Question about Philips SRP4004/27 Universal Remote Control - SRP4004 TV 30 ft, Vcr, DVD Player, Satellite Box, Cable Box, Blu ray Disc Player, Dtv Tuner, Dvr
My tv has no channel 1. How can I configure srp4004/27 remote controle to a tv without channel 1
I can not configure the remote control because i dont have channel one on my tv
SOURCE: 4 in 1 remote control
Hi the codes for hitachi are 0074,0082,0081,0511,0201,0616,0234,0236,0255,0232,0554,0110,0537,0075,0594,0147,0216,0143,0550,0518 turn on tv, 1.press tv button on the remote 2. press setup button until it flashes twice enter code then turn off by power button (keep repeating 1-3 until tv goes off) hope this helps.
Samsung vcr 0278 or 0455 as above. Angela.x.
Posted on Apr 22, 2008
SOURCE: i need a code for my remote control
I NEED THE CODE OF MY REMOTE CONTROL PHILIPS RC-2835/01...PLEASE HELP US! WE NEED THE TV!
Posted on Jan 25, 2009
watsuke
  • 48 Answers
SOURCE: remote control codes
Go to the masterplug website and call them, they'll send you everything you need via e-mail.
Posted on Feb 04, 2009
  • 50 Answers
SOURCE: masterplug 4 in 1 remote control codes for Panasonic TV
Panasonic Codes:
1056
1107
1108
1147
1148
1149
1150
1151
1152
1199
1206
1321
Posted on Jun 01, 2009
SOURCE: my remote dont work
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
You might have to enlarge the size but this is the manual.
Posted on Jun 03, 2009
How do I set up the romote without able to get to channel 1. I cant set my Prima TV to channel 1.
The problem post of yours' is difficult to understand. Acually; what do you want to do? Proved more details; please.
Oct 29, 2014 | Philips Televison & Video
My tv is set on zoom3 and i dont have my remote control,; what can i do? I've bought universal remotes but no luck!
Doesn't appear to be a good way to do this without the remote, you can try to do a factory reset,
Factory Mode Procedure
1.Power on TV.
2.Press volume up and channel up buttons on the TV simultaneously and release.
3.Power off TV with remote or power button to exit.
If this doesn't work you can get a polaroid replacement remote here:
http://www.discount-merchant.com/Polaroid-RC-201-Remote-Control-p/remote-9039.htm
Apr 01, 2011 | Polaroid FLM-323B Television
I dont know my model number of the philips universal remote i own. i also need the remote code. thank you!
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Philips Universal PH301S Remote Control
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Toshiba 2100TB tuning without the remote control
If you are sure, that there's no way to do it manually on the TV, there are only two solutions: buy a new remote control according to your TV set model (sometimes it's hard to find) or buy a universal remote control
Jan 30, 2009 | Televison & Video
Can you help me program my remote?
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
InputChannel without remote
Yes and no depends on the TV if you have a menu button press it and go to autoprogram and let it find all the channels then press channel down until you get to channel 1 then press it again and it should start cycling through aux inputs.sometimes TVs dont have a menu button and this is not possible.try simply pressing channel down until you get to channel 1 then maybe it will cycle through your inputs.Please rate me if this helps.
Nov 16, 2007 | Durabrand DWT1905 TV
Orion stv 2750 27" TV
if you dont already have the remote set up then find the codes and t it up. the remote should have a button that says either tv/video or input. depending on the tv it should take you to a few channels through this button. look for either input 1 or 2, or even GAME. these should be the channels it will play on.
Oct 26, 2007 | Orion STV2763 27" TV
Can I play the video and a dvd without the remote control?
Your set should have external video and audio imput jacks besides the tuner imput for antenna,you can use the video and audio outputs from the vcr or DVD and conect them to the video and audio imputs in the tv then you can select a channel below 1 or push the switch that says Video/antenna.
Oct 02, 2006 | Samsung CXD2512 25 in. Combo
Philips SRP4004/27 Universal Remote Control - SRP4004 TV 30 ft, Vcr, DVD Player, Satellite Box, Cable Box, Blu ray Disc Player, Dtv Tuner, Dvr Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
