Question about Kenmore Dryers
My door switch is broke,How can I fix it? - Kenmore Dryers
  • Kenmore Master
  • 8,220 Answers
You need a small phillips screwdriver. You remove 2 screws inside the door jam to get the old switch off. This video I made shows how to get inside the machine:
Not all kenmore dryers are the same here is different model:
SPOOKY DRYER
Posted on Oct 29, 2012
To konw the cause of the problem and get it fix.2005 ford escape has a centeral lock and door glass issue.
Which door are you having electrical issues with ? Just one or all ? And what kind of problem are you having ? Power windows and locks not working at all , won't up , doors don't lock ? All the time or intemittantly ? You can check for broke or almost broke wires inside the rubber boot from body of the vehicle to the door . The power and ground wires for the door switch are in there . Opening and closing the door over time the wires can break .
Dec 30, 2016 | 2005 Ford Escape
Plymouth neon 2000 passenger door
If the door buzzer switch is broken and moving around it will ground out on the door an complete the circuit and cause the buzzer to go off. if you do not want to fix the switch remove the wire from the switch and tape it up with electrical tape
Jan 30, 2018 | Plymouth Neon Cars & Trucks
Windows dont work door ajar light is on
I had my door ajar light stay on, turns out the switch in the drivers door latch broke, in order to fix it you have to get a whole new latch mechanism. I went to a junkyard to get a latch but the guy at the junkyard broke the switch while removing it from the door. I got a new latch assembly from the dealer, pretty reasonably price if I remember correctly. They are pretty easy to break right where the electrical connector connects to the switch. Maybe you have a broke switch?
Jun 17, 2011 | 2002 Ford F350 Super Duty DRW Reg. Cab
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
My dryer light will not shut off even when door closed and it will not start up when in push start button it does a rapid beep
is the door switch broke?first what kind of dryer and send the model number,when the door closes it hits the door switch and shuts the light off,the dryer will not run if the switch is broke,it's like trying to start the dryer with the door open if the switch broke.
Apr 25, 2011 | Dryers
Driver side window switch broke how to fix switch
It really depends on what broke. is it the plastic lever, or the electrical part of the switch.
Jan 22, 2011 | 2001 GMC Yukon
None of my windows in my chevrolet suburban 1999 will go down....how can i fix this problem?
replace the master switch in the drivers door,first make sure its getting 12 volts to the switch,could be a wire broke between door and body,open door,you will see a rubber boot from body to door,grab the boot and work it up and down,back and forth while holding the switch down,make sure key is turned on
Jan 31, 2010 | 1999 Chevrolet Suburban
The door latch broke, and I can't get the door open, or the food that was in there before the latch broke!!!
Remove the cover --- you shuld be able to release the lock from withinthe cabinet.
While you are there, you may want to replace the door safety interlock switch(s)
You may have to disassemble the door to get the latch fixed.
Oct 19, 2009 | Microwave Ovens
How do I replace the door switch button?
unscew & raise the top panel to gain access to the switch
easy fix!
Jul 21, 2009 | Washing Machines
Magic Chef door switch broke
Get the model from inside the microwave door and go to the link below. They have about anything for everything. Should be pretty easy to fix. Hope this helped.
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Mar 14, 2009 | Magic Microwave Ovens
Dryers Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
