Question about John Deere 650 750 850 655 755 855 955 670 770 870 970 Attachment Tech Manual
I am changing motor mounts on a JD 755 and am having problems removing and installing the starter because of the close tolerances.
How to change motor mounts and a starter on a John Deere 755.
SOURCE: john deere 316 belt
I am so far from expert...me answering this surprises me. However, I can...JD Small Engines has plenty of diagrams for the 316. Here's how a old single lady changes the belt on her 85 316. There is a bolt running from side to side of a black metal box...on the very front at the bottom of the mower below the grill. If you pull that out, just the front of the mower deck separates from the mower..slip the belt in and around the rear central pulley. Put the pin back in with the belt now around the back pulley and outside the part where the pin goes back in. Get a pneumatic tire jack and jack up the right (your left as you face the front of the machine) front pulley..try to catch the pulley armature or bolt so you don't torque the pulley. This releases the tensioner...thread the belt on the right pulley and reach up under the grill and put the belt over the front engine pulley....now all that's left is to get the belt over the left pulley. At this point, I remember having to either lower the deck to the ground or raise it up all the way...to the ground, I think as it wasn't already in the correct position. Once you start fussing with the left pulley, you will see it is spring loaded and easy to force the belt over if the right pulley is still on the jack. Really important to get the belt inside all the belt guides and lowering the deck before you frustrate yourself with getting the belt over the last pulley. When all is done, release the jack and everything tightens right up.
Posted on Jun 10, 2009
wireguy212
  • 1627 Answers
SOURCE: how do I change the temp gauge on a john deere
The temperature gauge is built into the instrument cluster and it needs to be changed as a unit.Try removing the wire from the temperature sensor and ground it to the frame of the tractor to verify that you do need the instrument cluster replaced,ground that wire will drive the gauge to hot if the gauge is good and nothing will change if it is defective.If grounding the wire made it work then you need a temperature sensor.Good luck and let me know how you make out!
Posted on Jan 02, 2010
wireguy212
  • 1627 Answers
SOURCE: need the pto to work on a 6300 john deere tractor
If you have tried a new sensor and a new switch the the next step is to replace the pto solenoid valve.If that proves fruitless then the b.c.u.needs to be replaced or bypassed.The solenoid valve will cure your problem 90% of the time.If that does not work,let me know,i can tell you how to by-pass the b.c.u..
Posted on May 08, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
Daniel S
  • 4323 Answers
SOURCE: John Deere Model 445 garden
Hi
Please check for the anti back fire solenoid in the front of the carb. Check whether the wiring to it is fine and if it is getting +12 V. If yes then you maybe required to replace the solenod.
However, if this doesn't resolve the issue then you would need to adjust manually so that decompresser works normally. Inspect the flywheel key as well, it may have sheared.
Check the carb filter and the make sure there is no sign of water in/around the carbeurater. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 05, 2010
Trying to change a stater cant find the bolts on top
the top bolts come in from the rear of the bell housing. They these bolts mount both the bell housing to the block and the starter motor to the block. Under neath just line up wich mount bolts are close to the starter and undo them, possibly 2 that hold them. once remove starter should fall straight into your hand
Jan 22, 2011 | 1997 Ford Expedition
How do i change the starter on a 1997 buick park avenue?
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the service precautions in the beginning of this section
  2. Disconnect the battery negative cable
  3. Raise and support the vehicle
  4. Remove the transmission cooler line clip if necessary
  5. Remove the torque converter cover
  6. Disconnect the battery positive cable from the starter
  7. Disconnect the wire from the starter solenoid S terminal
  8. Remove the 2 starter motor mounting bolts and the starter motor
To Install:
  1. Install the starter motor
    • Torque the mounting bolts to 32 ft-lbs (43 Nm)
  2. Connect the battery positive cable to the starter
    • Torque nut to 12 ft-lbs (16 Nm) (1997-2000);
    • Torque nut to 89 in-lbs (10 Nm) (2001-2005)
  3. Connect the starter motor S terminal wire
    • Torque nut to 22 in-lbs (2.5 Nm)
  4. Install the torque converter cover
    • Torque the bolts to 115 in-lbs (13 Nm)
  5. Attach the transmission cooler line clip
  6. Lower the vehicle
  7. Reconnect the negative battery cable
Dec 09, 2010 | Buick Park Avenue Cars & Trucks
How to change a 1991 cadillac seville starter
I will paste instructions from autozone.com below, but recommend you also read thru my post at http://www.fixya.com/cars/r5973094-starter_replace and let me know if you have questions.
4.5L and 4.9L Engines
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle securely on jackstands.
  3. Remove the starter motor shield.
  4. Remove the exhaust front and rear pipe assembly.
  5. Remove the flexplate inspection cover.
  6. Disconnect the solenoid 'S' terminal nut and battery cable nut.
  7. Unbolt the starter motor mounting bolts, and remove the starter motor.
Fig. Later model starter location and mounting on the 4.9L engine
To install:
  1. Install the starter motor, and tighten to 32 ft. lbs. (43 Nm).
  2. Install the solenoid 'S' terminal nut. Tighten the nut to 35 inch lbs. (4 Nm).
  3. Install the battery cable nut and tighten to 12 ft. lbs. (15 Nm).
  4. Install the flexplate inspection cover, the front and rear exhaust pipe assembly and the starter motor shield.
  5. Lower the vehicle.
  6. Connect the negative battery cable.
Nov 01, 2010 | 1991 Cadillac Seville
Where is the starter on a 1999 s-10
passenger side, under exhasut pipe, against motor, close to tranni.
Jul 17, 2010 | 1999 Chevrolet S-10 Pickup
I want to know how to change a starter on a 2000 chevy malbu 6 cyl. car.
jack up car, remove splash sheild, if equipped. disconnect the wires from starter motor,remove starter mounting bolts. installation is reverse of removal. TOOLMAN,
Jan 29, 2010 | 2002 Chevrolet Malibu
How to change a starter motor
Disconnect battery, remove and mark wires and cable taken off starter, remove the 3 mounting bolts and remove starter. It looks like two bolts come from other side and bolt into starter and 1 bolt goes thru the starter into the bell housing/motor. Do the oposite to install. Here is a picture of your starter and a good place to purchase it. Wish you luck.
http://www.partsgeek.com/catalog/1993/ford/festiva/engine_electrical/starter.html
Jan 25, 2010 | 1993 Ford Festiva
How do you change the starter on a 96 town and country
  2. Raise and safely support the front of the vehicle securely on jackstands.
  3. Disengage the solenoid wiring connector from the terminal. This connection may be held in place by a retaining nut, or it could be a push-in connector.
  4. Remove the B+ nut and wire from the starter motor terminal.
  5. Remove the starter motor-to-transaxle bellhousing mounting bolts.
  6. Remove the starter from the vehicle. If equipped, remove the starter motor spacer.
To install:
  1. If equipped, hold the starter motor spacer in position.
  2. Install the starter motor into position on the vehicle.
  3. Install the starter motor-to-transaxle bellhousing mounting bolts. Tighten the mounting bolts to 40 ft. lbs. (54 Nm).
  4. Engage the solenoid wiring connector onto the starter terminal.
  5. Connect the B+ wire and tighten the retaining nut to 90 inch lbs. (10 Nm).
  6. Lower the vehicle.
  7. Connect the negative battery cable.
  8. Verify starter motor operation.
Posting pics on next post!
Oct 18, 2009 | 1996 Chrysler Town & Country
How to change starter on 2000 chevy silverado
These instructions are for a 5.3L. Unless it is a V6 or diesel, the instructions will be similar if you have a different gas V8.
  2. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  3. Remove the protective shields as necessary.
  4. Remove the starter solenoid shield.
  5. Remove the starter to transmission close out cover bolt.
  6. Disconnect the engine oil level sensor connection.
  7. Remove the front axle mounting bracket through bolt nut, if equipped with four wheel drive (4WD).
  8. Reposition the front axle mounting bracket through bolt until the bolt tip is flush with the support bushing. Do not remove the bolt, if equipped with 4WD.
  9. Remove the mounting bolts from the engine block.
  10. Slide the starter forward until the starter clears the transmission.
  11. Remove the starter transmission close out cover
    1. Disconnect the positive battery cable and wiring harness from the starter.
    2. Remove the starter from the vehicle.
      1. Connect the positive battery cable to the starter. Tighten Tighten the nut to 16 N.m (12 lb in) .
      2. Install the starter transmission close out cover.
        1. Install the mounting bolts to the engine block. Tighten Tighten the bolts to 50 N.m (37 lb ft) .
        2. Reposition the front axle mounting bracket through bolt until the bolt is fully seated. if equipped with 4WD.
        3. Install the front axle mounting bracket through bolt nut, if equipped with 4WD. Tighten Tighten the nut to 90 N.m (67 lb ft) .
        4. Disconnect the engine oil level sensor connection.
        5. Install the starter to transmission close out cover bolt.
        6. Install the starter solenoid shield.
        7. Install the protective shields as necessary.
        8. Remove the safety stands.
        9. Lower the vehicle.
        10. Connect the negative battery cable. Tighten Tighten the bolts to 17 N.m (13 lb ft) .
Oct 01, 2009 | 2002 Chevrolet Silverado
Changing starter on 97 geo metro 4 cyl 1.3
According to the tech maual, you get at it from underneath...these are the steps....removing the tire may help in having the "extra room".
  2. Raise and support the vehicle safely.
  3. Label and disconnect the starter solenoid electrical connector.
  4. Remove the mounting bolts from the starter motor, then carefully lower the assembly from the vehicle. To install:
  5. Install the starter motor assembly complete with any shims that may be used between the engine block and the starter.
  6. Install and tighten the starter mounting bolts to 17 ft. lbs.. (23 Nm).
  7. Connect the starter solenoid electrical connector.
  8. Lower the vehicle and connect the negative battery cable.
Aug 27, 2009 | 1997 Geo Metro
Changing the starter on my 99 tahoe
Starter Escalade, Suburban, Tahoe, Yukon, Denali, Denali XL, Yukon XL, 1999 – 2005 REMOVAL&INSTALLATION
4.8L, 5.3L And 6.0L Engines
CAUTION Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures.
  3. Remove or disconnect the following:
    • Protective shields, as necessary
    • Starter solenoid shield
    • Starter-to-transmission close out cover bolt
    • Engine oil level sensor connection
    • On 4WD, front axle mounting bracket through bolt nut
  4. Reposition the front axle mounting bracket through bolt until the bolt tip is flush with the support bushing. Do not remove the bolt.
    • Mounting bolts from the engine block. Slide the starter forward until the starter clears the transmission.
    • Starter transmission close out cover
    • Positive battery cable and wiring harness from the starter
    • Starter from the vehicle 0900c152800a6916.jpgStarter removal—4.8L, 5.3L and 6.0L engines
To install:
  1. Install or connect the following:
    • Starter
    • Positive battery cable to the starter. Tighten the nut to 12 ft. lbs. (16 Nm).
    • Mounting bolts to the engine block and tighten to 37 ft. lbs. (50 Nm)
    • Front axle mounting bracket through bolt nut and tighten to 70 ft. lbs. (95 Nm)
    • Protective shields as necessary
  3. Remove the safety stands.
  4. Lower the vehicle.
  5. Connect the negative battery cable.
5.7L And 7.4L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Mounting bolts and shims
    • Wires
    • Heat shield
    • Starter
To install:
    • Starter
    • Wires. Torque battery wire nut to 89 inch lbs. (10 Nm), and ignition nut to 18 inch lbs. (2 Nm).
    • Heat shield. Torque the bolts to 53 inch lbs. (6 Nm) and the nuts to 35 inch lbs. (3 Nm).
    • Mounting bolts and shim. Torque the bolts to 33 ft lbs. (45 Nm).
6.5L Engine
    • Negative battery cables
    • Mounting bolts/nuts and shim, if used
    • Starter
    • Wires
    • Heat shield and bracket 0900c152800a6917.jpgExploded view of the starter motor—6.5L engine
To install:
    • Heat shield and bracket. Torque the bolts to 13 ft lbs. (17 Nm).
    • Starter
    • Mounting bolts/nuts and shim, if used. Torque the bolts to 33 ft lbs. (45 Nm) and the nut to 75 inch lbs. (8.5 Nm).
8.1L Engine
  1. Remove or disconnect the following:
  2. Reposition the front axle mounting bracket through bolt until the bolt tip is flush with the support bushing. Do not remove the bolt.
    • Positive battery cable nut
    • Positive cable from the solenoid
    • Engine harness ground nut and ground from the solenoid
    • Mounting bolts and starter
    • Heat shield bolts, nut and shield, if necessary
To install:
    • Heat shield, bolts and nut if removed. Tighten the bolts to 35 inch lbs. (3 Nm) and the nut to 44 inch lbs. (5 Nm).
    • Starter and bolts. Tighten to 37 ft. lbs. (50 Nm).
    • Ground wire and nut. Tighten to 30 inch lbs. (3.4 Nm).
    • Positive cable and nut. Tighten to 80 inch lbs. (9 Nm).
Sep 28, 2008 | 1999 Chevrolet Tahoe
John Deere 650 750 850 655 755 855 955 670 770 870 970 Attachment Tech Manual Logo
352 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
