Question about Hewlett Packard Printing & Imaging HP Deskjet 3050A e-All-in-One Printer Series - J611 CR232AB1H
Printer prints very slowly - Hewlett Packard Printing & Imaging HP Deskjet 3050A e-All-in-One Printer Series - J611 CR232AB1H
Panasonic printer kx mb 262 driver download
Iakjanila, remove the toner cartridge slowly. 2. Tilt the cartridge back and forth to ensure even distribution. Do this slowly. 3. insert it again in the printer, close the compartment cover and now test print. GL
Jan 12, 2014 | Office Equipment & Supplies
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
Printer prints slowly like "best
Go to Printer Properties and locate the Preferences then settings, and change the Quality there.
Mar 02, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Bad print quality
frist keep your cartredge out after that beat top slowly slowly and then insert in your printer anter that restart your printer if problem is not solved then reinstalled your drivers of printer. after that problem is now here till then see your ink ribbon is on goog condition and the cartredge have ink and then restart the computer
Apr 03, 2010 | Samsung CLP 300 Laser Printer
Printer prints very slowly.
Printer cartridges have what is called a TSR sensor in the print head. It is basically a thermostat to tell the printer if it is at risk of overheating the print head. If the TSR on your cartridge is defective the printer will play it safe and print at slow speeds to avoid damage to the printer cartridges.
Feb 02, 2010 | HP DeskJet 950c InkJet Printer
I have a tally 2250 printer to beused under win98.
you can installed this printer driver of genric text only.
Jun 25, 2009 | Tally T2250 Matrix Printer
Printing slowly! Very slowly!
Well thats no good!
Remove the printer and reboot your machine.
Go back into the print queue and remove the printer,
Add the printer and try to print a test page.
- Vincent
Nov 22, 2008 | HP Photosmart 7450 InkJet Printer
Specks on print out of Mono Laser Printer HL2040
If its spots this could have been from the cartridge or the fusser unit...
Do a half print test...send a print page to your printer listen to the printer print as soon as you think the printer has printed some little bit switch off the printer...take the cartridge and view the printed portion can you see the spots..if not.....than its your fusser unit thats marking the paper....remove the half printed paper slowly.....not to tear it......remover the fusser unit(hot unit)........at the back of the printer....towards the top....on the unit it self you will see a Teflon paper ....move the gear on the far end of the fusser unit itself and view if there is any spots....try cleaning this spots slowly as not to damage the Teflon or mark the Teflon.....
Nov 04, 2008 | Brother HL-2040 Laser Printer
Printer feeds through blank piece of A4 fast, followed by another one, slowly
Service error 6A00 Cancel printing and turn the printer off and then back on.
If this doesn’t clear the error, see the printer manual for more detail.
Jun 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Hewlett Packard Printing & Imaging HP Deskjet 3050A e-All-in-One Printer Series - J611 CR232AB1H Logo
63 people viewed this question
Top Hewlett Packard Printing & Imaging Office Equipment & Supplies Experts
Tony
Saleem Baig
Saleem Baig
satya
satya
Level 1 Expert
Are you a Hewlett Packard Printing & Imaging Office Equipment and Supply Expert? Answer questions, earn points and help others
