Question about Electrical Supplies
Where is the relay switch for generac exl8000
Motor running but no power being produced, is there a relay switch I can't see?
4 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: 20KW Guardian Generac does not produce 12 volts to run engine
The problem is that the printed circuit board inside the generator draws a little current from the battery even when the generator is not running. Over the course of a few days this can make the battery weak enough to be unable to get recharged by the built in running charger which results in not enough power to run the electronic governor on the generator. Usually the spark plugs will work even with a fairly low battery.
Most of the Generac generators come with a built in trickle charger that runs off of the transfer switch load terminals. If your built in charger isn't doing the job it's either broken or you have the wrong sort of battery installed in the generator.
Regards,
Carl
Posted on Jan 26, 2009
mamicheddy
  • 79 Answers
SOURCE: Generac portable generator doesn't produce power
Remove front cover on the genset and you will see the brushes and rings. Clean the rings if black with emory cloth and inspect brushes. Flash the fields by apply a 12V battery to the brushes. the brush closest to you or the bearing is connected to the positive side of battery and the back brush is negative. You have to do this with genset running. You should notice your voltage climb up to over 50Vac maybe even over 100Vac. Make sure to use rubber gloves when flashing fields and keep hands away from rotating parts. if voltage does increase when flashing the the voltage regulator is shot. If voltage does not climb then you will need a new genset or generator end.
Posted on May 15, 2009
  • 37 Answers
SOURCE: I have a generac generator 19kv propane powered
Pull the no 1 and no 4 wires off the voltage regulator and apply 12 vdc from the battery to them + to no 4 - to no 1. start unit and see if its putting out at least 60 VAC. If it is then you have a bad voltage regulator. If itis not then you have to investigate the brushes, stator, and rotor.
Posted on Nov 18, 2009
Have a Generac EXL8000 and wires have been pulled loose from the switches and plugins and control panel.
This is an older generator. If you have the owners manual, there should be wiring schematics that give the wiring legends to all of the connections. I can't find a downloadable .pdf manual for your generator. If you don't have the manual, you'll likely have to take your generator to a service center for repair & testing.
Mar 08, 2016 | Generac Electrical Supplies
On a Generac model 1646-2 generator is the oil level switch normal open with full oil level.
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
Jun 19, 2014 | Coleman Powermate Subaru 5000W Portable...
Automatic transfer switch not transfering power to home
YOU MAY WANT TO CHECK THE RELAYS THAT ARE IN THE TRANSFER BOX
Dec 15, 2013 | Generac Guardian 200-Amp Automatic...
Coils on transfer switch got fried when utility came back what could have caused this
possible failure of a relay. contact generac,sometimes they will accomodate you with new parts
Oct 08, 2012 | Generac Guardian 200 Amp Transfer Switch...
Installed a generac 20kw about a year ago, ran fine untill 2 days ago. During a utility outage, generator ran for about 30 minutes and then stopped producing power while still running. All mains were still...
With the engine off, check the exciter brushes and slip rings which supply magnetic power for the alternator winding in the stator. Also, check the motor-to-alternator mechanical coupling. Check the breakers for tripping. To service beyond this point requires a schematic of the alternator, a voltmeter, plus knowledge of what the schematic is telling you. Good luck!
Jul 25, 2010 | Generac Power Systems Generac 5525 20 Kw...
I have a wiring question. i have a generac 5522 generator. what signals the generator to start? is it n1 and n2 or is it 15b and 23? if it is 15b and 23 does wire 23 just come back to the gen with 12...
The generators control board senses lost utility (N1 & N2) and after a time delay kicks in the backup. The board sends 12 v to the transfer relay thru wire 194 then back to terminal 23. This is held open till the startup timer times out and only after the warmup does wire 23 close to ground. This energizes the transfer relay, contacts close and E1 & E2 can now conduct generator produced electric to the transfer relay contacts, limit switch (XB1), Wire B, and a bridge rectifier.
Dec 22, 2009 | Electrical Supplies
Have to attach a red cable to a terminal on the starter motor.Howver cannot locate the atarter motor.Generac 8000 generator.Thanks
Some gensets have a reverse generator that actualy rotates the motor until running then switches back and produces power. But the starter could be in the front of the engine looking like a altrnator or some such device. good luck..
Aug 26, 2009 | Hammering
I have no ac power output, but motor runs fine!
if you dont have the field excitation then you'll never get any AC no matter how your motor runs..field excitation comes in two types..one is by pole magnets and two is by field coils connected to a battery..
Jun 25, 2009 | Generac 100 Amp 120/240-Volt Transfer...
Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Jan 20, 2009 | Generac Guardian 100 Amp Transfer Switch...
Regards,
Carl
Jan 11, 2009 | Electrical Supplies
Electrical Supplies Logo
81 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
