Question about Porter Cable PorterCable BSI525W 5250 Watt Electric Generator
Porter cable 5250 watt generator will not stay running
4 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: My porter cable generator 3000 wt will not stay running once star
If this generator has been stored for any length of time with fuel in the carb you probably have a plugged main jet in the carb. As joboo1 says there are a few other things that could cause this behavior, but most often I see dirty carbs, water in the fuel, and plugged/dirty air filters. Get a flashlight and look into the fuel tank thru the filler hole, if you see anything floating in there you've got water in the fuel. Look at the ari cleaner, oil and fuel on the element indicate a dirty carb. Of course check the oil level. Lastly, take the bowl off the bottom of the carb (shut off the fuel valve first), if you see debris in there the carb needs a good cleaning.
Regards,
Carl
Posted on Mar 01, 2009
pic498
  • 32 Answers
SOURCE: no electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Posted on Jun 13, 2009
SOURCE: what type of oil do
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Posted on Oct 25, 2010
What spark plug does a porter cable BS1525w take
The Briggs and Stratton part number is 591043 sparkplug
Nov 30, 2015 | Porter Cable PorterCable BSI525W 5250 Watt...
When I spray starting fluid in carb it starts but won't stay running
It is not getting gas. Check there is gas in the tank, the fuel tap is working and the float in the carburettor isn't stuck.
Aug 16, 2015 | Porter Cable PorterCable BSI525W 5250 Watt...
What type fuel does a 5250 porter cable generator take
From p.10 of the manual
"Check fuel level, fill as required. Make sure generator is turned off and has been allowed time to cool down. Use clean, fresh, regular unleaded gasoline with a minimum of 87 octane. Do not mix oil with gasoline".
(taken from bottom of this webpage
http://www.cpoworkshop.com/porter-cable-bsi525-w-5-250-watt-electric-generator/pcbnbsi525-w,default,pd.html?cgid=porter-cable-delta-discontinued )
(Is this your exact model ?)
14.April.2014
Apr 14, 2014 | Electrical Supplies
THE VOLTAGE COMING FROM THE GENERATOR IS NOT RIGHT. iT WILL BLOW A LIGHT BULB INSTANTLY
Connect a voltage meter to the 115v plug and measure voltage. If too high, adjust governor spring tension to compensate. Your engine developes max horsepower at about 3600 rpm. At this speed the generator should be producting 115v at 60 cycles. Good holidays
Dec 17, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
What type of oil do i take for a porter cable 5250 watt electric generator?
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
I have a porter cable 5250 generator that bounces off the governo
there 2 linkages that conect that would be the problem. you have on conected to the throttle switch that runs to the govener than on that govener os another linkage hooks up to it and runs to the carborator that ajusts the flow. if you don't have both linkages than you need to order 1.
Jun 14, 2009 | Coleman Powermate Powermate 5000W...
Regards,
Carl
Feb 23, 2009 | Porter Cable 3,000 Watt Electric Generator...
Porter Cable PorterCable BSI525W 5250 Watt Electric Generator Logo
69 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
