Question about Sunbeam 900-watt Digital Microwave Oven 0.9 CuFt 900 Watt Digital Microwave Oven
SGB8901 Fuse blowing immediately when plugged in
My microwave blow the fuse after pressing start
There could be a bad interlock switch. I have seen this blow the fuse. The high voltage capacitor could be shorted. This will blow the fuse immediately. Take care around the high voltage circuit. Make sure you short the capactor terminals to groound before touching any connectors.
Oct 02, 2014 | GE SpaceMaker Microwave Ovens
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
NN 8501V Panasonic Dimension 4 Convection/Microwave oven keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
Apr 16, 2013 | Microwave Ovens
Beeping on Sunbeam SGB8901 Microwave
Unplug microwave, open top, "several screws" look to where the keypad is, behind that you should see the control board, mounted you should see a round black device may be a speaker or pizza buzzer, verify that is sound.
May 09, 2012 | Sunbeam Microwave Ovens
GE JES1855 1100 Watts Microwave Oven not working. Display lights do not come on. Checked wall plug and it is ok.
Sounds like internal fault protection fuse blew. can be fixed by qualified technicians. their is very high voltage coils and capacitors within this unit and can cause harm or death instantly if not discharged properly.
Aug 12, 2010 | GE JES1855 Microwave Oven
Sharp R-930AK convection/microwave suddenly died
You need to open the oven (unplugged) by removing the screws along the case. Inside, there is a 20 amp fast blow fuse that you can get at Radio Shack. It looks cylindrical and white. I would test that first. However, replacing the fuse may work, but then, other components may have shorted inside causing the fuse to blow. Try the fuse replacement/test it first. Good luck
Apr 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Sharp Model 1451 blown power fuse
1.Problem with monitor door switch or
2. Problem with high voltage condenser.
Nov 30, 2008 | Sharp R-1874 Convection/Microwave Oven
Blown Fuse
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Apr 01, 2008 | Emerson MW8775W Microwave Oven
Sunbeam 900-watt Digital Microwave Oven 0.9 CuFt 900 Watt Digital Microwave Oven Logo
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
