SOURCE: I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
SOURCE: defective lid switch
you can bypass the lid switch,remove thw 2 screws on the console one on each side,flip the console up,you will see a 3 wire jack in the middle on the washer,disconnect the jack,the wires going to the console clip the 2 outside wires leave the green and wire nut the others together,plup back in and your done,let me know how you do-mike
SOURCE: can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
SOURCE: door locked, won't turn on. won't reset
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Testimonial: "Good advice fast! Thank you so much for your time and expertise!"
