Question about Dryers
Inside fisher and paykell dryer door got stuck and didn't start so I took it apart to get my clothes and now I'm having trouble assembling it back together.... Please help
  • Dryers Master
  • 8,220 Answers
  • 883 Answers
SOURCE: Fisher and paykel clothes dryer ED 54 -U
go back to the last thing that changed..."as soon as I put the unit back together"...what item may have pinched a wire during re-assembly....not saying it wasn't pinched before you started. I am saying there is a possibility of a wire pinched to chassis...an electrical short.
Posted on Jun 05, 2007
SOURCE: Squealing Fisher Paykel Dryer DE05-US2
dryer's have a long belt that runs around the drum. a common culprit is an idler pulley on the belt tensioner. you can take off the front of the dryer and oil it for a temp fix. it will probably need to be replaced
Posted on Dec 16, 2008
SOURCE: dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Posted on Apr 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Posted on Nov 08, 2009
The dryer is not giving any heat.
Sounds like the heating element has burned out. If it's an older dryer then that's probably the case. If it's newer I would check the warranty.
Feb 05, 2015 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel Dryer Fault Code 22 Info
That is a fault for the "Door Actuator Open Circuit". You may have not had the door closed completely and when you opened the door to check it out, you closed it completely. Another possibility is the sensor module is going bad.
Feb 10, 2012 | Fisher and Paykel DE27CW1 Electric Dryer
How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My dryer drum is stuck. When I open the top, the drum is set so that I cannot get my clothes out. I looked at the directions to push a button in on the inside, and then manually rotate it. I had to...
It sounds like one or both of the bearings have failed. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Aug 12, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Hi emkboyce
Sep 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel gwl11 washer leaking and squealing
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
Jun 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
Jun 05, 2007 | Fisher and Paykel DG05 Gas Dryer
Dryers Logo
525 people viewed this question
Top Dryers Experts
