Question about Ricoh Aficio 3025P Black and White Copier
How do I reset paper tray for ricoh c 5501? - Ricoh Aficio 3025P Black and White Copier
SOURCE: Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
Posted on May 21, 2009
  • 990 Answers
SOURCE: it says to reset paper tray. How do i reset it?
Hello sir; On the left top on your cintrol panel there have a key said "user mode", press this key,then touch on screen "copier setting" then looking for tray setting , reset all tray,.
Posted on Jul 13, 2009
M2Tech1
  • 313 Answers
SOURCE: false ricoh 1224c paper jam warning
check tthe clips retaining teh feed rollers havent sliped off if it isnt picking up from tray take the tray at top out and then watch from above to see if the rollers are turning to feed paper.. if the lifts out check the side door guide isnt out of plavce check the end paper guides as well//check when you take the tray out look to see there is any paper stuck at the back where the tray sensors ares can cause a lift motor error aswell
Posted on Jul 31, 2009
  • 1294 Answers
SOURCE: Ricoh Aficio 240W is limited to bypass tray use
Enter into service mode:
1.Press the clear modes key.
2.Enter 1-0-7.
3.Press the clear/stop key for more than 3 sec until the service program menu appears on the touch panel.
Select paper tray setting,and set the new value.
Posted on Aug 02, 2009
  • 20 Answers
SOURCE: ricoh 1515. paper out light comes on continually
The lights are misaligned with the paper, meaning that it doesn't sense the paper.
Sensor problem.
Posted on Feb 16, 2010
Ricoh MPC 3503 fails to recognis paper in tray 2. what could be the reason
There is a paper high sensor that might not be working . Try to restart the machine with the paper tray open to reset all tray sensors . If that does not work you are probably going to need a tech to make sure all paper sensor are working .
Aug 14, 2016 | Ricoh Aficio Office Equipment & Supplies
Reset paper tray
Need to know model of copier
Jan 14, 2014 | Ricoh Office Equipment & Supplies
C-0102
The 1xx code refer to main body papre tray lift motor error.Check the paper jam in rear side to open the trays.To reset press the Utility key and hold on and turn ON the copier,wait will appaire Trouble reest on the display,release the Utility key,touch the screen and turn OFF the machine.Wait 2 minutes and turn ON.
Mar 05, 2013 | Konica Minolta bizhub Office Equipment &...
Reset paper tray in RICHO Aficio 2045e
Manevrating the paper tray button(green) in correctly paper size position.
Jan 04, 2012 | Ricoh Office Equipment & Supplies
Ricoh Aficio 240W is limited to bypass tray use only. Cannot set it to recognize the paper tray. I've seen the tech's reset it.
2.Enter 1-0-7.
Jul 29, 2009 | Ricoh Office Equipment & Supplies
It says to reset paper tray. How do i reset it?
Jul 13, 2009 | Ricoh Office Equipment & Supplies
False ricoh 1224c paper jam warning
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Feb 13, 2009 | Ricoh Aficio 1013F Copier
Paper jam E light won't reset in Ricoh A423
hi im jules_09,look for thr microswitch or sensor in the tray try cleaning it with alcohol just soak with alcohol if that doesnt work replace the sensor or microswitch
Dec 10, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio 3025P Black and White Copier Logo
287 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
