Question about Acer Computers & Internet
Overclocking can i overclock aspire am1100-e1401b
    Problem Solver:
  • 6 Answers
I never overclock my processors... because I have fried a couple.
AND I don't really need any extra power/speed... because now I only surf the web and do some Word/Excel stuff and my duo core Intel chip is awesome for that.
So - first: I don't recommend it.
But - second: there are some good sources on the web about it...
Do you know how to do it?
I mean the steps to get to the settings and change them?
If you do then I found some recommendations for your processor at http://www.amdgeeks.net/overclockdatabase.
Processor: Athlon 64 LE-1640 2600 @ 3422 MHz
Overclock % Voltage Idle Load
132% 1.25/35/40 @ 1.50V 35°C 41°C
Processor: Athlon 64 LE-1640 2600 @ 3380 MHz
130% 1.25/35/40 @ 1.40V 30°C 40°C
Processor: Athlon 64 LE-1640 2600 @ 3320 MHz
128% 1.25/35/40 @ 1.37V 29°C 44°C
Like I said I don't recommend it so I don't want to walk you through it, also when you do this you run a risk of frying your chip - and I don' want to be liable. Like I said above - there is some good infor on the web about it so you should not have any trouble finding out how if you don't know.
Good luck
Posted on Jan 03, 2009
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Sirwriter
Nov 05, 2009 | Intel DG31PR Motherboard
Added 2 1gb pc2-6400 240 pin ddr2 800 memory modules in my am1100-e1401b in the 2 extra spots compters shuts down swapped them out with existing 512 mb cards then it seems to work fine but only end up with...
Hello
I had this problem a few months back, but first you must be sure that you purchased the correct ram modules. It turned out, cause we tested the modules i baught at a friend's as well. The modules was broken. Hope this can help you.
Best regards
Nov 01, 2009 | Acer Aspireā„¢ T180 PC Desktop
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Upgrading the CPU
overclocking is adjusting the speed of which a cpu works at (processor = cpu) replacing a cpu is not overclocking and wont cause any problems aslong as the cpu is ment for the motherboard and is supported. depending on the motherboard you may not be able to place in a 800MHZ cpu, but if you find one that fits and works on your model sure go ahead, it wont cause any problems, other than possibly overheating if the cooling is designed for a slower processor.
May 31, 2009 | Acer Aspire 5315 Notebook
Acer AM1100-E1401B
Try Acers website first and then try driverguide.com
Apr 09, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
Rate this solution.
Jan 09, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
Overclock a black edition 5000 x2
@johnhercus26
pls let me remind you that overclocking voids your pc's warranty.you will need to enhance the cooling solutions for the device you will overclock plus the cooling solutions for the CPU case, every time you overclock, more heat is produced by the device you are overclocking. also you have to make sure you have power headroom..., a higher wattage CPU power supply. plus the risk that you may toast your pc or lessen its usable life. overclocking is for advanced users so pls take extra caution if you will do it.. for guide and instructions pls click here and goodluck! >>> http://www.pcstats.com/articleview.cfm?articleID=1804
Oct 23, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Overclocking
are you sure that your pc is built for overclocking? dont be risky it might get you trouble on your pc. i suggest that you shouldnt overclocking it and besides your processor is high ed.
CHARCOIS
Aug 24, 2008 | Intel (P42000400256SK478) Pentium 4, 2 GHz...
Max processor support
Believe the Aspire runs a 939 chip, if that is the case -AMD Athlon FX-60 Dual Core @ 2.6Ghz
-AMD Opteron 185 Dual Core @ 2.6Ghz (best Overclocker @ ~3.2ghz) LINK this is for cpu-z to see what processor id, fsb etc,
Mar 14, 2008 | Computers & Internet
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
200 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
