Question about Frigidaire FGQ332ES Gas Dryer
I have a frigidaire gas dryer crgr5700as2 i need to replace the door switch but not sure which wire goes with which prong
  • Official Brand Answer
  • 4,342 Answers
Hello - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. Typically this is something that you want a certified professional to install for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
Posted on Oct 31, 2012
jsrock516
  • 5911 Answers
SOURCE: changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Posted on Nov 11, 2008
  • 14 Answers
SOURCE: Frigidaire Gas Dryer - Heats for 1-2 minutes then gas shuts off
Most of the time, the culprit is a bad gas valve coil(s). Replace those, and your dryer should return to normal operation.
Posted on Jan 25, 2009
protek480
  • 1714 Answers
SOURCE: Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Posted on Jul 11, 2009
Maytag317
  • 1136 Answers
SOURCE: CHANGING DRYER CORD
All you need to do is, attach the middle connection from the cord to the middle post on the dryer. The 2 outside connections on the cord will attach to the outside posts on the dryer. It does not matter on the outside connectors as far as which side they go.
Make sure they are fastened down tight. If the connections are loose at all, they will go bad.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 23, 2009
hektor1961
  • 70 Answers
SOURCE: I NEED HELP CHANGING CORD TO A 4 PRONG ASAP!!THANKS
My friend:
  1. With the appliance UNPLUGGED, remove the access panel on the back of the unit where the power cord enters.
  2. With the cover removed, you will see a terminal block where the power cord is attached. The terminal wires will be colored with the WHITE wire in the middle, and the BLACK and RED wires on either end. NOTE: There should be a green jumper wire or metal bonding strap attached to the NEUTRAL (white) terminal wire.
  3. Remove the terminal lugs holding the old power cord wires in place. CAUTION: Use care not to drop any nuts or screws inside the appliance.
  4. Remove the bonding strap or ground wire from the Neutral terminal lug. NOTE: If disconnecting a ground wire, make sure you re-attach it to the appliance frame.
  5. Loosen the screws on the strain relief connector that holds the power cord in place and remove old power cord. NOTE: If your appliance does not have a strain relief that clamps down and hold the power cord in place, it is highly recommended that you install one. This prevents chaffing of the power cord against the appliance casing, and prevents the terminal wires from being pulled and broken loose. This could pose a potential shock hazard or cause damage to the appliance.
  6. Install new power cord by threading it through the strain relief connector and tighten down the screws.
  7. Connect the new power cord to the corresponding colors at the terminal block (Black goes to Black, Red goes to Red, White goes to White). The difference is going to be a Green (ground) wire that will connect to the appliance frame. There’s usually a green grounding screw for this. NOTE: If you disconnected a green grounding strap in Step 4., you can connect these two wires at the same point.
  8. Re-install access cover. Turn off the service breaker to the appliance PRIOR to plugging it back in. With the breaker in the off position, plug the appliance in, and THEN turn the breaker on. In the event, something was wired incorrectly, it is far better to have your hands away from the receptacle and controlled from a distance. Safety first
Posted on Aug 17, 2009
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
Got my mom's Frigidaire dryer. She had a four prong. My home is older so I have to switch out to a 3 prong cord. I am not sure what to do with the wires or how to properly connect it.
you must change your home to a 4 prong. L1 L2 Neutral and ground..
this is 240 so dont mess with unless you are sure you can work on it or call a electrician
Please rate/vote the response Thanks
Dec 20, 2010 | Frigidaire Dryers
Same dryer but I need to switch to a 4 prong cord.Please help!
WARNING! I believe you want to replace a 110V-120V plug with a 220V. Don't do it until you know for sure. Sounds dangerous! Not an expert, just some free advice from a novice.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My washer door isnt staying locked
Your probably need to replace the door striker (two pronged plastic prongs) thats attached to the door with two screws, or, the door switch. The door switch can be accessed by taking off the top lid and removing the two screws in front of the machine. The switch is a whole lot more expensive than the striker. Be sure to pay attention on how the switch is wired!
Jun 04, 2009 | Frigidaire Affinity ATF7000E Front Load...
GE Dryer not producing heat
First, replace the door switch. Second, check the wiring of the new cord. It should be as follows:
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Third, if you still have no heat, make sure there is strong air flow out the vent outside the house when the dryer is running. If all that is good, check for 240 volts to dryer. (dryers can run the motor on 120, but need 240 to heat). Comment back (including model number) if you have further questions.
May 22, 2009 | LG DLE7177 Dryer
Aug 14, 2008 | Frigidaire FGR231A Gas Dryer
Frigidaire FGQ332ES Gas Dryer Logo
46 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
