Chigo QCIH24A split unit code E3 - Heating & Cooling
2 Suggested Answers
SOURCE: I have a Chigo Mini Split KF-32GW/A. What is
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
1、Check whether two sets of plugs on the outlet end of
the motor have loosed from the socket of the
electric control board, insert it firmly when loosing.
2、Check whether the indoor motor has damaged, the
motor should be replaced when it is damaged
3、 Check whether the controllable silicon and other
components on the electric control board have
damaged, replace the controllable silicon or electric
control board when they are damaged.
Posted on Jun 26, 2010
Voltas split a.c error code e3
http://errorcodeairconditioning.blogspot.com/2012/06/chigo-fault-code.html
LED
code = E3
explain = display at off state
LAMP DISPLAY
code = flicker 3/5 SEC
explain = display at on/off state
FAILURE = coil temp. sensor fault
The reason of fault and solution = 1 .Check whether the resistance of the sensor is normal
(the resistance is 5K? in the normal temperature 25°), when it is abnormal the sensor should be replaced.
2 .Check whether there is short circuit or open circuit in the wire of the sensor, and whether the plug is connected well,
3.When the 1 and 2 are both normal, then the components or integratedcircuit is damaged, the electric control board should be replaced.
Apr 29, 2016 | Heating & Cooling
Please , may i know f4 error code in split type air conditioner
Here is error code f4
light fan motor of indoor
1?Check whether the contact of the plug of the motor wire 8 unit fault and socket is well, making sure well contact.
2?Check whether the indoor motor has damaged, the motor should be replaced when it is damaged.
3?Check whether the controllable silicon and other components on the electric control board have damaged, replace the controllable silicon or electric control board when they are damaged.
click on the link below and scroll down the left side to find error code f4...CHEERS
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
Mar 20, 2016 | Heating & Cooling
Soleus dual mini split KFMHP18 fault error F1
F1 error code is a communication failure between the outdoor and indoor units. Check all inter-connecting wires. They should be minimum 14g stranded wire. Make sure all electrical connections are tight. These units are manufactured by CHIGO, you may try to contact them.
Aug 10, 2013 | Soleus Ductless Mini Split 18000 Air...
Split unit aicon fujiaire appear e3 message
I have a Fujiaire split unit(wall type). I have this problem quite frequently, an error code E04 display, Try to look at the operating manual, it does not specify the problem, I check the compressor motor winding, the amount of F22 charge and clean the outdoor and indoor unit. Wonder why put an Error code when there is nothing on the troubleshooting list. But whenever the authorize repair man come for servicing, he could not tell me. Does anyone has a solution?????
May 26, 2011 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
My airconditioner will not turn on using remote control
Check there will be error code: If not check power to indoor is perfect. Error code details as follows
Code E3
Error detail Remote control transmission error(transmitting error)
Inspected unit Remote control.
Code E4
Error detail Remote control transmission error (signalreceiving error)
Inspected unit Indoor.
Dec 10, 2010 | Mitsubishi MSZ-A15NA Split System Air...
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
