Question about Raypak Spapak Electric Spa Heater - Els1102 - 2 - 11 Kw
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
I want to change out a broken H400ID propane fueled pool and spa heater with an electric heater for the spa only. What issues would be involved with changing out this old unit and connections?
  • 5,089 Answers
Hayward has manuals for each type heater, gas and electric.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
Posted on Nov 26, 2012
johnsonr1
  • 91 Answers
SOURCE: pool heater wont fire up
Its just after 1 am here as well, Ontario Canada. Yes, you have to remove the front lower panel by raising it then pulling out at the bottom. Then compare the valve you have with the 2 in the picture on pg 5. If it is easier, you can have your husband call me while doing this and I can talk him through it. My contact information is located on the main page of my company website www.emshvac.com
Thanks
Richard
Posted on Jun 23, 2009
SOURCE: I have a Raypak pool heater the pilot will lite but the unit will
My Rapak gas pool heater burner will not ignite. I changed the flame sensor and then the main gas valve (on a recommendation of a heating contracter) and after spending almost $300 on parts, I may have not needed, it still will not ignite. The water temp has been around 80 using the solar cover but now with the air temp in the 50's at night and only in the 70's in the day the water is a brisk 70 degrees. We would like run the heater now, so we can use the pool for a bit longer this fall.
Any ideas? Some people told me there is a valve that senses the proper amount of water is flowing around the boiler so it doesn't burn up, is this possiblely the problem that the valve is not opening?
Joe Snyder, Toledo, Ohio
Posted on Sep 09, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
  • 990 Answers
SOURCE: I have a Raypak model 153 pool heater. The heater
For some reason your heater is not recognising the flame when it goes on. The biggest reason for this will be small spider webs in the burner orfaces. These are on the main gas manifold where it connects to the burners. You can get a small wire and bend it to go in these orfaces but the first time you do this it will probally be easer to pull the tray and remove the orfaces from the gas line. Good luck, I hope this helps.
Posted on Nov 28, 2009
john224
  • 1378 Answers
SOURCE: My raypak versa spa heater was making a loud sound
Part one - The 'whoosh' or 'boom' at ignition. If those sounds describe your start up your jet(s) are clogged along the gas manifold. Follow the pipe out of the gas valve down to where the gas is shot into the heater. Those bronze ports have a small opening and spiders like to nest inside this area. Turn them out of the manifold and inspect them. You should find those closest to the ignitor are clogged causing the delay and then boom of ignition.
Part 2 - Have this happen enough and the roll out switch / fused link along the bottom of the heaters service panel will open up and disable the heater. It will look like a black rubber tube about 1/4 diameter by about 2 inches long -OR- a white ceramic block about the diameter of a quarter; either will have 2 wires to it and it will be 'close' to the manifold and jets you need to clean out. If you have a way to read resistance across this switch remove the wires from it and check it. If it is open it will need to be replaced.
Posted on Dec 16, 2009
My hyward H400ID won't ignite green light comes on for few seconds and then goes off. Need help
There are many questions needing answered. Is the fan coming on, if not it could be the fan proving switch. If the fan is coming on but the heater does not light there should be a code on the heater. I added a link to the manual for this heater. http://www.hayward-pool.com/pdf/manuals/H-seriesLowNOx-H250IDL2-H350IDL2-H400IDL2.pdf
Sep 21, 2014 | Pool & Spa
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
Aquapod doesnt sync with heater any more
what type the heater is communicating to aqualogic control is RAYPAK digital 2100 ? also go to outside where the aqualogic control is and look for diagnostic in control look for water temperature sensor connecedt to aqualogic and see what that say,
Jun 15, 2013 | Hayward Pool Products Aqua Pod
Im a new pool owner and I have a Hayward H400ID heater, It was working great just a couple of days ago and now it will not turn on. I get a system normal light... but when I switch from off to spa/pool...
Many things without more info, but if your new at this let's go with simple. Make sure your baskets are clean and your filter is clean. Without proper water flow the heater would overheat and boil the water inside. Because of this it has safty switches to stop it from running when things get dirty. Good luck and let me know how you do.
Apr 18, 2010 | Hayward H Series Pool & Spa Heater 400k...
How do you set a spa heater to heat the water over 104 degrees?
Sorry set by law and a ery good one to boot. Even if you are the one to reset the manufacture would still assume liability. Heater and thermostat manfacture would both be liable for death or stroke and they try their best to avoide this. So sorry no they have done their best to avoide someone getting hurt or dead.
Mar 06, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak Spapak Electric Spa Heater - Els1102 - 2 - 11 Kw Logo
123 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
