Question about Emerson ES769 CD Shelf System
Emerson ES769 CD Shelf System spins dics doesnt work
Player does not play CD, it spins the disk but and displays the word DISC on the LCD but never plays the disk, Auxiliary and radio work fine
2 Suggested Answers
SOURCE: won't play a cd
put a mp3 cd it will work worked for mine has truoble reading regualr cds
Posted on Feb 08, 2008
it sounds dumb, but i actually wiggled it back and fort (the whole unit) and it started to spin the disks
Posted on Feb 23, 2008
0 characters
1 Points
Cd doesnt play, it just opens up. is there something i can do the stero is new
If the CD spins but does not track or read any disc you can try and clean the lens head of the CD player. Use a cd cleaner and try. if not the possibility of the optical head being faulty is high.
Mar 04, 2011 | Coby CX-CD405 CD Shelf System
Everything works on my emerson MS9700 except the cd player. the display keeps saying no rdy. how can i fix this?
If the indication says" not ready " it means that the disc is not reading the data present on it . It is possible that the disc is not scanned by the optical head to be ready to play.
So it is possible that the optical head is defective or weak, please try to clean the optical eye with ear bud very softly or use a disc cleaner.
If there is no result the head can be faulty.
If the set was not used for long time please keep it powered ON.
Also the processing section/main board can be a suspect.
Nov 19, 2010 | Emerson EM-MS9700 6 CD-Changer stereo...
My CD player will not work. how can i get it
First try cleaning the Lens with a commercial cleaning disc, it might just solve the problem!
Feb 27, 2010 | SpeakerCraft SoundSource CD Shelf System
Emerson ms3105 won't play cd's wont even spin
kungfuz...I have had two of these emerson cd players. One is in my home and is still working after 3 1/2 years. The other was purchased for our church just over a year ago and it has stopped working. The disks will turn a little then stop. Occasionally it will still play a complete hymn but this is rare. Also a grinding sound can be heard with the ear close to the unit. I think when you pushed the combo of buttons and it stopped working, this is likely just a fluke and it was probably going bad anyway. I may be wrong but I have been down this road myself and your problem sounds very similar to mine. I can't offer you much encouragement...sorry...!
Jan 28, 2010 | Emerson MS3105 CD Shelf System
Cd player quit working
Jun 19, 2009 | Emerson MS9825 CD Shelf System
Emerson ms9700
one thing that you can do and this helped me when i had that same problem is to take off the top cover and clean the laser lens
Oct 25, 2008 | Emerson MS9700 CD Shelf System
CD Player does not recognize CD
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Oct 05, 2008 | Teac DC-D2831 CD Shelf System
Feb 11, 2008 | Emerson MS3103 Shelf System
Won't play a cd
We have the same problem and are searching all over the web for a solution but no luck. If we find a solution we will come back and post what we found. :)
Oct 15, 2007 | Emerson MS3111M Shelf System
CD's won't play
I know that Panasonic provides chips, optics (laser),etc. to Emerson. I am familiar with the problem you've experienced because I've had a Panasonic CD Player. If the disc doesn't spin (as you said), the problem must be that your shelf system probably has an optical problem (laser problem/pickup problem) and will need to be serviced.
Apr 22, 2007 | Emerson MS3103 Shelf System
Emerson ES769 CD Shelf System Logo
43 people viewed this question
Top Emerson Audio Shelf Systems Experts
Level 1 Expert
Are you an Emerson Audio Shelf System Expert? Answer questions, earn points and help others
