Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
HOW TO OPEN LID ON MAYTAG CENTENNIAL - Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
3 Suggested Answers
wiringlunati
  • 576 Answers
SOURCE: how can I make the Maytag Centennial 3.2 agitate
You really can't without redesigning the washing machine.
Posted on Mar 07, 2010
jsrock516
  • 5911 Answers
SOURCE: how do I get top of my washer..Maytag Centennial
This model Maytag is actually manufactured by Whirlpool. To access the lid switch on this particular model, all you should have to do is remove the operator console. The console has a retaining clip on each side holding it to the cabinet top. To release these clips, simply take a putty knife and slide it under the left and right front corners of the control panel push straight in towards the back of the washer. The clips will depress, allowing the operator console to be lifted up. The lid switch is mounted next to the left lid hinge. Refer to the "Top and Cabinet" parts illustration, Item 6 at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWC400VW1/3048/0153200?pathTaken=&prst=0&shdMod=MVWC400VW1
Some other websites you may refer to for parts include:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: If you model number does not cross reference to these sites, use the part numbers fromthe Sears websites as your search criteria. Often, the model numbers may not be included on some websites (newly added models), but the part numbers will.
HINT: In some cases, what may appear to be a bad lid switch, may only be an actuator adjustment. The acutator on these models is the rod attached to the left lid hinge. You can bend the rod slightly to adjust the contact with the lid switch, or it may be tightened as necessary. If the switch toggles (clicks) by hand with the actuator rod removed, the switch typically is not bad.
If you need to remove the entire cabinet to access under the lid, the following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Apr 21, 2011
Maytag centennial top loader i left the lid open to soak some clothes and it drained on its own and now it is stuck in draining mode
Turn the machine off. Wait 2minutes close lid and start new cycle.
check to see if your drain hose is lower than the bowl....this will also cause the water to drain out
Jan 25, 2014 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Centennial MVWC6ESWW1 and need to know how to lift off the top cover to get to the lid switch?
There are two hinges at the back, just remove two screws on top then push the top toward the front about 1'' or 1.5'' then lift it up.
Sep 30, 2013 | Maytag Centennial MTW5800TW Top Load...
Maytag mvmc6esww1
First, open and close the lid. You should hear the lid switch click. Let me know if you can hear it.
Oct 21, 2012 | Maytag Centennial MTW5800TW Top Load...
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
148 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
