Question about Hotpoint Washing Machines
How do I remove the agitator?
I have a hotpoint washer that has a cotton belt under the agitator and I can't get the agitator out to remove the belt. It pulls other clothes under. It has no screw on top, I have tried WD-40 and wedges but it will not move. Help please.
  • paulac620 Jan 04, 2009
    I don't have a model #. The machine has a metal wash basket with the white plastic agitator. I picked it up at a yard sale about 3-4 years ago.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    What is the model number? Or at least, does the machine have a white plastic inner wash basket or a metal one? (less than 15 years old?)
  • 1,543 Answers
Technically, the agitator should just pull straight up and off. Realistically, that just might not be that easy. There is an agitator puller. If you take the small plastic cap off the top of the agitator (if it is still there) you then slip a metal ring over the top of the agitator and tighten down three set screws into the plastic on the side of the agitator, near the top. (biteing into the plastic, but not enough to crack the agitator) Then, a pull collar is hooked over the edges of the pull collar and the center of the puller goes right down the center of the agitator (right on the center of the transmission shaft) Perhaps you could fashion your own pull collar. Your machine is well over the average life of a washer, so I wouldn't worry too much about damage to it. It may be time to invest in a new machine soon. Please don't bother rating, as anything but a Fix-Ya drops my score. Good luck with your repair.
Posted on Jan 04, 2009
I have a new Hotpoint washer (top load) model HTAP1200DWW i have a string stuck under the agitator. I removed the top cap on agitator but there's another plastic cup a little lower down the shaft. My...
Most just pop out. If you can get your fingers from both hands at 3 and 9 o'clock under agitator and pull up quickly and firmly, it should pop out.
Aug 25, 2017 | Hotpoint Washing Machines
Need to make spin the agitator on a Hotpoint Heavy Duty Washer
Drive belt broken call GE Parts for new belt , They stock for all makes ,,
Aug 17, 2012 | Hotpoint Washing Machines
Can't remove agitator on hotpoint washer
I have this same model of Hotpoint washer. I pulled up on the agitator and that separated it from the hub. I removed the hub by loosening the bolt at the top of the hub with a socket wrench. I removed the hub after removing the bolt. I removed the long stringy fabric by unwinding it and lifting up. that's all there is to it. Really simple. Everything went back together very easily. Only hard part is lifting the agitator up with enough force to free it from the hub.
Aug 10, 2012 | Hotpoint Washing Machines
My hotpoint washer will spin but will not wash or rinse, the agitator makes a noise as it attempts to wash and then rinse. the spin seems to work fine
The agitator shaft has splines at its top which fit inside a splined area inside the agitator. Sometimes the splines in the agitator strip; then you would need a new agitator. If that is not the case the problem is within the mechanism. There is a repair kit available for that, but you need to take the mechanism out of the machine. I am assuming that you have the "direct drive" machine, recognizable by the pump sitting at the front, in the middle, under the tub. If you have the older, belt driven washer, please get back and I will explain.
May 09, 2011 | Hotpoint Washing Machines
Need to remove the agitator asm on a hotpoint model VBXR1090B2CC
make sure washer is empty no water no clothes ... this one is not funn even for a technician sometimes dosent like to pull off.... grab bottom of agitator with either your hands and pull upward at very bottom base be carefull not to pull so hard that you slam the agitator top into your chest ... i have taken my belt in some stubborn situations slidding under agitator and pulling upward with my belt to get more thrusting upward action the also make an inflatable innertube tech tool that u put under the agitator and inflate to pop agitator off
Jan 24, 2011 | Washing Machines
Fills with water..doesn't wash..drains and spins..does the transmission spin in direction and wash in the other? in other words does the motor run one direction to spin and rev. to agg/
Yes it does reverse. If the motor is running in agitate pull off the agitator and check the agitator drive (bell) (white plastic bell shaped) on top of the agitate shaft is not stripped. You should not be able to turn. To remove the agitator fill first about 8 in of hot water, drain and pull up on agitator with fingers under the bottom or a belt.
Nov 22, 2010 | Hotpoint -Ariston VVSR1030HWO Top Load...
Hotpoint washer will not agitate. How do test the time? the lid switch is OK.
Check the belt and motor brushes. Belt may have come off or snapped and if motor brushes are getting worn they may not be making enough contact in the motor to make it agitate.
Feb 14, 2010 | Hotpoint VBSR3100GWW Top Load Washer
How do you remove the agitator from a top load washing machine? model VBSR3100WW
Simply pull up very hard it will come loose. You might want to try and old leather belt or strap under the agitator and pull up.
Jul 12, 2009 | Hotpoint VBSR3100GWW Top Load Washer
Roper washer
Just cut the strap out. It will be much cheaper to cut a silly strap than to need a repair person or ruin the seal in the agitator. this is not a problem worth fooling with. you must be a female.
Nov 05, 2008 | Roper RAS8445KQ Top Load Washer
Hotpoint washer
Two types of Hotpoints had two different ways of removing the agitator. One had a pop off top that when you removed it, you can remove the center bolt, the remove the agitator. Another one you had to put your fingers under the agitator and pull straight up to unclip the agitator. Good Luck!!! Jim
Sep 04, 2007 | Washing Machines
Washing Machines Logo
111 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
