Question about Wacom Intuos4 PTK640 Graphic Tablet
My computer won't recognize my wacom ptk640
Why does my intuos tablet not respond
Can you set back an older version of XP? with restore under the configuration tab?
If possible one from before you installed your driver.
Take care with XP, because "bad" guys try to get access to any XP computer, not in the last place by offering drivers you don't need.
Nov 21, 2014 | Wacom Intuos4 PTK640 Graphic Tablet
My eraser is bugging out
I'd guess your memory is filling up. Try setting your undo levels to really low, like 1 or 2, and see if that helps.
Apr 10, 2017 | Wacom Intuos4 PTK640 Graphic Tablet
Illustrator CS5 does not recognize my graphic pen, wether with the Wacom tablet or my new Monoprice tablet. It draws a yellow sticky note kind of thing, it is annoying and I can't find a solution,
I too have a tablet not made by Wacom. For some reason, Illustrator only opens the tablet-sensitive definitions for Wacom. The solution I found: Go to the Wacom site, install the latest intuos driver. You won't be using it, but it will trick Illustrator into thinking there's a Wacom installed, the definitions will be active for your pen. Mine seems to work fine now.
Jun 28, 2012 | Wacom Computers & Internet
My iphone is hanged its shows apple logo only, hw can i solved this problem without loosing my all data,like my videos,contacts,pictures,pls help me out
Try pressing and holding both the POWER & the HOME button at the same time for around 3 to 10 seconds until it turns OFF. Then turn it back on again.
If it still won't go past the Apple logo, use tinyumbrella to Fix Recovery or to Exit out of Recovery. Download tinyumbrella using the links below: for Mac for PC (Windows)
Update tinyumbrella first if it tells you that there's newer version available.
NOTE: Your computer must be able to recognize your iPhone before you can use tinyumbrella to fix it. If your computer could not recognize your iPhone, you first need to put it to DFU mode. To learn more about DFU mode, CLICK HERE.
If those things still don't work, you'll have no other choice but to restore. Again, your computer must be able to recognize your iPhone before you can restore it using iTunes. Put it to DFU mode if your computer won't recognize it.
Read more tips for iPhone, iPad and iPod touch, CLICK HERE.
Apr 25, 2011 | Apple iPhone 3G
My Wacom Bamboo Tablet doesn't Recognize pen.
well, in desesperate mesure when you cant solve it, uninstal and instal it again, that solves it, but, I reconmend it only when you've no other choise
Apr 13, 2010 | Wacom Bamboo Fun USB Tablet with Cordless...
My Cintiq 21ux is not recognized as a 2nd monitor it just works as a huge wacom tablet with a black screen.It recognizes the pen as a mouse on my other monitor I get the same message No /sync /go to...
HI, I've had a similar problem. This solved it for me. Connect the cintiq first to a dvi to vga adapter, then connect that to apples vga to mini display port adapter.
worked for me so I'll keep my fingers crossed for you.
Jun 06, 2009 | Wacom Cintiq 15X Graphic Tablet
Im using a serial to usb connector to connect my artZ II tablet to my laptop..
Sorry, I figured it out, it was because the serial to usb adapter i was using needed a driver, and then my computer recognizes it as an extra serial port. So, during installation it needed to be searched for automatically from my serial ports.
May 12, 2008 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Open Questions:
Wacom Intuos4 PTK640 Graphic Tablet Logo
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
Ed Mac
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
