Question about Homelite 2-cycle Engine Generators Parts Manual
What type of oil does the Homelite HG 5000 generator take
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Our Homelite model 5500 generator
The problem when that happens is usually a loss of residual magnetism...by flashing the generator you can recharge the permanent magnets, and then the generator will work again.
Generator Flashing
This link gives one way to do it.. there are others if your google it...look a few posts down to find the procedure...
heatman101
Posted on Jun 08, 2011
  • 57 Answers
SOURCE: generator been sitting for a
Remove carb bowl, clean . Stem on fastener my b clogged, take needle clear holes at bottom of stem and through top of stem.
Posted on Sep 04, 2011
I have a homelite 5000 watt portable generator that starts to run for like 5 seconds and then just stops
check sump oil level
check oil level sensor that switches off the engine if the oil is to low
check fuel flow through the tap as they corrode internally and block the flow
Dec 31, 2016 | Electrical Supplies
What oil wieght oil does the powermate 5000 use
a 10-30 multi weight oil should work fine, in the winter, if it gets cold there, a 5-30, if it gets super hot in summer, a 10-40
Mar 10, 2013 | Coleman Powermate Portable Generator...
I have a hg 6000 homelite generator, runs great but does not give me any power. i used it a year or so ago an everything worked fine. got a lil smoke from where windings are. the generator was made in...
Hi and welcime to FixYa. I am Kelly
This is going to sound odd but.... this is how it it is recommended to field flash and inverter type generator. (Brushless) The steps are to (not kidding...) use a male mail interconnecting wire from your house wiring and plug in your generator and turn ON the main CB for 1 minute.
If this does not work.... See steps below amnual links.
Owners manual link: (Click on get manual)
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/hg6000_1.html
Or try this direct link:
http://lawnandgarden.manualsonline.com/support/homelite/portable-generator/request-manual-299128
This is a brushless generator... Not sure what the smoke was but... the yellow wires are for the capacitor winding. If you probe the capacitor terminals with one of the wires disconnected with a meter on R x 10,000 you should see a brief jump in resistance and then the meter drifts to infinity.
reverse the test leads and test again looking for the same result.
Next read resistance Yellow wire to Yellow Wire (Stator capacitor loop check) It should read low resistance
Also read Brown wire to Brown wire. This is the DC stator loop check. Is should read resistance.
Main winding checks Red to Blue and White to Brown that goes to the main breaker. OR Turn the Main breaker on.. White to lower left pin of 30A 4 pin output recepticle. Bot red to blue and White to Brown MUST read low resistance
These are all the checks except the rectifier and the rotor. You will probably find something during the above tests. If not... respond here and I will pass on the rotor and diode tests.
Kelly
Aug 27, 2011 | Electrical Supplies
My 5000 watt Homelite Generator will start on the first pull but then runs for about 2 to 5 seconds and dies or it gets rough and then dies. I have cleaned the carburator and checked the full line for flow...
If you have an oil level switch on this generator, it could be that you have low oil level or the switch is bad. Check the oil level. Bypass the oil level switch.
How old is the fuel in the tank, and how full is the tank? Fuel goes bad with time due to the ethonol turning to gummy varnish like substance. Not keeping a tank full allows condensation to form on the inner walls, contaminating the fuel with water. Drain the tank completely and fill with new gasoline.
How did you "clean the carb?" If it was not completely disassembled, soaked in carb cleaner, and all jets and ports blown out with air, you could have blockages from the "bad gas."
BigDaddyPat
Jul 20, 2011 | Pramac 5000 Watt Generator
I have a homelite 240-hg I cant get it started i
Try some starter fluid (eather) that wil give you an indication if it's ignition or a fuel problem.
Feb 28, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Need oil type for generator & motor for 5000 power mate
Unless you're in very cold locations use SAE 5W30 regular motor oil.
Dec 03, 2008 | Coleman Electrical Supplies
Homelite 2-cycle Engine Generators Parts Manual Logo
212 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
