Question about RCA RCU410W Remote Control
My RCRPS06GR does not have a timer or sleeper key, how can I set it up?
My remote does not have a timer or sleeper key, how would I be able to set it up?
Where can I get instruction manual?
The Owner's Manual and Code List for the RCA RCRPS06GR universal remote are available on the product page: http://www.rcaaudiovideo.com/remotes/4-5-devices/?sku=RCRPS06GR . Click on the Support/Manuals tab. The current direct link to the English language version of the manual is http://www.rcaaudiovideo.com/docs/common/RCRPS06GR/RCRPS06GR_OM.pdf .
I hope this helps.
Jan 22, 2016 | RCA Rcrps06gr Universal Remote
What is code for Philips HTL1170B soundbar?
You can use the CODE SEARCH feature to try to find something that will work. If a search through all codes stored in the remote fails, you may have to try a different universal remote, such as a Philips. All universal remotes do not store all possible codes.
Jan 10, 2016 | RCA RCRPS06GR rcrps06gr 6-device universal...
Wich is subtitle buttom fo rca rcrps06gr?
Closed captioning (CC) is enabled/disabled as part of the initial set up process. Subtitles are included in some material and cannot be added or removed.
Dec 13, 2014 | RCA Televison & Video
Rca remote code for maxent
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 11, 2014 | RCA RCRPS06GR 6-DEVICE UNIVERSAL REMOTE
CONCERTONE
This remote control have no set-up codes to this brand TV. If you wish to get more details, check this link. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 02, 2013 | RCA Televison & Video
Program RCRPS06GR for Roku
My roku stick remote broke and I want to program my universal remote RCA rcrps06gr to program roku can I program it
Jan 28, 2013 | RCA RCRPS06GR 6-DEVICE UNIVERSAL REMOTE
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
My tv keeps turning on by its self. At night I use the sleep timer a lot, but I do not know if that's why it turns on randomly?
Yes,tv it will turn on and off randomly,if sleeper timer mode is on,u probally setup for both OFF and ON setting same times like 30,60,120 mins setting is on.
Aug 07, 2011 | Quasar VV-1311W 13 in. Combo
Why does my Indignia television turn on by itself in the middle of the day or night?
Check ur tv menu make sure ur tv is it not on a timer setting.And Sleeper mode is not on like 30,60,120.Turn off the tv timer if it on,and the sleeper mode should be off too.
Jun 18, 2011 | Insignia 19 in. Widescreen Flat-Panel LCD...
RCA RCU410W Remote Control Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
