Question about LG 42LG50 42 in. LCD HDTV
My lg 42lg50 HDMI ports quit working
When I try to use any of the hdmi ports I get a no signal on the tv.
markevans
  • 148 Answers
SOURCE: LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
Posted on Dec 23, 2007
  • 979 Answers
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
Posted on Feb 28, 2008
  • 458 Answers
SOURCE: LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Posted on Apr 18, 2009
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
  • 10 Answers
SOURCE: no signal from ps3 to lg tv via hdmi
if this is the first time you've hooked it up via HDMI then you have to go back to the old cables first. Hook those up to the old TV or the new one, then go to settings and switch to HDMI. It will give you 30 seconds to change the plugs again so you can view the HDMI. Then select ok. Hope this helps
Posted on Aug 20, 2009
Just bought a 55" Lg Led tv and i hook up hdmi from cable box to tv hdmi 1 and hdmi from my blue ray player to the tv hdmi 2, ok then i turn the input on both now hdmi 2 work but hdmi 1 has no signal why...
try connecting your blue ray player to HDMI 1.
A) If it works there, then you know the port on the TV is OK & the problem is with either your HDMI cable or your cable box.
B)If it still doesn't work then you may have a problem with the port on your MAIN PCB. if it's a new TV your warranty will cover that as long as the input connector is not physically broken.
Mar 08, 2015 | LG Televison & Video
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
Why does my LG tv seems like it need to warm up before it will accept HDMI signal?
Sounds like a capacitor fault. They can be intermittent when cold, but will work okay when warm. Eventually though they will fail.
This is your advance notice to get the set either repaired by the manufacturer or a local TV shop.
Sep 06, 2014 | LG 42LG50 42 in. LCD HDTV
How to fix hdmi port
What do you mean? HDMI reception problem? If firmware to HDMI is not installed, the set do not receive any HDMI signal. Contact the authorized service center. Electro help
Jul 25, 2014 | LG 42LG50 42 in. LCD HDTV
Can't get hdmi signal from comcast dvr to LG smart tv
the type of cable you use is important. i work for dish network and i have seen cables go bad. also tv's hdmi imputs go bad as well. i would call a technitian out to look at the system, have him try a new hdmi cable and in different ports to make it work. it may be there reciever or your tv.
Mar 05, 2013 | LG 55LM6700
Hdmi ports om our lg tv are not working
yes you have to replace the mainboard just buy the part yourself and install it there's not much to it buy the part @ www.shopjimmy.com
Mar 02, 2013 | LG 47LW6500 47 3D LCD TV
The lg 42 in tv indicates invalid format when I connect the hdmi cable but the first time I connected it was working fine I moved it to another lg tv and it works fine
Tries tv unplug,replug tv it back like about an hour later.By letting tv resetting iself back to the factoty setting.Goto Menu goto PICTURE go down to resetting to reset the whole tv tuner signal board back to factory.That HDMI port should work again now,If not that HDMI port is shorted and dead sorry.
Jan 05, 2011 | LG 32LC7D Television
42LG50 HDMI error message
pull the plug on your tv and cable box for 1 minute and start fresh. glitches like this happen all the time with hdmi. if this does not cure, the error message you get needs to be posted.
Feb 27, 2009 | LG 42LC2D 42 in. LCD HDTV
42LG50, black is not really black
The most common culprit to signal noise is poor quality or defective cables that may have cracks. I would check the HDMI cable. Do you have any other devices with an HDMI output like a PlayStation 3? If the image is fine using it, your HDMI ports on the TV are fine and so would the cable. It could be the BluRay player itself. Since this is a LCD TV that uses a backlight, your blacks aren't as black as you may want. The TV may allow you to drop the level of the backlight so check the onscreen menu for options.
Sep 09, 2008 | LG 42LG50 42 in. LCD HDTV
LG 42LG50 42 in. LCD HDTV Logo
166 people viewed this question
Computer Repairing
Computer Repairing
