Printer prints very slow - Office Equipment & Supplies
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
Slow printing
Check that the default setting for print quality on your printer driver hasn't been set to "Fine".
In your Opertaing System, find your printer (in XP it's under Control Panel / Printers and Faxes) and select Properties. This should then bring up the settings for the driver.
Fine printing quality takes over double the time "Normal" quality takes so would considerably slow your printing.
Apr 10, 2014 | Brother MFC 210C All-In-One InkJet Printer
Why does processing job take long?
the print file detail may be multi-layered may be too much information in print job- your printer memory may not be adequate, you may be printing through a slow network, you may be printing through an older print server which is as slow as parallel port printing or you may be printing through your parallel port which is slow.
Dec 27, 2013 | HP LaserJet 5500dtn Color Printer
Printer takes forever to print
How is the printer connected to your computer(s)?
If it is USB or network. Try a different cables.
Does your computer run slow also? Low disk space can cause print jobs to print slowly.
Network issues can cause slow printing as well. If your printer is on network and there is a mismatch of 10/100 Mbps speed or Half/Full duplex, the printing can be slow.
If your OS is Windows, remove the printer from Printers and Faxes. Uninstall the driver package if installed separately. Download the latest drivers and install them and reinstall the printer.
Apr 15, 2013 | Lexmark MS310dn Monochrome Laser Printer...
Printing in color on my Lexmark printer is very slow. This is a wireless printer and is not so slow on black and white printing.
Printing in color is always slow vs. printing in B/W. If your printing color with the highest resolution setting, it will print really slow. You can adjust the resolution settings in Printer Properties for the Lexmark. If you want faster print, select a lower resolution.
Mar 03, 2011 | Lexmark X7675 Wireless All-in-One Printer
It is printing very very slow
Try this....when you go to print click on properties and then
color....then print in greyscale. It should then print much, much more
quickly. I had the same problem and it appears that when you print in
color on a network, it uses the graphics mode rather than a text.
Mar 02, 2011 | HP OfficeJet 7310 All-In-One InkJet...
I have developed an ms access POS. When i print receipt to samung thermal printer srp 350 ver 2, it prints very slow. i have tried several drivers but i end up with the same slow printing problem. I am...
itecghana, printing slow is probably an issue of the interface type (serial, parallel, usb, ethernet...) and not the printer itself. The Bixolon 350 has a self test printout capability (turn on printer while holding down the feed button) which'll demonstrate the print speed capability of the printer.
My guess is you have a serial interface (COM port), serial is notoriously slow when printing via any windows driver.
If the printer you have is a 350, one solution is to change the interface card on the printer from Serial to USB. The part number of the USB interface card is IFA-U Type, can buy one for about 35 bucks online.
Jan 10, 2011 | Samsung SRP 350 Thermal Printer
It prints really really slow
Expect pictures to print slow no matter what.
For letters and all text documents set your printer up to print draft for the best printing speed.
Jul 31, 2010 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart C3100 printer is printing very slow.
Check 'properties' when printing and make sure that you are not printing at the highest quality color if you are not printing pictures.
Jan 31, 2010 | HP Photosmart C3180 All-In-One InkJet...
16 people viewed this question
k24674
jasbo
jasbo
