Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
New plug no fire in the ingintion
How do you trouble shoot the ingintion coil or pack on husqvarna 325L added new plug and checked stop switch checked ok what could cause it not to fire. added new carb and plug it stared right up shut off would not restart, fuel ok, could the coil went bad that fast. help
  • Husqvarna Master
  • 2,239 Answers
The ignition unit can fail at any time, before replacing try removing the top cover and pulling the plug leed away from the cylinder, i have seen the leed wear against the cylinder and short out,also check the wires that go down to the unit, these can also short out, it is not a simple task to change the ignition unit, you need to have all the from end off the machine to get to it
Posted on Nov 01, 2012
4 Suggested Answers
  • 42 Answers
SOURCE: spare parts
I have many different web sites that you can find parts at. Here are a few of the best:
www.jackssmallengines.com
www.outdoordistributors.com
www.m-and-d.com
Let me know if you need any help finding your parts. Thanks.
Posted on Apr 04, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: 323L Husqvarna trimmer
This sounds like the carb needs to be adjusted like it is letting to much fuel into the cylinder. There is supposed to be fuel and air mixture in the cylinder to make it fire. If there is to much fuel what will happen is that it will just build up in there and the air wont get hot enough as it compresses to start the engine.
Posted on May 21, 2009
  • 652 Answers
SOURCE: HUSQVARNA 125L/LDTHE TRIMMER WILL NOT CARRY A WORK
Buy a new Homelite you can get one for under a hundred dollars at home depo. This will help out and the parts for yours to fix would be about the same. Sounds like there is a problem with power, could be the cable drive is malfunctioning.http://www.homelite.com/
Posted on Oct 06, 2010
Trouble shooting no spark
If it's an EFI vehicle check the coil pack output. Some vehicles you can sway the coils around to see if it's bad. Your wires may be bad or the boot and spring if it's coil on plug. Check the sensors related to the firing system crank cam etc. See if there is wiring damage anywhere
Mar 21, 2017 | Cars & Trucks
I have no fire...checked all the basic options...
Hi, Leisha and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
TROUBLE SHOOTING
How to diagnose no spark situation on motorcycle
How to test motorcycle CDI box ignition coil
Testing your motorcycle coil
Mar 03, 2016 | Motorcycles
No fire to plugs on 1991 ford aerostar 4.o replaced crank sensor,coil pack and switch what else is there
If the engine cranks but has no spark, you need to know if the coil is getting voltage and a ground signal. The coil gets power from the ASD relay and a fuse.
Have you checked the compuer for trouble codes ?
Jul 08, 2012 | 1991 Ford Aerostar Extended
Briggs and stratton 24 HP model ELS 725 mower stopped running have power, turns over, does not fire. please explain your answer with instructions for ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN...
A great expedient spark tester can be made from an old spark plug that you know is GOOD.....clip or grind the grounding terminal ( the terminal which goes over the top of the electrode) back until you have a gap of 1/8 to 3/16 of an inch between the terminal and the electrode...Remove both plugs from the machine and attach your new test plug to the plug wire. Ground the plug by placing it on the head or the shroud. Turn the machine over. If you are getting fire you should see a strong blue spark shoot from the electrode to the terminal. If you have no fire then you probably have a bad ignition coil, bad plug wire, or maybe just a bad seat, brake, or PTO safety switch...I'd check these first. Also check your ignition switch in the run position with a test light to be sure it is good....hope this helps... ;-D
Jul 08, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna 235 not an e model, Will not start, no spark to plug.
Hello David; We are prohibited from contacting you directly. It sounds as though the ignition module is defective but it could also be a defective switch or interconnecting wire, try this please, it tests the entire system.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
In the USA a duplicate receipt can usually be obtained from the merchant, there too? If not what about your credit card receipt?
I would try my local Husky dealer once the problem is isolated.
Dealer Locater.
http://www.husqvarna.com/uk/homeowner/dealers/dealer-locator/
An IPL (Illustrated parts listing) can be found here:
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Husqvarna Forest & Garden #952802239 235E...
Starting problem
It is most likely the distributer or an internal part of the distributer. It may also be the coil pack since it went so suddenly. I believe your local auto parts store can test the coil pack and it should be easy to remove. Good luck hope I gave you a good starting point for your trouble shoot.
Feb 22, 2010 | 1986 Jeep Cherokee
2004 Cavalier with 2.2 Ecotech. Running very rough The two outboard spark plugs are firing, the two inboard plugs are not. The question is: which is more likely to be the trouble, the module in the...
I would bet it is one of the two coil packs, the modules rarley go bad.to make certain you can take the two coils off and switch their locations
just make sure you put the spark plug wires back on the coils as if you did not switch the coils. there are two small bolts holding each coil on. PLEASE rate my answer because I am new on here. chrisdaddyp@aol.com
Jul 08, 2009 | 2004 Chevrolet Cavalier
Coil pack
153624 is the firing order
Jun 21, 2009 | 1998 Ford Mustang
No fire
Two possibilities left.
You have a short in your stop circuit or bent/out of place component. To check this unhook the small wire on the coil and tuck it out of the way. Put your recoil back on and try to start it. If it starts you need to follow the wire and look for any exposed wire. No exposed wire then you need to follow the mechanical portion of the on/off switch, something is not aligned right or a spring is worn out.
Next check your flywheel to coil air gap. Place a cover of a notebook or a piece of cardboard from a cigarette pack between the flywheel and the coil. This will get you the proper air gap. Then tighten down the coil. If that's not it, you have a bad flywheel. It's very rare but does happen.
Note: while you have the flywheel exposed, clean it up with light grit sandpaper (180 grit or finer) or steel wool. Rust can interfere with the electrical field.
Mar 31, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
156 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
