lamp behind the display is flickering and breaking down. To repair this will not be cost effective, cheaper to replace the monitor. But I would suggest hooking a spare monitor to the computer to make sure there are no additional issues.
Jan 21, 2011 | Dell SE198WFP LCD Monitor
No picture.. just a bunch of random colored lines
It sounds like the T-CON board on the LCD panel may be damaged when the filter caps went bad. Do you see any bad caps in the logic board? Also check out he ribbon cable between the logic bd and the T-CON LCD panel are properly attached.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 09, 2010 | Westinghouse LCM-19v5 Monitor
Bad panel on 42'' DP42746??
id like to help you out you said there is a black spot about the size of a . you said software did you mean softball if you said softball and its round and black yes its the panel if its a straght line up and down it could be a logic module or ribbon cable
Feb 03, 2010 | Televison & Video
Vertical lines on screen different colors
The problem is the LCD panel or the logic PCB (printed circuit board). you can find the logic pcb attatched via flat ribbon cables or small plugs. Good luck. The part number should be on the printed circuit board. I hope this helps.
Nov 16, 2009 | Toshiba 42HL196 42 in. LCD HDTV
46 inch Sony flat panel lcd has vertical red and green lines down right side of screen and you can be watching tv and picture will go right out and leave grayish blank screen until restart. Black...
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Apr 28, 2009 | Sony Televison & Video
Colored vertical lines
It is a tossup between a bad LCD panel and the logic board. The only way to tell for sure is to change out the logic board or have it tested on another unit. Checkout www.lcdrepair.us for instruction videos on that unit as well as parts.
http://www.lcdrepair.us/Installation.html
Jun 19, 2008 | Dell 2000FP 20.1" LCD Monitor
Red bar/green bar on left side of vizio plasma
POSSIBLE solution:
We have the same problem on our 42" Vizio plasma screen. I've had many conversations with the tech at Vizio, and they said it's an inherent problem with the screen (whatever that means) that can't be fixed, or is not worth fixing (as another comment says).
But...when a cable guy came to install a new dish, I told him about it, and he said he's seen it before on other plasmas, and that it may be caused by the sound speakers being placed either too near or in the wrong position near the tv.
He said there are magnets in the speakers that will throw off something in the screen.
We have a Bose sound system, and so we tried repositioning the speakers and subwoofer. The line did go away, but then came back. It comes and goes.
Who can figure this out? Well, for what it's worth, try repositioning your sound speakers.
Apr 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
