Blue green and yellow base picture no red colour
    Sergeant:
  • 214 Answers
This could be from a couple of reasons. It could be a transistor, or resistor on the neck board that controls the red gun on the tube if it is a tube tv. It could also be a weak red gun in the tube itself and may need rejuvenated. Or maybe it can also be a bad solder joint on the PCB that connects the yoke connector.
Posted on Oct 30, 2012
tvtek
  • 1284 Answers
SOURCE: The picture is only producing the basic colours red green and blue
Can you post a picture of the Tv with the issue stated?
Posted on Mar 01, 2007
chrispurs1
  • 372 Answers
SOURCE: help,colour is wrong
Hi. The problem is either the degaus positor has failed which is an easy repair. Or have you recently placed hifi speakers or something with a strong magnet in side near your tv set.
Posted on Sep 03, 2007
  • 556 Answers
SOURCE: Television colour
your problem is simple it is called colour patch. it is basically due to change in direction or you must have shifted or tilted. it might be due to magnetic effect like spkr,telephone near by it.just remove from that location. put of the set for 15 minutes &put it on .problem will get clear. ask tv tech. to degauss it by dega.coil.it hardly 1 second job. regards
Posted on Sep 12, 2007
  • 1694 Answers
You can start with the make, model and age off the back of
the TV..........................T.
Posted on Dec 24, 2007
Shuttle83
  • 1139 Answers
SOURCE: Incorrect Tv colours
Hello Roloi,
This sounds like a problem with your yoke transformer. I would suggest having a qualified TV technician work on this problem, because it involves testing a component that could have dangerous current in it.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 25, 2008
Directv can't connect my tv to he, what can I do, they say I need a green plug in in the back,with the red, yellow, white
What I believe they are trying to tell you is you need to hook up into a component input . It is a video input only and it has three jacks usually coloured red green and blue. Match up the colours with the receiver and you will get an HD picture. They way you currently have it hooked up is a composite connection with only the yellow being for picture. This cannot get you an HD picture. The red and white is for the sound. I don't know what you mean by he though.
Sep 24, 2015 | Emerson 42" Plasma Tv Pl-p42w-10a 720...
BEKO 32WLU530HID only red colour except on internal Menu
Sounds like a loss of green--I am in USA and Scart term not used here but I am aware it began as internet slang for Component hookup--which does use a Green, Red, and Blue input cables---if that type then suspect no green from source or cable bad etc.
Apr 25, 2012 | Televison & Video
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
No green and yellow colour
Hello
If you see the picture in yellow colour, means that there is no blue colour output from the video drive section in your tv, Yello is the mixtrure colour of red and green. Green is actualy there. blue colour is absent.
To detect this fault, you must open your tv. Just look in to the video output section, can be located at the picture tube base card, which is plughed into it diretly. See for any loose soldering points there. Check whether transisotors are used for red, green and blue output stages, or an Ic or three seperate Ics are used for this purpose. Anyway, blue catode of your picture tube pin gets a hig voltage, and so the blue emission is absent. You just check the voltages at red,gree and blue catodes, at the respective picture tube pins, which can be taken at picture tube base card. All of these three pin voltages must be somewhat equal to each other. In your case, no voltage at blue cathode will be higher that the other two. Check for the reason. It may be due to an open video output transistor [blue], or an Ic, of one Ic if used for the three colour outputs. Check and replace the same, will rectify your problem. Ok
If you have andy difficulty, get it to me through Fixya. Ok
Gopakumar, India.
Nov 21, 2010 | JVC AV-27230 27" TV
I have seen a problem in my tv is that there is no green colour display in crt. only two colour ( i.e. Red and Blue) or combination may be display. Pl. look into this matter , replay soon
Your problem may related to the green output or driver stage in your tv. Usually green calour is not tranmitted, only blue and red colour informatein are comming from transmitters. Green colour information is regenerated inside the tv by matrix network. If the matrix get damaged no green colour will be displayed. To check first; whether the TV colour picture tube's green gun is right or not. For that you must connect a resistor of value more than 470k 2W, to the green cathode of the picture tube base to earth. The connection should be done causiously, not for a long time. It is advised to do in intermittantly with just touches. When you touch the green cathode with the resistor with one side of it earthed, a green flash must come on the crt. You can do this test for red and blue too. If there is no green flash, or light picture tube may be faulty. It is a very rare case. You must check the volltages of the other two cathodes [red and blue]. The voltage at green cathode must be almost the same as other two.
Just check the green output transistor for open. If it is open, voltage at green cathode will be high. Also check the base voltge of the green output transistor. It should be around 2.5vDC. You can compare the base voltages of the other two transistors with green drive base voltage. If there is no base voltage, the fault should be in the matrix section. It is inside an Ic. Philips usually uses TDA series Ics in chroma section. Check the Ic pin voltages according to service manual and try to rectify the fault. It needs a technical knowledge and skill.
Oct 14, 2010 | Philips Magnavox 27MS343S 27" TV
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
