Question about Toshiba 50H82 50" Rear Projection Television
Picture of hyper module board toshiba 57h84
Is there a picture of the hyper module board and specs on the capacitors?
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Toshiba or any authorized service center can pull up the photo of that board (the 10 caps that fail are all indicated with red arrows) you are aware they are surface mounted caps?
Posted on Oct 30, 2012
  • 10 Answers
SOURCE: Capacitors for Toshiba Hyper box
Yes it will take care of numerous problems. Replace all 10mfd caps on the board.
Posted on Dec 17, 2008
MikeMaierTV
  • 206 Answers
SOURCE: toshiba 57h81 location of hyper board and remove procedure
Hyper board is located directly behind the input board, this is where all the tv conections are, then they are two tabs soldered from the bottom of the board then it simply unplugs, But replacing all those capacitors on that board can be a little tricky, replace all 10up @16volt caps and that usaly repairs the board
Posted on Feb 13, 2008
  • 1694 Answers
SOURCE: TOSHIBA 50HDX82 - hyper board failure
Toshiba likes to solder shields / covers in place.......check..
Small boards have a side clip = release with screwdriver while
releasing end clips = hard to describe, best to visually inspect.
I will let you know about service literature = CD ROM.........T.
Posted on Nov 14, 2007
SOURCE: Toshiba 42H81 Hyper Module replacement
MVPU14 and MVPU13 do cross.
Posted on Jan 02, 2009
  • 14 Answers
SOURCE: shaky picture on my toshiba 50h12
Your ICc may have damaged if display is flickering.
Posted on Jan 22, 2009
The picture went black but we do have sound. It was running perfect and picture was great until it just went black.
If this is a Toshiba 61A61 rear projection. First you have to determine if it has high voltage. You can find this out by looking at the end of each picture tube where the socket is to see if there is an orange glow indicating that the filaments are lit and the set has high voltage. If they are not lit then I know from experience with this set that there is a bad connection on the deflection board where the high voltage transformer is located. The HV transformer has red wires coming out of it. You will have to turn the deflection board upside down and look for the bad connection. But first just tap lightly on the deflection board with the handle of a screwdriver to confirm the bad connection. If the set comes on you will be required to solder the connection with a soldering iron and rosin core solder. Now if the orange glow is there you have bad capacitors on the hyper module. The hyper module is located to the right looking from the back and stands upright and is soldered to the main board. It will be required to unsolder and inspect the capacitors for bulging at the top. The hyper module is likely to not be available anymore. Changing the capacitors will fix the video problem
Nov 11, 2011 | Toshiba 61A61 61" Rear Projection...
What would cause a projection screen tv (toshiba) to have to warm up when turned on? the picture flutters and is unviewable for 6 to 7 minutes
The Hyper module needs replacement. There were repair kits available for the hyper boards several years back the capacitors ( surface mount) need replacement
Jul 01, 2011 | Toshiba 57H81 57" Rear Projection...
I have a Toshiba 65H82 television with the wavy line problem. I have read the solutions on this site. It talks about the "hyper board." The list of boards in the service manual does not list a...
Hyper board is located under metal shield mounted on signal board in tv, buy repair kit from HERE and replace capacitors in hyper board to solve wavy picture problem in Toshiba 65H82
Thanks.
Mar 29, 2011 | Televison & Video
The picture looks scrambled and appears to be only on the horizontal. I need a solution or at least an idea of what could be wrong and perhaps replaced.
I would guess the capacitors on the hyper module have failed. This typically can be identified by a scrambled picture when you first turn it on and after a period of time the picture begins to clear up.
The hype module is most likely right behind your hookup connections in a metal sheilded enclosure soldered to the main board. It is about 7 inches wide, and 7 inches tall.
That would be a good place to start. You would need a capacitor tester to verify if the caps have failed.
Feb 25, 2011 | Toshiba 57HDX82 57" Rear Projection HDTV
No picture, the little red light on the power button just flashes. I'm not sure if this is something relatively simple, like a bulb replacement, or if it's shot and I need to buy a new tv. Help! Toshiba...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem.....
Dec 31, 2010 | Toshiba 57H84 57" Rear Projection...
Picture flutters vertically
Many of these sets (57H84 etc) had a problem with the "Hyper" board.
It is a circuit in the set that processes all signal from the tuners, and all inputs.
Most of the time this problem shows up when the set is first turned on and after several minutes the picture goes to normal----the delay if you have this problem slowly gets longer and longer.
The hyper board is NO LONGER AVAILABLE-and the only way to correct it is remove it and send it out for rebuild.
There are about a dozen very small "surface mounted filter caps" on the board that dry out and cause the problem.
2 people with this problem were able to remove the board and replace all the tiny caps but IT IS NOT EASY AND NOT A TASK for a do it yourself person unless you have some real skill.
The problem usually looks like noise lines from left to right across the whole or part of the screen---if it started gradually---it is a bad Hyper board.
Let me know by responding with a comment if you need help or advise.
SD TECH
Aug 04, 2010 | Toshiba 57H84 57" Rear Projection...
Picture is wavy then fine, happens every two minutes
This model like several others had problems with what is called a Hyper board inside which processes all signal inside the set.
From a Toshiba service bulletin:
No: PJTV200503 2 Pages Ref: WU032505
Product: Projection TV Date: 3/25/05
Models: 42H81,43HX71, 43H71, 50HX81, 50H71, 50H81, 53HX71, 53H71, 57HX81, 57H81, 61H71, 65HX81 AND 65H81
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may-be liable for any resulting damages and may expose themselves and others to possible injury.
Application: The information contained in this bulletin applies only if you encounter the symptom(s) listed below.
Subject: MVPU13 Hyper Module Repair (23786198 / 23148017X)
Symptom: Multiple Symptoms may be experienced depending on which capacitor is faulty. The primary symptoms are jagged, digitized or pie crusting of the picture. The set may also be described with a poor sync condition.
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040 as shown in Figure 1. It's recommended that all of the capacitors identified in Figure 1 be replaced. (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.)
TOSHIBA AMERICA GOISJSUIVIIER PRODUCTS, L.L.C.
There are several surface mounted capacitors that dry out with age and usually the problem starts out when first turned on and then eventually after on a long enough time the set works--the time will get longer as the problem gets worse.
The board is no longer available and only two options here: locate and replace all the selected caps which is not a do it yourself job or remove the board and send it out for rebuild.
Let me know if you need more info as I have seen dozens of these sets with this kind of problem.
SD TECH
May 13, 2010 | Toshiba 57H83 TV
A band of color for a picture on my 50H72 toshiba projection tv suddenly becomes either half a picture with a thick band of color on top or just becomes a band of color with no seeable picture. We have...
The most likely cause of a problem such as described is failure of the "Hyper Module"; this is one of the "stand-up" PCB's on the main signal PCB (which is the one on the right when viewed from back of set). These modules have a history of failure of the multiple electrolytic "surface-mount" capacitors; successful repair of hyper modules usually entails replacing all caps on the board, and often some solder repair as well...the degree of soldering expertise required to adequately service such products will usually preclude all but professional repair
Mar 04, 2010 | Toshiba 46HM95 46" HDTV
Picture is distorted keeps on moving
Good Day,
You have problem with caps on the Hyper Board. This is how to repair it:
the top shield and replace all of the 10uf, 16v capacitors using Part Number 24619040 It’s recommended that all of the capacitors identified be replaced. (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care).
GOOD luck, big IRISH.
Dec 08, 2009 | Toshiba 42H81 42" Rear Projection...
Picture scrambled
A board called the Hyper Module has gone flaky. It needs to be pulled and a whole bunch of electrolytic capacitors need to be changed inside it. I have done many of these repairs before and the usual cost is around $250 to $300. The set is well worth the repair.
Jun 11, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
314 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
