Question about Soundstorm SMP3-100R CD Player
Soundstorm SMP3-100R CD player
I have my cd player for about 6 months now and have not used the USB nor the Memory card slot for about a month. when i plug in a USB thumb drive with MP3 songs, the display says reading USB and it says that for about 30 - 45 seconds and then the radio starts playing or if the a CD was in before the USB thumb drive was plugged in it would then play the CD. Please help marcas
I have had this problem before with mine. I found that it was one of the tracks I had on my flash drive was corrupt, I don't remember which track it was but if I plugged my drive in it would play until it got to that track and then it would just swith over to radio or cd. I had the same problem with a cd I had burned a bunch of MP3's on. If you erase your flashdrive, reformat it and then try saving songs to it again that should take care of the problem as long as you find out which file has the corruption in it and you don't put it back on your flashdrive.
Posted on Jun 12, 2008
I have forgotten my Sandisk 8GB memory password. So, Can you Suggest me on break my password?
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Jun 29, 2012 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have saved my pictures to my ScanDisk 2gb, how do i insert it into my computer to transfer my pictures
IF YOUR PC HAS AN MEMORY CARD SLOT USE THE CORECT ADAPTER AND JUST SLIDE IT IN,,,,BUT IF IT DOSENT HAVE A CARD SLOT YOU WILL NEED TO BUY A USB MICRO/SD ADAPTER... HOPE THIS HELPS.
Jul 15, 2011 | SanDisk 2GB microSD Memory Card
My daugther has a sylvania netbook and I cannot get her usb to read her removabale cd drive? please help
If youare referring to the Sylvania SYNET07526 using Win CE 6, then a CD player is not recognized by the operating system, so you can not add this to that machine. It does recognize memory devices such as thumb drives and USB drives of most sizes that can be used to store anything you download. The application Media Player can play some files from the internet. that is just about all it can do.
Jan 23, 2011 | Sylvania G-Netbook
Motherboard diagram
A Computer Motherboard Diagram motherboard-diagram-01.jpg Once you know what you are looking at, you can recognize the components on any motherboard layout. A computer motherboard diagram is very useful for when you need to replace motherboard, do motherboard upgrades, troubleshoot motherboard, or build your own computer.
  1. PCI Slot - This board has 2 PCI slots. These can be used for components such as Ethernet cards, sound cards, and modems.
  2. PCI-E 16x Slot - There are 2 of them on this motherboard diagram, both are blue. These are used for your graphics card. With two of them onboard, you can run 2 graphics cards in SLI. You would only need this if you are a gamer, or working with high end video / graphics editing. These are the 16x speed versions, which are currently the fastest.
  3. PCI-E 1x Slot - Single slot - In the PCIe 1.x generation, each lane (1x) carries 250 MB/s compared to 133 MB/s for the PCI slots. These can be used for expansion cards such as Sound Cards, or Ethernet Cards.
  4. Northbridge - This is the Northbridge for this motherboard. This allows communication between the CPU and the system memory and PCI-E slots.
  5. ATX 12V 2X and 4 Pin Power Connection Power Connection - This is one of two power connections that supply power to the motherboard. This connection will come from your Power Supply.
  6. CPU-Fan Connection - This is where your CPU fan will connect. Using this connection over one from your power supply will allow the motherboard to control the speed of your fan, based on the CPU temperature.
  7. Socket - This is where your CPU will plug in. The orange bracket that is surrounding it is used for high end heat sinks. It helps to support the weight of the heat sink.
  8. Memory Slots - These are the slots for your RAM. Most boards will have 4 slots, but some will only have 2. The color coding you see on the motherboard diagram is used to match up RAM for Dual-Channel. Using them this way will give your memory a speed boost.
  9. ATX Power Connector - This is the second of two power connections. This is the main power connection for the motherboard, and comes from the Power Supply.
  10. IDE Connection - The IDE (Integrated Drive Electronics) is the connection for your hard drive or CD / DVD drive. Most drives today come with SATA connections, so you may not use this.
  11. Southbridge - This is the controller for components such as the PCI slots, onboard audio, and USB connections.
  12. SATA Connections - These are 4 of the 6 SATA connections on the motherboard. These will be used for hard drives, and CD / DVD drives.
  13. Front Panel Connections - this is where you will hook in the connections from your case. These are mostly the different lights on your case, such as power on, hard drive activity etc.
  14. FDD Connection - The FDD is the Floppy Disk controller. If you have a floppy disk drive in your computer, this is where you will hook it up.
  15. External USB Connections - This is where you will plug in external USB connections for your case or USB bracket.
  16. CMOS battery - This is the motherboard's battery. This is used to allow the CMOS to keep its settings.
May 31, 2010 | E-Machines T2542 PC Desktop
Upload data from memory stick to desktop
When you say memory stick im assuming you mean something such as a usb jump drive (thumb drive) or an sd card ( ex. for a digital camera)
A usb thumb drive you would plug into an empty usb port. Open My Computer or Computer in the start menu.
You will see your thumb drive appear as a drive. You can double click on it to open it and see the data stored on it. From there you can copy it anywhere you want on your pc.
If you are talking about a memory card for a digital camera etc then you need a card reader for your computer. You would plug the card reader in via usb. Plug the card into the appropriate slot and it would show up in my computer just like a jump drive would. Again you can save the data however you would like from there.
Thank you for choosing fixya!
Feb 16, 2010 | Dell Inspiron 530 Desktop Computer
Expandable Memory
If music won't load onto Micro Sd card:
1) go to settings
2) go to USB mode
3)change to MSC format
Now you're good to go.
Nov 03, 2007 | SanDisk Sansa e250 MP3 Player
Using a lexar jumpdrive in car audio
I would recommend trying a clean thumb drive with no software, only mp3/wma files. Having software and other files that are not audio may cause problems.
Mar 15, 2007 | Virtual Reality Sound VR3 CD Player w/ USB...
Soundstorm SMP3-100R CD Player Logo
242 people viewed this question
Top Soundstorm Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
