Question about Dell Computers & Internet
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
I have just purchased a Dell Laptop with Windows 7 Home Premium installed and I want to run my Cannon Pixma MP495 wirelessly What do I need to do?
  • Dell Master
  • 32,281 Answers
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Posted on Oct 29, 2012
  • koester_ch
    koester_ch Oct 29, 2012
    You are talking to someone that is just starting to use this computer and I don't know how to do these things.
  • Chris Hingee
    Chris Hingee Oct 30, 2012
    Setting up a wireless printer is not a job for a novice. I suggest you get a computer savy friend to help you.
mailtoravi
  • 186 Answers
SOURCE: upgrade vista home premium
As per my knowledge, there is no version of Vista called Vista Professional like in Windows XP.
Make sure what is the version to which you want to upgrade to from Vista Home Premium to Vista Business or Vista Ultimate.
The available versions of Vista Operating Systems along with the features supported from the Link below :
http://www.microsoft.com/windows/windows-vista/compare-editions/default.aspx
However, if you want to Upgrade the current version of Vista to a higher version like Vista Business or Vista Ultimate, you need to purchase Vista Anytime Upgrade kit from any retail store or directly from Microsoft.
You can find the required information related to Anytime Upgrade Kit from the link below :
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
However, make sure that you had created the Recovery Disks for your notebook using which you will be able to reinstall the preinstalled Operating Sytem along with all the Preinstalled Applications and Drivers after which you need to use the Vista Upgrade Kit to upgrade to higher version of Vista.
However, if you are currently having a 32 Bit Vista preinstalled in the Notebook, it is not possible to upgrade to a 64 Bit Vista since you can upgrade only a 32 Bit of Operating System to a higher version of 32 Bit Operating System and a 64 Bit Operating System to a higher version of 64 Bit Operating System.
Hope this helps....
Posted on Nov 17, 2008
  • 120 Answers
SOURCE: i want to reboot my
Reboot? You mean restart? Click Start, click the arrow beside the Lock button and choose Restart. It's the same.
If you mean System Recovery (wiping out everything but the OS and making the PC new), then there must be a software like Recovery Manager. Search Start Menu.
As it is a Dell, you must have a recovery partition on the drive. It will be just as new.
Or use the set of CDs that you created when it was new, or one which you got with the PC. If you didn't get and you didn't even make it, ask Dell to send a set for your model.
If nothing works, then use a Vista installation disk that you can buy in a retail store. Note that you won't get the pre-installed software that you got from Dell when you removed the PC from the box.
Posted on Nov 28, 2008
  • 35 Answers
SOURCE: reset my toshiba p300 laptop, to factory settings
The first thing you have to do is reset your windows password , There is a way to reset windows password without erasing anything.
Follow the instructions:
1.Free download the iso file : http://www.resetwindowspassword.com
2.Burn it to a disk to create the boot disk, that simple.
3.Configure your pc or laptop to boot in the cd drive,
4.Insert the CD, reboot from CD drive, and then just follow the process of instruction. A few steps later, admin password would be cleared
Took about 5 minutes for the whole process.
Posted on Jun 22, 2009
  • 476 Answers
SOURCE: I recently formatted my Acer Aspire 4732Z laptop
You should have used eRecovery preinstalled on your computer,
if you formatted this unit properly there should be no need for another install of vista,
opps what did you format this unit with???
XP or Vista or windows 7
you only need to reinstall another operating system when you up grade your system,sometimes not even then,
as for the product key on the bottom relates to the install on your machine.
The new vista will come with a different product key,
If you format the drive to install the new vista then the key on the bottom will not work.unless you have the new product key,you could contact Microsoft and ask them to help with the product key,they will want the proof of purchase tho,contact them over the phone ,
Hope this helps,Cheers MISTERDJ
Posted on Apr 11, 2010
Testimonial: "hey thanks for your help(: i didnt use n acer disk btw"
  • 14 Answers
SOURCE: forgot asus laptop password Windows vista
To reset your ASUS laptop Windows login password, I think you can try this password recovery software, fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. You can do it on your own, no need to send it to a computer shop. Regards.
Posted on Nov 17, 2011
How do I find ip address for canon pixma mp 495 printer?
Two links for you
Pixma MP495 Printer not detected - Canon Community
community.usa.canon.com/t5/Printer-Multifunction.../Pixma-MP495-Printer.../25583
  1. Cached
  2. Similar
May 26, 2013 - So I have a Canon Pixma 495 printer that worked great wirelessly ... Hi I have the Canon Pixma MP495 and I can't seem to find the IP address.
PIXMA MP495 Wireless Connection Setup Guide - Canon Europe
www.canon-europe.com/.../pixma_printer.../mp495_printer_wireless_connection_set...
  1. Cached
  2. Similar
This method is by far the easiest way of connecting your PIXMA MP495, so if your ... Press and hold the [Maintenance] button (A) on the printer for approximately 5 ... regarding pressing the WPS button, please refer to the access point manual.
ip address for canon pixma mp 495 printer Google Search
Oct 04, 2016 | Canon PIXMA MP495 InkJet Printer
I have a wireless mp495 printer i would like to install without the cd
Cannon has them. Go to their website: Canon Support Drivers PIXMA MP495 and click Drivers and Software. Run through their question and boom! you have drivers. Good luck!
-V
Feb 02, 2015 | Office Equipment & Supplies
Admin password for pixma mp495 printer
Hi
Did you solve the problem ?
I have bought a new pc and i cannot install the cannon mp495 because i havent got the admin pasword...!?!
Is there someway to reset the password ?
Apr 02, 2013 | Canon PIXMA MP495 Wireless Photo...
Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
Nov 22, 2011 | Canon PIXMA MP495 InkJet Printer
Where can I install the PIXMA MP495 CD-Rom as my laptop does not support CD-ROM's?
You can download everything off of the CD from Cannon's website. Click here to go to their website, go about halfway down the page until you find a button labeled "Drivers & Software" click on that and it will ask you what operating system you have. Just select which operating system you have from the menu. Once you select what operating system you have, click "Drivers" and hit download next to the first option.
Jul 28, 2011 | Canon PIXMA MP495 InkJet Printer
I just purchased a DELL Inspiron .. running Windows 7. It says if I just plug in my Cannon MX 310 Printer/Fax that Windows will recognize it and set it up for me. I see that it definitely creates an...
I am sure that, you have not installed the drivers of that printer, because Windows 7 recognize most of the printers automatically however the printer and fax machine would start working properly the time you would install the printer drivers on your system and laptop, please let me know it works or not, so i can send you next update on it
Sep 28, 2010 | Canon PIXMA MX310 All-In-One Printer
I HAVE CANNON PIXMA MP150 LOST THE SOFTWARE THAT CAME WITH IT FOR PHOTOS AND PROJECTS I DID IN CRAFTING IT WAS SOMETHING CALLED SCAN GEAR WAS ONE I THINK?? BUT IT CAME ALREADY ON THE INSTALLATION DISC I...
The "Vista Home Premium Service Pack 2" disk that it is prompting you for came with your computer itself, not the printer. It's most likely labelled "Setup" or "restore" disk - just put it in the drive when prompted and you should be all set!
Oct 20, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP 170 scanner driver, Vista ''not recognizing''
You would need to download the vista driver to install. Hope this helps.
Dec 24, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
314 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
