Question about Honda Em1600x, 1800x, 2200x, Eb2200x Generator Parts Catalog
How do I remove oil from a Honda eb2200x generator
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
My EB2200X generator won't generate electricity
Check output on diode pack on the back of genny maybe stuck or brushes need replacing.
Oct 15, 2014 | Honda Em1600x, 1800x, 2200x, Eb2200x...
My honda 2000 generator only runs for about 3 seconds then shuts off
Its sure that its missing oil at the engine.Modern engines have a oil alert dispositive. Check oil level,if it is low,just fill with more oil at carter engine.
Sep 03, 2014 | Honda EU2000IKN EU 2000 Watt Generator 50...
Honda EB3000c generator won't start?
Three of the most common causes for this would be:
- A worn spark plug (solution: replace spark plug)
- A clogged fuel filter (solution: clean or replace filter)
- Oil level too low/high (solution: check level, add or remove oil)
There are many videos available online that should help you fix this yourself. If none of these help, you should take the generator to your local dealer/shop.
Sep 16, 2013 | Honda EB3000c Industrial Generator
It starts with the switch fine but when i let go of the key it cuts off
Check for faulty low oil sending unit or oil level low or dirty oil (some generators have a fuel cut-out solenoid at the carb ). Key switch will override the low oil safety. Easy test, remove wire from oil sending unit. If unit runs, and oil has not been changed in a while, service engine and retest.
Sep 09, 2011 | Mi T M MiTM Generator 9hp Honda 5000 Watt...
Honda 5000 generator clear oil out leaking thru air intake
There is supposed some oil in there. There is a tube to the carb intake that allows flow like a pcv valve
Oct 05, 2010 | Honda Mmd 5000 Watt Electric Start...
Honda 3000 eu no spark replace ing coil still no spark
Is there enough oil in the crankcase? Many generator ignition problems come from the oil level sensor. Either not enough oil or the sensor being bad.
Jul 21, 2010 | Honda 3000 Watt Portable Generator
The generator starts up then dies?
Check the oil pressure switch. It will shout you down like that if it doesn't sense oil pressure.
Oct 01, 2009 | Electrical Supplies
Honda 5.5 generator gas is filling oil compartment when not in us
turn the fuel off when not in use,it is going through the carb.to the oil.
Mar 17, 2009 | Honda 3000 Watt Portable Generator
Gas in the oil on my honda generator
Your needle/float is stuck, which will allow fuel to flow though the intake...past the piston..and into the crankcase. If has been awhile since you used it, most likely the gas has gummed up the insides of the carb. Otherwise, you may have had something get into the fuel bowl that is keeping the needle from closing. Best way to solve is to remove and clean the carb. Replace fuel filter if needed also.
Hope this helps
Mar 11, 2009 | Honda 3000 Watt Portable Generator
Honda Em1600x, 1800x, 2200x, Eb2200x Generator Parts Catalog Logo
49 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
