Question about Apple Computers & Internet
Graphics, missing hard and disk drives,
Hi FixYa
G4, dual 1.42,
OS 10.4 .11,
2 GIG Ram
4 internal hard drives (120G boot-up), 500G1, 500G2, 40G.
plus addt’l firewire drives.) 23- apple cinema display. DVD combo and CD drive.
1. Intermittent problem - The DVD and CD drives do not show disks on the desktop.
2. Intermittent problem - Disks show up on desktop. Double click on it and prompt states ‘cannot be found’.
3. Intermittent problem - I insert a CD or DVD. The window opens showing all the files. If I click once on a file, the file disappears. If I double click on a file it disappears and prompt says ‘file cannot be found’. If I eject and reinsert disc, files show up again.
4. Consistent problem - In System preferences I select any of the other two 500G internal drives as start up drives, it still boots from the 120.
5. The internal hard drives intermittently do not not show up on the desktop. {The firewire drives always show up fine.)
A few times the unit froze and the grey screen came down stating 'you must restart the unit'.
I opened up the unit, exercised ribbon connectors, disconnected all peripherals, zapped the PRAM, removed Ram down to 512 K, reinstalled the 10.4.11 system from scratch using full install DVD (wiping the 120 boot drive clean). Above problems persists. All along Techtool Pro shows reports no problems.
6. Consistent problem - Random pixelation and dotting on the whole display, mostly arranged in horizontal patterns as it warms up and gets hotter (15-20 minutes). If the door is open the fan starts to run faster and faster. If the door is closed the fan stays at one speed. The pixelation happens with door open and closed. Cinema Display is OK- I tried it on other Macs and works fine.
I replaced graphics card with a used ATI RADEON 9800 Pro. Problem persists. Put back the old graphics card. Problem persists. Boot from TechTool Pro DVD. Problem persists.
Questions -
1. Could it be anything besides the logic board, procesor or power supply? If not, is it cheaper to buy a G4 Dual 1.42 on ebay (motherboard and  power supply, no drives, no memory) and moving my hardware into it?
Thnx
Paul
  • lynchcom Jan 05, 2009
    I tried. Apple will not repair as it's discontinued.
    Thnx
    Sergeant:
  • 369 Answers
YOUR MAIN BOARD HAS A PROBLEM JUST TAKE TO A APPle service center
Posted on Jan 04, 2009
Download needed RAM-OS missing
peter148
SOURCE: RAM-OS missing
Hi the Pin Pad is ok but it has to go back to a VeriFone supplier to download the operating software. With the Pin Pad not being used for 1,5 years the internal battery in the Pin Pad will have gone flat. Meaning that the Pin Pad has lost its internal software. This software can only be supplied by a Certified VeriFone Dealer.
Posted on Sep 25, 2008
Brian Sullivan
  • 27725 Answers
SOURCE: download needed RAM-OS missing
if this is whats happening to your computer otherwise i cant imagine ((download needed RAM))
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATAthe ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Feb 04, 2011
psoftware109
  • 42 Answers
SOURCE: "Download needed RAM-OS missing"
Download needed RAM-OS missing is cause to OS removed itself in sc5000.you need install OS again.
psoftware109@gmail.com
Posted on Mar 08, 2011
J D Wright
  • 874 Answers
SOURCE: Download needed RAM-OS missing
https://www.google.com/search?client=firefox-b-1-ab&ei=98qNWpaoL8Ovggfwk5KwAQ&q=ram-based+os&oq=ram-based+os&gs_l=psy-ab.3..0i22i30k1.3975.4101.0.4621.2.2.0.0.0.0.100.194.1j1.2.0....0...1.1.64.psy-ab..0.2.193....0.Z_8h3_sAF58
ram based os Google Search google.com
Posted on Feb 21, 2018
Feb 25, 2018 | Computers & Internet
I am on my g3 and it is very slow
The speed performance of any computer is affected the amount of RAM memory and the amount of space of the primary hard drive that contains the operating system. So, check both items and upgrade both to the maximum that can be had. Back in the day, RAM was expensive so as configured by apple, iMacs came configured with minimal size. With RAM upgraded, the operating system more applications could be opened, which includes processes that run in the background. With the minimal RAM, OS 8, would hit the hard drive to swap pages of memory, rolling them in and out. Over time, the area used on hard drive would fragment, causing several read operations to assemble a page of RAM memory. This I believe was the era of using disk utility tools like Norton Disk Doctor to de-frag the hard drive. Also Tech Tools. So the easiest is to upgrade the RAM on the G3 iMac / Power Mac. Once you have upgraded the RAM, then you can then begin to upgrade the hard drive to the maximum size that your OS is capable of using. It has been so long ago I have forgotten what that value might be. I believe that the latest version of OS 8 was at revision 6 (8.6). In the latter days of the G3 power macs / iMacs, it was OS 9 (9.2). Some G3 CPUs could run OS X (10.2). The point being to upgrade RAM, hard drive space, and the Operating System. The larger capacity of the hard drive should delay the onset of fragmentation. Something to consider when upgrading the hard drive is to determine if your G3 computer is capable of using a solid state "hard drive". If you are able to do so, the speed performance is very impressive. Boot times are phenomenal. What may have taken a minute to accomplish now only takes 30 seconds. Go to www.youtube.com enter keywords Mac G3 SSD. View several videos that others have posted about their experiences. There is a video demonstrating this guys upgrades on a G3 "Graphite" IMac, boosted to 1 gig of RAM, and a 60 gig SSD. Impressive this old Mac. Take note of MacRumors dot com website, a great resource. In general, I check YouTube videos in addition googling any particular subject. I would suggest to upgrading to "Tiger" just as he did. As it relates to your WIFI, it is possible that your WIFI card is defective or is missing. If you are running OS 9, then you have to do some investigating. If you are running OS x, then go to to the pull down menu and select "About this Mac" then select "more" the begin to see if you show an airport card. It is "iffy" whether your internal WIFI card would be able to connect with the wireless routers of today. Something to consider is to acquire an old airport base station unit and have that connected to where you currently are connected directly to your Mac. Alternately you might want to scan the forums like at MacRumors for any discussion surrounding vintage Apple products as it relates to WIFI. The limiting factor then become the graphics co processor. The OS will offload processing work to the graphics card. The greater the memory capacity of the graphics card, the faster the performance. Another website I go to is: www.macsales dot com. The have technicians you can speak with concerning upgrades. I wish you success as you seek to increase performance to the maximum. You have an excellent opportunity to do most if not all of the upgrades yourself I normally go to www.ifixit dot come. To get instructions on proper tear downs on my G5 / intel iMacs.
Dec 11, 2014 | Apple iBook G3 Mac Notebook
I got mac g4 just got face and ? on it, any have idea what going on it
Typically this is operating system corruption or a failed hard drive. If you can boot to your install media (CD, USB, or recovery partition) try a clean install. You could also try third party software solutions like Disk Warrior or Drive Genius (they supply bootable media) to fix the OS issues or check the disk for failures / corruption
Oct 16, 2012 | Apple iMac G4 Desktop
What is the best motherboard and system configuration for adobe premiere 6.5 and pinnacle pro on rtdv ? I need the configuration in details please..... Please, thanks, Mack
TECH SPECS for ADOBE PREMIERE 6.5
Minimum System Requirements
Windows
  • Windows 98SE, Me, 2000 (SP2), or XP
  • Intel PIII 500MHz
  • 128MB RAM (256MB or more recommended)
  • 600MB HDD space for installation
  • CD-ROM drive
  • QuickTime 5.0 recommended
  • Microsoft DirectX certified FireWire
  • dedicated large-capacity 7200RPM HDD
  • For Real-Time Preview:
    Pentium III 800MHz processor (Pentium 4 dual processors recommended)
    Macintosh
  • Mac OS 9.2.2 or Mac OS X v.10.1.3
  • PowerPC G3 (G4 or G4 dual recommended)
  • 64MB RAM (128MB or more recommended)
  • CD-ROM drive
  • QuickTime 5.0.2
  • QuickTime compatible FireWire
  • large-capacity HDD capable of sustaining 5MB/sec
  • For third-party capture cards:
    Adobe Premiere certified capture card
  • For Real-Time Preview: G4 processor (G4 dual recommended)
  • Jun 27, 2011 | Pinnacle Pro-ONE RTDV Video Capture
    I cant get my ibook g4 to run it turns on with blinking folder
    Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
    Mar 09, 2010 | Apple iBook G4 Mac Notebook
    Install Snow Leopard on a macmini Power-PC ?
    If it is a G4 PowerPC processor No
    If it is an Intel Processor Yes
    Jan 06, 2010 | Apple Power Mac G5 Desktop
    Can't get imac to boot up everything looks fine then I get a black box with white lettering saying error in start-up . code number post/16/2048DIMMO/J22, thanks for any help. I ran the hard-drive test and...
    Sounds like a kernel panic code. You may be missing a piece of the OS code due to a Hard Drive error from a power issue or whatever. You may need to reinstall your OS. Start up from the cd and save all your data you can to a flash drive or external hard drive and then do a clean install.
    Jul 16, 2009 | Apple iMac G4 Desktop
    External hard drive enclosure
    I too purchased a Nexxtech Hard Disk Enclosure and my Vista-based computer keeps telling me to try a USB 2.0 setup...the USB's ARE 2.0...did you try the setup disk that came with your unit?...I tried on mine but still a no go...I may have to return it to Best Buy & try somrthing different.
    May 19, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
    Cant load os
    Hi Tajjek,
    Try booitng the Mac from the installation disc which was shipped with the machine,make sure to use the right disc( which was shipped with the machine). If the unit does not boots to the OS disc,then remove the internal hard drive and power on the machine if you get flashing question mark after start up boot chimme then it is issue with the internal hard drive. Please get backt to me with your observation if issue persists.
    Feb 13, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
    External Firewire drive won't mount any more
    This model appears to have a high failure rate in consumer reviews, so it may have physical damage on the disk. Only a re-format of the drive will isolate bad sectors that won't hold data. Try re-mounting your drive after a fresh re-boot of your computer. If the drive came with the manufacture's software to allow it to communicate with your computer, then try removing this software from your system and re-installing it again. This will repair a corrupt driver or I/O program. Try using the drive with a new or different firewire cable. Other users have reported this drive working again after replacing the cable. If you use Mac OS 10.2, you might not be able to initialize or partition the hard drive. This may require you to partition and format the drive on a different computer. From your brief description, it sounds as though you may need to re-format the drive before it will work again.
    Apr 11, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
    Computers & Internet Logo
    169 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
