Question about Winix WDH751 Dehumidifier
Winix model wdh851 leaks when pump runs
Had for about 6 mo. and work great but it just started to leak when the pump runs to empty the tank
Does not shut off when tank full, water leaks all over the floor if I don't watch it constantly
Sounds like the float valve inside tank may be stuck in closed position. Calcium buildup is very common. Good luck Juliana. Unplug and empty tank of any water and look for the float valve it should be near top of tank. Use a small bucket and mix vinegar and water and brush. Scrub that valve. Clean it up
Jul 13, 2016 | Windchaser Dehumidifiers
Noisy when opporating
depends on what is cause of noise, if a fan, something in it, or could be a bearing worn
Aug 08, 2014 | Winix 50 Pint Dehumidifier WDH851
Winix wdh851 service manual
The owner's manual is here: http://www.sylvane.com/media/documents/products/winix-wdh851-dehumidifier-owners-manual.pdf
but that's probably not what you want. You might try posting your specific issue that you need the service manual for. For instance a fan that won't start is a common problem for dehumidifiers and a cheap fix. If that is your issue read this: http://www.fixya.com/support/t3588983-lg_lhd65ebl_serial_603taac20984
The article is for an LG dehumidifier but the thermistor mentioned is common to most brands.
Jul 13, 2014 | Winix 50 Pint Dehumidifier WDH851
Float Switch
Contact there customer service at: www.sylvane.com 1-800-934-9194. you will need model number etc.
Feb 18, 2014 | Winix WDH751 Dehumidifier
Turns on but fan and compresser does not run
start relay on compressor fans will not work if pumps not running
Nov 16, 2013 | Winix WDH751 Dehumidifier
Manual winix p150
Hello, this is Ava with Think Crucial.
You may refer to this online manual for your model number to help you put back the filters in your unit.
Winix WAC P150 Owner Manual
You can purchase a wide variety of high quality Winix replacement parts for your Winix Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=winix
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 16, 2013 | Winix FresHome Model P150 True HEPA Air...
Maytag Dehumidifer still works, but is leaking
Well life span is 3-15 years depends how long and hard you run them. 45 pint is about 1000sqft basment. rule of thumbs bigger better. run less and do a better job. I would start by filling the bucket and place in a dry shower see if you have a crack. cant find a source for the bucket discontinued this might be your problem. http://www.repairclinic.com/SSPartDetail.aspx?s=t-M7DH45B2A-%3d%3di1025984&PartID=1025984 Repair cost are about 40-50 and hour!!!! good luck
Nov 01, 2009 | Maytag M7DH45B2A Dehumidifier
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
Dehumidifer stopped collecting moisture, blows air w/ empty tank
Possible cause it's out of gas.
you might have to get a refridgeration mechanic to regas it, or/and fix any gas leaks
Apr 02, 2009 | Maytag M3DH30B2A Dehumidifier
Amcor tc100 started to leak on the floor but is still working
Ive had same issue with this machine. i opened it up and cleaned the plastic channels leading into the tank. Dust can collect and block these channels, diverting the water onto the floor. This cleared that problem, but now the fan is not working, so im hunting for one going cheap...?
Jan 12, 2009 | Dehumidifiers
Winix WDH751 Dehumidifier Logo
51 people viewed this question
Top Winix Dehumidifiers Experts
Gil Shultz
Ken Wieczorek
Ken Wieczorek
Think Crucial
Think Crucial
Are you a Winix Dehumidifier Expert? Answer questions, earn points and help others
